1000 Eaton Boulevard
Cleveland, OH 44122
United States
1.5kW Single-Phase Hot-Swap PDU, 100-127V
15A Outlets (8 5-15R), 2 5-15P, 10 ft. (3.05 m) & 6
ft. (1.83 m) Cords 2U Rack-Mount
Highlights
Single phase 12A 100-127V
Hot-swap PDU
Enables live replacement of a
standard UPS with zero
downtime
2U horizontal rackmount
installation
Compatible with any 100-127V
UPS with a 5-15P input plug
Manual transfer switch controls
PDU input power source
Pair of 5-15P input cables
connect to separate Utility and
UPS inputs
8 Built-in 5-15R outlets
MODEL NUMBER: PDUB15
Package Includes
Features
Tripp Lite Hot-swap PDU systems support live-replacement of standard UPS systems for maintenance
with no interruption of connected server or networking loads
PDUB15 is universally compatible with any Tripp Lite or other brand of 100-127V UPS rated up to
1500VA or 1440 watts with a NEMA 5-15P input cable
2U horizontal rackmount form factor compatible with 2 or 4 post racks
Supports space saving rear-post mounting in the same rack space as many Tripp Lite Rackmount UPS
systems (select installations, see manual)
Pair of attached 5-15P PDU input cables connect to separate Utility and UPS power sources
8 high quality 5-15R outlets support critical networking loads in both Utility and UPS operating modes
One additional 5-15R pass-through outlet supports UPS input power cord
Dual input power cables support PDU connection to separate Utility and UPS power sources
Manual transfer switch with lighted status indicators controls the source of power to connected
equipment between Utility and UPS
Set the switch to UPS during normal operation and connected equipment will receive full-time
conditioned power from the UPS
Set the switch to Utility to bypass the UPS and provide connected equipment with unfiltered power
directly from the Utility line cord while the UPS system is removed and replaced with a fresh one
Once the new UPS is up and running with all connections restored, set the switch back to the UPS
setting to once again provide fully-conditioned UPS power to connected equipment
Specifications
OVERVIEW
UPC Code
037332153876
1/3
Hot-swap PDU System
2U mounting brackets
User manual with warranty
information
Cleveland, OH 44122
United States
PDU Type
Hot-Swap
INPUT
PDU Input Voltage
100; 120; 125; 127
Recommended Electrical Service
Works with most 120V UPS systems up to 1500VA
Maximum Input Amps
12
Maximum Input Amps Details
Agency de-rated to 12A continuous
PDU Plug Type
NEMA 5-15P
Input Phase
Single-Phase
Input Cord Details
Utility input cable (10 ft / 3m) / UPS input cable (6 ft / 1.8m)
Input Cord Length (ft.)
10
Input Cord Length (m)
3.05
OUTPUT
Output Capacity (Watts)
1440
Output Capacity Details
1.52kW (127V), 1.44kW (120V), 1.2kW (100V) / 15A total capacity (Agency de-rated to 12A); 12A max per 5-15R
outlet
Frequency Compatibility
50 / 60 Hz
Output Receptacles
(8) 5-15R
Output Nominal Voltage
100-127V
USER INTERFACE, ALERTS & CONTROLS
Front Panel LEDs
Lighted indicators confirm UPS and Utility switch position and operating mode
Switches
Manual 2 position transfer switch offers fast switching between UPS and Utility operating modes in less than 6
milliseconds
SURGE / NOISE SUPPRESSION
Automatic Shut-Off
No
PHYSICAL
Material of Construction
Metal
Form Factors Supported
2U rackmount in 2 or 4 post racks
PDU Form Factor
Horizontal (2U)
Shipping Dimensions (hwd / in.)
12.30 x 6.20 x 20.00
Shipping Dimensions (hwd / cm)
31.24 x 15.75 x 50.80
Shipping Weight (lbs.)
8.90
Shipping Weight (kg)
4.04
Unit Dimensions (hwd / in.)
3.420 x 17.320 x 3.030
2/3
Cleveland, OH 44122
United States
Unit Dimensions (hwd / cm)
8.7 x 44 x 7.7
Unit Weight (lbs.)
7.70
Unit Weight (kg)
3.49
ENVIRONMENTAL
Operating Temperature Range
0C ~ 40C (32F ~ 104F)
Storage Temperature Range
-30°C to +50°C (-22°F to +122°F)
Relative Humidity
5-95% non condensing
Operating Elevation (ft.)
0-10,000
Operating Elevation (m)
0-3000
FEATURES & SPECIFICATIONS
High Availability PDU Features
Manual Hot-Swap Bypass
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); NOM (Mexico); UL 60950-1
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“PDUB15”相匹配的价格&库存,您可以联系我们找货
