PDUMH20-6
PDUMH20-6
    TRIPPLITE
    PDUMETERED5-15/20R12OUTLET
PDUMH20-6 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2kW Single-Phase Local Metered PDU, 100-127V Outlets (12 5-15/20R), L5-20P/5-20P Input, 6 ft. (1.83 m) Cord, 1U Rack-Mount MODEL NUMBER: PDUMH20-6 Highlights ● Local metered single phase 16A 100-127V PDU ● 1U horizontal rackmount; Digital current meter ● NEMA 5-20P / L5-20P input; 6ft. (1.83 m) line cord ● 12 NEMA 5-15/20R outlets ● Reversible housing; 4.5 in. / 11.4 cm depth Package Includes Features ● 20A single phase 100-127V Local Metered Power Distribution Unit / PDU (Agency de-rated to 16A continuous) ● Built-in 2 digit visual meter continuously reports PDU load level in amps ● Attached NEMA L5-20P 20A 120V input plug with 6 ft. / 1.8m line cord ● Includes 5-20P 20A 120V plug adapter ● 1U horizontal rackmount format installs in one rack space ● 12 NEMA 5-15/20R outlets ● Mounting flanges support installation in 2 and 4 post racks, with additional support for wall-mount and under-counter installation formats ● Mounting ears are reversible for front or rear facing rackmount installation ● Optional PDUSIDEBRKT enables 0U vertical rackmount in compatible racks ● Back panel grounding lug Specifications OVERVIEW UPC Code 037332183255 PDU Type Local Metered INPUT PDU Input Voltage 100; 120; 125; 127 Recommended Electrical Service Single-phase 20A 100-127V service 1/3 ● PDUMH20 Local Metered rackmount PDU ● L5-20R to 5-20P plug adapter ● Owner's manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States Maximum Input Amps 16 Maximum Input Amps Details Agency de-rated to 16A continuous PDU Plug Type NEMA 5-20P; NEMA L5-20P Input Phase Single-Phase Input Cord Length (ft.) 6 Input Cord Length (m) 1.83 OUTPUT Output Capacity Details 2.03kW (127V), 1.92kW (120V), 1.6kW (100V) / 16A total capacity; 16A max per outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (12) 5-15/20R Output Nominal Voltage 100-127V Overload Protection 20A circuit breaker USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Digital display reports total PDU output current in amps SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported 1U rackmount, 0U vertical rackmount, wall-mount, and under-counter installation Minimum Required Rack Depth (cm) 22.35 Minimum Required Rack Depth (inches) 8.8 Outlets Measurement (Center to Center) 30.20mm PDU Form Factor Horizontal (1U) Shipping Dimensions (hwd / in.) 2.20 x 9.30 x 20.50 Shipping Dimensions (hwd / cm) 5.59 x 23.62 x 52.07 Shipping Weight (lbs.) 5.00 Shipping Weight (kg) 2.27 Unit Dimensions (hwd / in.) 1.750 x 17.300 x 3.750 Unit Dimensions (hwd / cm) 4.45 x 44.5 x 9.53 Unit Weight (lbs.) 4.6 Unit Weight (kg) 2.09 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States ENVIRONMENTAL Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range -30°C to +50°C (-22°F to +122°F) Relative Humidity 5-95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 FEATURES & SPECIFICATIONS TVSS Grounding Back panel grounding lug STANDARDS & COMPLIANCE Product Certifications RETIE (Colombia); NOM (Mexico); UL 60950-1 Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDUMH20-6 价格&库存
很抱歉,暂时无法提供与“PDUMH20-6”相匹配的价格&库存,您可以联系我们找货
