AV2FP
AV2FP
    TRIPPLITE
    ISOBARSURGEW/COAX&NETWORK
AV2FP 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Isobar 2-Outlet Surge Protector Low-Profile Professional Audio/Video Power Conditioning Center, 10 ft. and 18 in. Cords, 5100 Joules MODEL NUMBER: AV2FP Highlights ● 2 NEMA 5-15R surge-protected outlets for HDTV and accessory ● Network-grade 5100-joule surge protection rating ● Durable metal housing mounts out of sight behind HDTV ● 12A resettable circuit breaker prevents dangerous overloads ● Detachable 10 ft. and 18 in. power cords with right-angle plugs Package Includes Premium protection for A/V home theater components, including HDTVs and stereo receivers, against dangerous power surges, spikes and line noise. Recommended for professional-grade home theater installations. Description Premium protection for your expensive home theater equipment, the AV2FP Isobar® 2-Outlet Low-Profile Professional Audio/Video Power Conditioning Center features a network-grade surge protection rating of 5100 joules to defend your sensitive electronics against even the strongest surges and spikes. In fact, Tripp Lite will repair or replace any connected equipment damaged by surges up to $100,000 for life (valid in the U.S., Canada and Puerto Rico only). The AV2FP features two NEMA 5-15R outlets, one for your flat-panel HDTV and one for an accessory, such as an audio receiver or Blu-ray™ player. This unit's unique protection system prevents disruptive line noise from causing A/V distortion, computer lock-ups, data errors and similar problems. Large toroidal chokes, ferrite rod-core inductors, HF/VHF capacitors and multiple layers of metal oxide varistors remove EMI/RFI interference and prevent system crashes, reboots and performance problems. Coaxial and RJ45 jacks also protect your incoming cable, satellite and Ethernet signals. Because residential power outlets have three wires—hot line (H), neutral (N) and ground (G)—the AV2FP protects all three, covering two protection modes: full normal mode (H-N) and common mode (N-G/H-G). An integrated 12A circuit breaker protects all outlets and shuts down connected equipment in the event of an overload. An on/off switch provides one-touch control over both outlets. Diagnostic LEDs confirm power, protection and ground status at a glance. Detachable 10-foot and 18-inch AC power cords include right-angle NEMA 5-15P plugs, allowing furniture to be placed flush against the wall. Features Network-Grade 5100-Joule Surge Protection for Your Home Theater ElectronicsProtects your A/V components against even the strongest surges and spikesFull normal mode (H-N) and common mode (NG/H-G) line surge suppression2 NEMA 5-15R surge-protected outlets for HDTV and accessoryBidirectional coaxial and RJ45 jacks protect cable, satellite and Ethernet signals Premium Safety FeaturesOn/off switch provides one-touch control over connected equipmentAutomatic shutoff permanently cuts power to outlets if protection circuit is incapacitated, preventing equipment damage and indicating replacement is requiredDiagnostic LEDs confirm power, protection and ground status at a glanceAudible alarm alerts you to damaged internal protection circuitryConforms to current UL 1449 and 962A safety standards Fits Effortlessly Into Your SetupDetachable 10 ft. (3.1 m) and 18 in. AC power cords provide flexibility in 1/4 ● AV2FP Isobar 2-Outlet LowProfile Professional Audio/Video Power Conditioning Center ● Detachable power cord with C13 connector, 10 ft. ● Detachable power cord with C13 connector, 18 in. ● Built-in mounting brackets ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States placementSpace-saving right-angle NEMA 5-15P plugs allows furniture and equipment to move flush against the wallBuilt-in mounting brackets allow for secure installation on wall behind HDTVMetal housing designed for long life Backed by Tripp Lite's Ultimate Lifetime Insurance$100,000 Ultimate Lifetime Insurance covers any connected components damaged by power surge (U.S., Canada and Puerto Rico only) Specifications OVERVIEW UPC Code 037332125071 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 120V (110-125V) Input Cord Gauge Type 14 gauge; SJT Input Cord Gauge (AWG) 14 Voltage Compatibility (VAC) 120 Maximum Surge Amps 255000 Input Plug Type NEMA 5-15P Input Cord Details SJT Input Cord Length (ft.) 10 Right-Angle Plug Yes Input Cord Length (m) 3.05 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output Receptacles (2) 5-15R Circuit Breaker (amps) 12 Overload Protection 12-amp circuit breaker Right-Angle Outlets No USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) Yes Switches Circuit breaker Audible Alarm Audible alarm Diagnostic LED Details 3 (protection, grounding, power) 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 5100 AC Suppression Response Time NM = instantaneous CM = < 1 ns Safe Thermal Fusing yes UL1449 Let Through Rating 330V - UL verified EMI / RFI Filtering Yes Automatic Shut-Off Yes DATALINE SURGE SUPPRESSION Cable (Coax) Protection Yes Network (Ethernet) Protection Yes Telephone/DSL Protection No PHYSICAL Material of Construction Metal Power Cord Color Black Housing Color Black Included Mounting Accessories Built-in mounting brackets Mounting Holes or Slots No Slot or Hole Mount Measurement (Center to Center) 220.49 mm Outlets Measurement (Center to Center) 45mm Receptacle Color Black Shipping Dimensions (hwd / in.) 9.80 x 2.40 x 10.00 Shipping Dimensions (hwd / cm) 24.89 x 6.10 x 25.40 Shipping Weight (lbs.) 3.20 Shipping Weight (kg) 1.45 Unit Dimensions (hwd / in.) 1.500 x 4.500 x 9.250 Unit Weight (lbs.) 1.65 Unit Weight (kg) 0.75 COMMUNICATIONS Network Compatibility 100 Mbps (Fast Ethernet) FEATURES & SPECIFICATIONS Rotatable Outlets No 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Antimicrobial No STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 107.3 (Canada); UL 1449; UL 1778; UL 962A Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $100,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
AV2FP 价格&库存
很抱歉,暂时无法提供与“AV2FP”相匹配的价格&库存,您可以联系我们找货
