PDUMH20
PDUMH20
    TRIPPLITE
    PDU METERED 5-15/20R 12 OUTLET
PDUMH20 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2.4kW Single-Phase Local Metered PDU, 120V (12 5-15/20R), L5-20P / 5-20P, 120V Input, 15 ft. (4.57 m) Cord, 1U Rack-Mount MODEL NUMBER: PDUMH20 Highlights ● Local metered single phase 20A 120V PDU ● 1U horizontal rackmount; digital current meter ● NEMA 5-20P / L5-20P input; 15ft. (4.57 m) line cord ● 12 NEMA 5-15/20R outlets ● Reversible housing; 4.5 in. / 11.4cm depth Package Includes Features ● 20A single phase 120V Local Metered Power Distribution Unit / PDU ● Built-in 2 digit visual meter continuously reports PDU load level in amps ● Attached NEMA L5-20P 20A 120V input plug with 15-ft. (4.57 m) line cord ● Includes 5-20P 20A 120V plug adapter ● 1U horizontal rackmount format installs in one rack space ● 12 NEMA 5-15/20R outlets ● Mounting flanges support installation in 2 and 4 post racks, with additional support for wall-mount and under-counter installation formats ● Mounting ears are reversible for front or rear facing rackmount installation ● Optional PDUSIDEBRKT enables 0U vertical rackmount in compatible racks ● Back panel grounding lug Specifications OVERVIEW UPC Code 037332142504 PDU Type Local Metered INPUT PDU Input Voltage 120 Recommended Electrical Service Single-phase 20A 120V service 1/3 ● PDUMH20 Local Metered rackmount PDU ● L5-20R to 5-20P plug adapter ● Owner's manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States Maximum Input Amps 20 PDU Plug Type NEMA 5-20P; NEMA L5-20P Input Phase Single-Phase Input Cord Length (ft.) 15 Input Cord Length (m) 4.57 OUTPUT Output Capacity Details 2.4kW (120V) / 20A total capacity; 16A max per outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (12) 5-15/20R Output Nominal Voltage 120V Overload Protection 20A circuit breaker USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Digital display reports total PDU output current in amps SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported 1U rackmount, 0U vertical rackmount, wall-mount, and under-counter installation Minimum Required Rack Depth (cm) 24.13 Minimum Required Rack Depth (inches) 9.5 Outlets Measurement (Center to Center) 30.20mm PDU Form Factor Horizontal (1U) Shipping Dimensions (hwd / in.) 9.20 x 2.25 x 20.40 Shipping Dimensions (hwd / cm) 23.37 x 5.72 x 51.82 Shipping Weight (lbs.) 6.40 Shipping Weight (kg) 2.90 Unit Dimensions (hwd / in.) 2.000 x 20.000 x 4.500 Unit Dimensions (hwd / cm) 4.45 x 44.5 x 11.4 Unit Weight (lbs.) 3 Unit Weight (kg) 1.36 ENVIRONMENTAL 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range -30°C to +50°C (-22°F to +122°F) Relative Humidity 5-95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 FEATURES & SPECIFICATIONS TVSS Grounding Back panel grounding lug STANDARDS & COMPLIANCE Product Certifications RETIE (Colombia); NOM (Mexico); UL 60950-1 Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDUMH20 价格&库存
很抱歉,暂时无法提供与“PDUMH20”相匹配的价格&库存,您可以联系我们找货
