1000 Eaton Boulevard
Cleveland, OH 44122
United States
2.4kW Single-Phase 120V Basic PDU, 14 NEMA 515/20R Outlets, NEMA L5-20P Input, 15 ft. (4.57
m) Cord, 0U Vertical
MODEL NUMBER: PDU1420T
Highlights
NEMA L5-20P input with 15-ft.
(4.57 m) cord
14 NEMA 5-15/20R outlets
Switchless design prevents
accidental shutdown
24 in. all-metal housing
Supports toolless 0U vertical
button-mounting
Package Includes
Delivers 120V single-phase AC power to multiple loads from a utility outlet, generator or UPS system in a
high-density IT environment. Ideal for networking, telecom, security, audio/video and sound reinforcement
applications.
Description
The PDU1420T 2.4kW Single-Phase 120V Basic PDU is the perfect no-frills unit for networking, telecom,
security, audio/video and sound reinforcement applications. Perfectly suited for high-density IT
environments, the PDU1420T features a single breakered load bank with 14 NEMA 5-15/20R outlets. The
NEMA L5-20P input plug with long 15-ft. (4.57 m) cord connects to your facility's compatible AC power
source, generator or protected UPS to distribute power to connected equipment.
The switchless design prevents an accidental shutdown, which could lead to costly downtime. A 20A
circuit breaker protects connected equipment from dangerous overloads. The 24-inch all-metal housing
supports toolless 0U vertical mounting in EIA-standard 19-inch racks, as well as on a wall or workbench or
under a counter with user-supplied hardware.
Features
Reliable Single-Phase Power Distribution
● Ideal no-frills PDU for networking, telecom, security, audio/video and sound reinforcement applications
14 NEMA 5-15/20R outlets in one breakered load bank
20A circuit breaker protects outlets against overloads
NEMA L5-20P input plug with 15-ft. (4.57 m) cord
Switchless Design
● Prevents accidental shutdowns and costly downtime
Versatile Installation Options
● Supports toolless 0U vertical mounting in EIA-standard 19 in. racks
Also mounts on wall, workbench or under a counter with user-supplied hardware
1/3
120V Basic PDU
Mounting hardware
Owner’s manual
Cleveland, OH 44122
United States
Specifications
OVERVIEW
UPC Code
037332122254
PDU Type
Basic
INPUT
PDU Input Voltage
120
Recommended Electrical Service
Single-phase 20A 120V service
Maximum Input Amps
PDU Plug Type
NEMA L5-20P
Input Phase
Single-Phase
Input Cord Length (ft.)
15
Input Cord Length (m)
4.57
OUTPUT
Output Capacity Details
2.4kW (120V) / 24A total capacity; 16A max per 5-15/20R outlet
Frequency Compatibility
50 / 60 Hz
Output Receptacles
(14) 5-15/20R
Output Nominal Voltage
120V
Overload Protection
20A circuit breaker
USER INTERFACE, ALERTS & CONTROLS
Switches
No power switch
SURGE / NOISE SUPPRESSION
Automatic Shut-Off
No
PHYSICAL
Material of Construction
Metal
Form Factors Supported
Vertical or horizontal mounting supported in wallmount applications, racks and a variety of other surface types
PDU Form Factor
Vertical (0U)
Shipping Dimensions (hwd / in.)
27.70 x 2.40 x 5.80
Shipping Dimensions (hwd / cm)
70.36 x 6.10 x 14.73
Shipping Weight (lbs.)
6.60
Shipping Weight (kg)
2.99
2/3
Cleveland, OH 44122
United States
Unit Dimensions (hwd / in.)
1.750 x 25.750 x 2.250
Unit Dimensions (hwd / cm)
4.45 x 61 x 5.7
Unit Weight (lbs.)
5.6
Unit Weight (kg)
2.54
ENVIRONMENTAL
Operating Temperature Range
0C ~ 40C (32F ~ 104F)
Storage Temperature Range
-30°C to +50°C (-22°F to +122°F)
Relative Humidity
5-95% non-condensing
Operating Elevation (ft.)
0-10,000
Operating Elevation (m)
0-3000
FEATURES & SPECIFICATIONS
TVSS Grounding
Grounding lug
STANDARDS & COMPLIANCE
Product Certifications
RETIE (Colombia); CAN/CSA-C22.2 No. 60950-1 (Canada); NOM (Mexico); UL 60950-1
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“PDU1420T”相匹配的价格&库存,您可以联系我们找货
