PDU40TDUAL
PDU40TDUAL
    TRIPPLITE
    POWER STRIP 40OUT 10'CORDS 65"
PDU40TDUAL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 3.8kW Single-Phase Dual-Circuit 120V Basic PDU, 40 NEMA 5-15/20R Outlets, NEMA L5-20P/520P Inputs, 10 ft. (3.05 m) Cords, 0U MODEL NUMBER: PDU40TDUAL Highlights ● Functions as 2 independent 16A PDUs in one housing ● Dual NEMA L5-20P/5-20P inputs with 10-ft. (3.05 m) cords ● 40 NEMA 5-15/20R outlets in 2 separate circuits ● Switchless design prevents accidental shutdown ● Supports toolless 0U vertical button-mounting Package Includes Dual-circuit PDU ideal for delivering 120V single-phase AC power to servers and networking equipment with dual redundant power supplies or any application that requires high capacity in a compact form factor. Description The PDU40TDUAL 3.8kW Single-Phase Dual-Circuit 120V Basic PDU works as two independent PDUs in a single housing, perfect for networking, telecom, security, audio/video and sound reinforcement applications. Ideal for high-density network equipment with dual redundant input cables, it features 40 NEMA 5-15/20R outlets split evenly into two separate power circuits. Each power circuit, including its input plug, power cord, breaker and outlets, is color-coded black or gray for easy identification. Both 10-ft. (3.05 m) power cords feature NEMA L5-20P input plugs and come with optional adapters to convert them to NEMA 5-20P plugs, which are not color-coded. Connect the plugs to separate mains input power sources, generators or protected UPS systems to distribute AC power to connected equipment. The switchless design prevents an accidental shutdown, which could lead to costly downtime. Dual 20A circuit breakers protect connected equipment from dangerous overloads. The 70-inch all-metal housing supports toolless 0U vertical mounting in EIA-standard 19-inch racks, as well as on a wall or workbench or under a counter with user-supplied hardware. Features Dual Single-Phase PDUs in a Single Housing ● Ideal for high-density network equipment with dual redundant input cables ● 40 NEMA 5-15/20R outlets in 2 breakered power circuits ● 70 in. all-metal housing Dual Input Connectors ● NEMA L5-20P input plugs with 10-ft. (3.05 m) cords ● Included adapters convert plugs to NEMA 5-20P, if desired ● Plugs connect to separate external AC power sources Dual Independent Power Circuits 1/3 ● PDU40TDUAL 3.8kW SinglePhase Dual-Circuit 120V Basic PDU ● (2) NEMA L5-20P to NEMA 520P Plug Set Adapters ● Mounting Hardware ● Owner’s Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Circuits include input plug, power cord, circuit breaker and outlets ● Color-coded black or gray for easy identification ● 20A circuit breakers protect outlets against overloads Switchless Design ● Prevents accidental shutdowns and costly downtime Versatile Installation Options ● Supports toolless 0U vertical mounting in EIA-standard 19 in. racks ● Also mounts on wall, workbench or under a counter with user-supplied hardware Specifications OVERVIEW UPC Code 037332128409 PDU Type Basic INPUT PDU Input Voltage 120 Recommended Electrical Service Two single-phase 20A 120V circuits Maximum Input Amps 16 Maximum Input Amps Details 20A maximum per circuit (Agency de-rated to 16A per circuit continuous) PDU Plug Type NEMA 5-20P; NEMA L5-20P Input Phase Single-Phase Input Cord Details Set of two input power cords; Grey-color input cord powers grey-color outlets; Black-color input cord powers blackcolor outlets Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 OUTPUT Output Capacity Details 3.8kW total - 1.9kW per circuit (120V); 32A maximum total (16A maximum per circuit); 16A max per 5-15/20R outlet Frequency Compatibility 50 / 60 Hz Output Receptacle Details 20 grey-color outlets are powered via the grey-color input cable; 20 black-color outlets are powered via the blackcolor input cable Output Receptacles (40) 5-15/20R Output Nominal Voltage 120V Overload Protection 2 x 20A circuit breakers; Grey-color circuit breaker protects grey-color outlets; Black-color circuit breaker protects black-color outlets SURGE / NOISE SUPPRESSION 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Automatic Shut-Off No PHYSICAL Material of Construction Aluminum Form Factors Supported Zero U vertical rackmount, wallmount, raceway, workbench and more PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 2.40 x 4.80 x 72.44 Shipping Dimensions (hwd / cm) 6.10 x 12.19 x 184.00 Shipping Weight (lbs.) 9.31 Shipping Weight (kg) 4.22 Unit Dimensions (hwd / in.) 70.240 x 1.500 x 3.340 Unit Dimensions (hwd / cm) 178.41 x 3.81 x 8.48 Unit Weight (lbs.) 8.16 Unit Weight (kg) 3.70 ENVIRONMENTAL Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range -30°C to +50°C (-22°F to +122°F) Relative Humidity 5-95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 60950-1 (Canada); NOM (Mexico); UL 60950-1 Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDU40TDUAL 价格&库存
很抱歉,暂时无法提供与“PDU40TDUAL”相匹配的价格&库存,您可以联系我们找货
