1000 Eaton Boulevard
Cleveland, OH 44122
United States
Isobar 8-Outlet Professional Audio/Video Power
Conditioning Center, 10 ft. Cord with Right-Angle
Plug, 5700 Joules, LCD, 1U
MODEL NUMBER: AV3500PC
Highlights
8 NEMA 5-15R surge-protected
outlets (7 rear, 1 front)
Network-grade 5700-joule surge
protection rating
Durable metal housing supports
standard 1U rack mounting
12A resettable circuit breaker
prevents dangerous overloads
10 ft. power cord with spacesaving right-angle NEMA 5-15P
plug
Package Includes
Ultimate protection for A/V home theater components, including HDTVs and stereo receivers, against
dangerous power surges, spikes and line noise. Recommended for professional-grade home theater
installations.
Description
Premium protection for your expensive home theater equipment, the AV3500PC Isobar® 8-Outlet
Professional Audio/Video Power Conditioning Center features a network-grade surge protection rating of
5700 joules to defend your sensitive electronics against even the strongest surges and spikes. In fact,
Tripp Lite will repair or replace any connected equipment damaged by surges up to $100,000 for life (valid
in the U.S., Canada and Puerto Rico only).
Your devices, including HDTVs, Blu-ray players, receivers, amplifiers, DVRs and video game systems,
plug into eight NEMA 5-15R outlets—seven rear and one front—which are arranged in two exclusive
isolated filter banks. These banks prevent disruptive line noise from causing A/V distortion, computer lockups, data errors and similar problems. Large toroidal chokes, ferrite rod-core inductors, HF/VHF
capacitors and multiple layers of metal oxide varistors remove EMI/RFI interference and prevent system
crashes, reboots and performance problems. Coaxial and RJ11 jacks also protect your incoming cable,
satellite and telephone signals.
Because residential power outlets have three wires—hot line (H), neutral (N) and ground (G)—the
AV3500PC protects all three, covering two protection modes: full normal mode (H-N) and common mode
(N-G/H-G).
An integrated 12A circuit breaker protects all outlets and shuts down connected equipment in the event of
an overload. A lighted on/off switch provides one-touch control over all outlets. Diagnostic LED shows
power, protection and ground status, and an LCD meter displays input voltage at a glance. A 10-foot AC
power cord with right-angle 5-15P plug reaches nearby outlets and allows furniture to be placed flush
against the wall.
Features
Network-Grade 5700-Joule Surge Protection for Your Home Theater ElectronicsProtects your A/V
components against even the strongest surges and spikesFull normal mode (H-N) and common mode (NG/H-G) line surge suppression8 NEMA 5-15R surge-protected outlets (7 rear, 1 front)3 sets of bidirectional coaxial and 1 set of RJ11 jacks protect cable, satellite and telephone/DSL signals
1/4
AV3500PC Isobar 8-Outlet
Conditioning Center
Rack-mounting hardware
Owner’s manual
Cleveland, OH 44122
United States
Premium Safety FeaturesLighted on/off switch provides one-touch control over connected
equipmentAutomatic shutoff permanently cuts power to outlets if protection circuit is incapacitated,
preventing equipment damage and indicating replacement is requiredDiagnostic LEDs confirm power,
protection and ground statusLCD meter with dimmer control displays input voltage at a glanceAudible
alarm alerts you to damaged internal protection circuitryConforms to current UL 1449 and 962A safety
standards
Fits Effortlessly Into Your Setup10 ft. AC power cord reaches nearby outletsSpace-saving right-angle
NEMA 5-15P plug allows furniture and equipment to move flush against the wallMetal housing mounts
easily in 1U of space in EIA-standard 19 in. racksSupports shelf installation as console component
Backed by Tripp Lite’s Ultimate Lifetime Insurance$100,000 Ultimate Lifetime Insurance covers any
connected components damaged by power surge (U.S., Canada and Puerto Rico only)
Specifications
OVERVIEW
UPC Code
037332149091
INPUT
Nominal Input Voltage(s) Supported
120V AC
Recommended Electrical Service
120V (110-125V)
Input Cord Gauge Type
14 gauge; SJT
Voltage Compatibility (VAC)
120
Maximum Surge Amps
225000
Input Plug Type
NEMA 5-15P
Input Cord Length (ft.)
10
Right-Angle Plug
Yes
Input Cord Length (m)
3.05
Integrated Cord Clip
No
OUTPUT
Frequency Compatibility
50 / 60 Hz
Output Receptacles
(8) 5-15R
Circuit Breaker (amps)
12
Right-Angle Outlets
No
USER INTERFACE, ALERTS & CONTROLS
Diagnostic LED(s)
Yes
Front Panel LCD Display
Input Voltage LCD meter displays the in-coming utility power with dimmer control. Alerts user to input voltage levels
Switches
Combination AC circuit breaker and illuminated on/off power switch
Audible Alarm
Audible alarm
2/4
Cleveland, OH 44122
United States
Diagnostic LED Details
report 4 operational conditions (protection, grounding, power, switched status)
SURGE / NOISE SUPPRESSION
AC Suppression Joule Rating
5700
AC Suppression Response Time
NM = instantaneous CM = < 1 ns
Protection Modes
Includes full normal mode (H-N) and common mode (N-G / H-G) line surge suppression
Safe Thermal Fusing
Yes
UL1449 Let Through Rating
330V - UL verified
EMI / RFI Filtering
Yes
Isolated Filter Banks
2
Automatic Shut-Off
Yes
DATALINE SURGE SUPPRESSION
Telephone/DSL Protection Details
1 line
Cable (Coax) Protection
Yes
Cable (Coax) Protection Details
3 line
Network (Ethernet) Protection
No
Yes
PHYSICAL
Color
Black
Power Cord Color
Black
Included Mounting Accessories
Rackmount hardware
Mounting Holes or Slots
No
Outlets Measurement (Center to
Center)
42mm
Receptacle Color
Black
Shipping Dimensions (hwd / in.)
3.00 x 22.50 x 16.00
Shipping Dimensions (hwd / cm)
7.62 x 57.15 x 40.64
Shipping Weight (lbs.)
11.75
Shipping Weight (kg)
5.33
Unit Dimensions (hwd / in.)
1.750 x 17.500 x 11.750
Unit Dimensions (hwd / cm)
4.445 x 44.45 x 37.46
Unit Weight (lbs.)
5.5
Unit Weight (kg)
2.49
FEATURES & SPECIFICATIONS
3/4
Cleveland, OH 44122
United States
Rotatable Outlets
No
Antimicrobial
No
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“AV3500PC”相匹配的价格&库存,您可以联系我们找货
