PDU1415
PDU1415
    TRIPPLITE
    POWER STRIP 14OUT 15'CORD 24"
PDU1415 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 1.8kW Single-Phase 120V Basic PDU, 14 NEMA 515R Outlets, NEMA 5-15P Input, 15 ft. (4.57 m) Cord, 0U Vertical MODEL NUMBER: PDU1415 Highlights ● NEMA 5-15P input with 15-ft. (4.57 m) cord ● 14 NEMA 5-15R outlets ● Switchless design prevents accidental shutdown ● 24 in. all-metal housing ● Supports toolless 0U vertical button-mounting Package Includes Delivers 120V single-phase AC power to multiple loads from a utility outlet, generator or UPS system in a high-density IT environment. Ideal for networking, telecom, security, audio/video and sound reinforcement applications. Description The PDU1415 1.8kW Single-Phase 120V Basic PDU is the perfect no-frills unit for networking, telecom, security, audio/video and sound reinforcement applications. Perfectly suited for high-density IT environments, the PDU1415 features a single breakered load bank with 14 NEMA 5-15R outlets. The NEMA 5-15P input plug with long 15-ft. (4.57 m) cord connects to your facility's compatible AC power source, generator or protected UPS to distribute power to connected equipment. The switchless design prevents an accidental shutdown, which could lead to costly downtime. A 15A circuit breaker protects connected equipment from dangerous overloads. The 24-inch all-metal housing supports toolless 0U vertical mounting in EIA-standard 19-inch racks, as well as on a wall or workbench or under a counter with user-supplied hardware. Features Reliable Single-Phase Power Distribution ● Ideal no-frills PDU for networking, telecom, security, audio/video and sound reinforcement applications ● 14 NEMA 5-15R outlets in one breakered load bank ● 15A circuit breaker protects outlets against overloads ● NEMA 5-15P input plug with 15-ft. (4.57 m) cord ● 24 in. all-metal housing Switchless Design ● Prevents accidental shutdowns and costly downtime Versatile Installation Options ● Supports toolless 0U vertical mounting in EIA-standard 19 in. racks ● Also mounts on wall, workbench or under a counter with user-supplied hardware 1/3 ● PDU1415 1.8kW Single-Phase 120V Basic PDU ● Mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332122247 PDU Type Basic INPUT PDU Input Voltage 120 Recommended Electrical Service Single-phase 15A 120V service Maximum Input Amps 15 PDU Plug Type NEMA 5-15P Input Phase Single-Phase Input Cord Length (ft.) 15 Input Cord Length (m) 4.57 OUTPUT Output Capacity Details 1.8kW (120V) total capacity; 12A max per 5-15R outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (14) 5-15R Output Nominal Voltage 120V Overload Protection 15A breaker USER INTERFACE, ALERTS & CONTROLS Switches No power switch SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported 0U vertical rackmount, wall-mount PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 2.40 x 5.60 x 28.30 Shipping Dimensions (hwd / cm) 6.10 x 14.22 x 71.88 Shipping Weight (lbs.) 5.30 Shipping Weight (kg) 2.40 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Dimensions (hwd / in.) 1.750 x 25.750 x 2.250 Unit Dimensions (hwd / cm) 4.45 x 61 x 4.34 Unit Weight (lbs.) 4.6 Unit Weight (kg) 2.09 ENVIRONMENTAL Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range -30°C to +50°C (-22°F to +122°F) Relative Humidity 5-95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 FEATURES & SPECIFICATIONS TVSS Grounding Grounding lug STANDARDS & COMPLIANCE Product Certifications RETIE (Colombia); CAN/CSA-C22.2 No. 60950-1 (Canada); NOM (Mexico); UL 60950-1 Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDU1415 价格&库存
很抱歉,暂时无法提供与“PDU1415”相匹配的价格&库存,您可以联系我们找货
