PS410HGOEMX
PS410HGOEMX
    TRIPPLITE
    POWER STRIP MED 4 OUTLET 10'
PS410HGOEMX 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States UL1363a, Paragraph 14.1(d) States "The SPRPT shall be permanently attached to the medical equipment by a means such that it is only removable with the use of a tool." To achieve compliance, one must use the PSCLAMP. For Patient-Care Vicinity - UL 1363A MedicalGrade Power Strip, 4 Hospital-Grade Outlets, 10 ft. (3.05 m) Cord, Drip Shield MODEL NUMBER: PS410HGOEMX Highlights ● Antimicrobial protection helps prevent the growth of bacteria, viruses, fungi, mold and mildew ● Approved for use in patient-care vicinities when properly mounted ● Complies with UL 1363A specifications ● 10-ft. (3.05 m) cord with NEMA 5-15P-HG hospital-grade plug ● Optional drip shield provides extra protection from liquids Package Includes Power strip with built-in cord manager and optional drip shield supplies power to movable plug-connected components mounted to IV poles, carts and mobile medical workstations inside or outside of patient-care vicinities. Features Power Distribution Anywhere in Any Medical FacilityIdeal for use in operating rooms, patient-care vicinities, therapy rooms, imaging environments and administrative areasFor use on IV poles, mobile carts, crash carts and mobile workstations, when properly mounted120V, 50/60 Hz power strip complies with UL 1363A specifications Exclusive Antimicrobial ProtectionAntimicrobial coating helps resist the growth of bacteria, viruses, fungi, mold and mildewCoating meets the requirements of JIS Z 2801:2000, an international standard for evaluating efficacy in antimicrobial products Versatile Medical-Grade Solution4 NEMA 5-15R-HG hospital-grade outlets provide consistent powerIntegrated cord wrap provides easy cord managementRugged, all-metal housing for long life in demanding environments Premium Safety FeaturesDual, resettable built-in 15A circuit breakers protect against dangerous overloadsSwitchless design prevents accidental shut-offDrip shield adds extra measure of safety against liquids and moisture Ready to Use Right Out of the BoxBuilt-in mounting tabs and flanges make the PS410HGOEMX easy to install on a variety of surfaces Specifications 1/3 ● PS410HGOEMX UL 1363A Medical-Grade Power Strip with four 15A Hospital-Grade Outlets, 10 ft. Cord, Cord Wrap and Drip Shield ● Owner’s Manual with maintenance requirements 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332168948 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 15A 120V Input Plug Features Hospital Grade Plug Input Cord Gauge Type 14 gauge; SJT Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-15P-HG Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output Receptacles (4) 5-15R-HG Circuit Breaker (amps) 15 Overload Protection 2 x 15amp breakers (1 line, 1 neutral) Transformer Accommodation (4) Yes Outlet Orientation Single row of 4 Right-Angle Outlets No USER INTERFACE, ALERTS & CONTROLS Switches No power switch PHYSICAL Color White Material of Construction Metal Power Cord Color White Form Factors Supported IV poles, mobile carts, crash carts and mobile medical workstations Housing Color White Included Mounting Accessories Mounting tabs and flanges Mounting Holes or Slots Yes Cable Management Bar Receptacle Color White 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / in.) 10.12 x 6.10 x 2.36 Shipping Dimensions (hwd / cm) 25.70 x 15.49 x 5.99 Shipping Weight (lbs.) 3.06 Shipping Weight (kg) 1.39 Unit Dimensions (hwd / in.) 9.940 x 4.280 x 2.170 Unit Dimensions (hwd / cm) 25.25 x 10.8712 x 5.51 Unit Weight (lbs.) 2.84 Unit Weight (kg) 1.29 Mounting Details Includes flanges FEATURES & SPECIFICATIONS Antimicrobial Yes Built-In Circuit Breaker Yes Built-in Cable Management Yes WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PS410HGOEMX 价格&库存
很抱歉,暂时无法提供与“PS410HGOEMX”相匹配的价格&库存,您可以联系我们找货
