PDUMV20-24
PDUMV20-24
    TRIPPLITE
    POWERSTRIP
PDUMV20-24 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2kW Single-Phase Local Metered PDU, 100-127V Outlets (6 5-15/20R), L5-20P/5-20P adapter, 0U Vertical, 24-in. Highlights ● Local Metered single phase 100-127V 16A 0U 24-in. / 61cm vertical rackmount PDU ● Two-digit current meter reports output current in amps ● Attached 15-ft. (4.57 m) cord with NEMA L5-20P plug and 520P adapter ● 6 NEMA 5-15/20R outlets ● Toolless button mount and boltdown bracket installation hardware included MODEL NUMBER: PDUMV20-24 Package Includes Features ● 20A single phase 100-127V Local Metered Power Distribution Unit / PDU (Agency de-rated to 16A continuous) ● Two-digit lighted meter reports combined total output current in amps ● Attached NEMA L5-20P input plug with 15-ft. (4.57 m) line cord and 5-20P adapter ● 0U 24-in. / 61cm vertical rackmount format installs using no rack spaces ● 6 NEMA 5-15/20R outlets ● Includes 20A circuit breaker and lighted power switch inside a transparent protective cover ● Toolless installation supported in button-mount compatible equipment racks ● Bolt-down installation brackets support installation in other racks and additional surfaces Specifications OVERVIEW UPC Code 037332182845 PDU Type Local Metered INPUT PDU Input Voltage 100; 120; 125; 127 Recommended Electrical Service Single-phase 20A 100-127V service Maximum Input Amps 16 Maximum Input Amps Details Agency de-rated to 16A continuous 1/3 ● PDUMV20-24 Local Metered Vertical PDU ● (1) L5-20P to 5-20P plug adapter ● Mounting hardware and spare mounting buttons ● Instruction manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States PDU Plug Type NEMA 5-20P; NEMA L5-20P Input Phase Single-Phase Input Cord Length (ft.) 15 Input Cord Length (m) 4.57 OUTPUT Output Capacity Details 2.03kW (127V), 1.92kW (120V), 1.6kW (100V) / 16A total capacity; 16A max per outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (6) 5-15/20R Output Nominal Voltage 100-127V Overload Protection 20A circuit breaker USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Digital meter reports PDU output current in amps Switches Lighted on/off switch with integrated transparent saftey cover SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Aluminum Form Factors Supported Vertical PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 2.20 x 6.20 x 26.50 Shipping Dimensions (hwd / cm) 5.59 x 15.75 x 67.31 Shipping Weight (lbs.) 6.30 Shipping Weight (kg) 2.86 Unit Dimensions (hwd / in.) 24.470 x 1.640 x 1.500 Unit Dimensions (hwd / cm) 62.2 x 4.2 x 3.81 Unit Weight (lbs.) 3.52 Unit Weight (kg) 1.60 ENVIRONMENTAL Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range -30°C to +50°C (-22°F to +122°F) Relative Humidity 5-95% non-condensing Operating Elevation (ft.) 0-10,000 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Elevation (m) 0-3000 STANDARDS & COMPLIANCE Product Certifications RETIE (Colombia); NOM (Mexico); UL 60950-1 Product Compliance RoHS; FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDUMV20-24 价格&库存
很抱歉,暂时无法提供与“PDUMV20-24”相匹配的价格&库存,您可以联系我们找货
