PDUMV20HV
PDUMV20HV
    TRIPPLITE
    PDU METERED 208V-240V 20A 6 C19
PDUMV20HV 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 3.7kW Single-Phase Local Metered PDU, 208/230V Outlets (6-C19 & 32-C13 ) C20/L6-20P Cable 10 ft. (3.05 m) Cord, 0U Vertical Highlights ● Local metered single phase 16A 208/230V 0U 63.75in / 162cm vertical rackmount PDU ● Two-digit meter reports output current in amps ● 10ft / 3m detachable input cable with NEMA L6-20P plug ● C20 inlet accepts a variety of 16A international cordsets ● 38 output receptacles (6 C19, 32 C13) ● Ready for immediate toolless 0U installation MODEL NUMBER: PDUMV20HV Package Includes Features ● 16/20A single phase 230/208V Local Metered Power Distribution Unit / PDU (Agency derated to 16A continuous) ● Two-digit lighted meter reports combined total output current in amps ● 10ft / 3m detachable input cable with NEMA L6-20P plug ● C20 inlet accepts a variety of 16A international cordsets ● 0U 63.75in / 162cm vertical rackmount format installs using no rack spaces ● 38 total outlets (6 C19, 32 C13) ● Included plug-lock inserts ensure components remain connected and powered ● Toolless installation supported in button-mount compatible equipment racks ● Bolt-down installation brackets support installation in other racks and additional surfaces Specifications OVERVIEW UPC Code 037332139344 PDU Type Local Metered INPUT PDU Input Voltage 208; 230 Recommended Electrical Service Single-phase 16/20A 230/208V service Maximum Input Amps 16 1/3 ● PDUMV20HV 63.75 inch basic PDU ● Plug-lock inserts (6 C20, 32 C13) ● Spare installation buttons, 2.9 mm/4.6 mm ● 10-ft. (3.05 m) detachable C19to-L620P input cordset ● Mounting hardware ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Maximum Input Amps Details Agency de-rated to 16A continuous Input Connection Type L6-20P detachable cordset, C20 inlet available PDU Plug Type NEMA L6-20P; IEC-320 C20 Input Phase Single-Phase Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 OUTPUT Output Capacity Details 3.68kW (230V), 3.33kW (208V) / 16A total capacity; 16A max per C19 outlet; 12A (10A CE) max per C13 outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (32) C13; (6) C19 Output Nominal Voltage 208/230V USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Digital meter reports PDU output current in amps SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Aluminum Form Factors Supported 0u vertical installation in equipment racks, plus under-counter and wallmount PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 5.00 x 3.50 x 65.50 Shipping Dimensions (hwd / cm) 12.70 x 8.89 x 166.37 Shipping Weight (lbs.) 9.50 Shipping Weight (kg) 4.31 Unit Dimensions (hwd / in.) 3.750 x 2.250 x 63.750 Unit Dimensions (hwd / cm) 162 x 5.7 x 9.5 Unit Weight (lbs.) 5.20 Unit Weight (kg) 2.36 ENVIRONMENTAL Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range -30°C to +50°C (-22°F to +122°F) Relative Humidity 0-95% non-condensing Operating Elevation (ft.) 0-10,000 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Elevation (m) 0-3000 STANDARDS & COMPLIANCE Product Certifications IEC 62368-1; RETIE (Colombia); GOST (Russia); NOM (Mexico) Product Compliance RoHS; CE (Europe); EAC (Belarus, Kazakhstan, Russia); UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDUMV20HV 价格&库存
很抱歉,暂时无法提供与“PDUMV20HV”相匹配的价格&库存,您可以联系我们找货
PDUMV20HV
库存:7
