PDUMH30
PDUMH30
    TRIPPLITE
    PDU METERED 5-15/20R 12 OUTLET
PDUMH30 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2.9kW Single-Phase Local Metered PDU, 120V Outlets (12 5-15/20R), L5-30P, 15 ft. (4.57 m) Cord, 1U Rack-Mount Highlights ● Local Metered single phase 24A 120V 1U horizontal rackmount PDU ● Two-digit current meter reports total PDU input current in amps ● Attached 15-ft. (4.57 m) cord with NEMA L5-30P input plug ● 12 NEMA 5-15/20R outlets ● Reversible housing, 6.5 in. / 16.5cm depth MODEL NUMBER: PDUMH30 Package Includes Features ● 30A single phase 120V Local Metered Power Distribution Unit / PDU (Agency derated to 24A continuous) ● Two-digit lighted meter reports total PDU input current in amps ● Attached L5-30P 30A 120V input plug with 15-ft. (4.57 m) line cord ● 1U horizontal rackmount format installs in one rack space ● 12 NEMA 5-15/20R outlets ● Outlets are arranged in two loading banks, each with separate 20A breaker protection ● Mounting flanges support installation in 2 and 4 post racks, with additional support for wall-mount and under-counter installation formats ● Mounting ears are reversible for front or rear facing rackmount installation ● Back panel grounding lug Specifications OVERVIEW UPC Code 037332157676 PDU Type Local Metered INPUT PDU Input Voltage 120 Recommended Electrical Service Single-phase 30A 120V service Maximum Input Amps 24 1/3 ● PDUMH30 Local Metered rackmount PDU ● Owner's manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States Maximum Input Amps Details Agency de-rated to 24A continuous PDU Plug Type NEMA L5-30P Input Phase Single-Phase Input Cord Length (ft.) 15 Input Cord Length (m) 4.57 OUTPUT Output Capacity Details 2.88kW (120V) / 24A total capacity; 20A max per breakered load bank; 16A max per outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (12) 5-15/20R Output Nominal Voltage 120V Overload Protection Two 20A breakers protect 6 outlets each USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Two digit current meter reports PDU input current in amps SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported 1U rackmount, 0U vertical rackmount, wall-mount, and under-counter installation Minimum Required Rack Depth (cm) 29.21 Minimum Required Rack Depth (inches) 11.5 Outlets Measurement (Center to Center) Distance between outlets = 30.20mm; Distance between Bank 1 and Bank 2 = 41.45mm PDU Form Factor Horizontal (1U) Shipping Dimensions (hwd / in.) 11.00 x 3.20 x 20.20 Shipping Dimensions (hwd / cm) 27.94 x 8.13 x 51.31 Shipping Weight (lbs.) 6.10 Shipping Weight (kg) 2.77 Unit Dimensions (hwd / in.) 1.750 x 17.500 x 6.500 Unit Dimensions (hwd / cm) 4.45 x 44.5 x 16.5 Unit Weight (lbs.) 7 Unit Weight (kg) 3.18 ENVIRONMENTAL 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range -30°C to +50°C (-22°F to +122°F) Relative Humidity 5-95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 FEATURES & SPECIFICATIONS TVSS Grounding Rear grounding lug STANDARDS & COMPLIANCE Product Certifications RETIE (Colombia); NOM (Mexico); UL 60950-1 Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDUMH30 价格&库存
很抱歉,暂时无法提供与“PDUMH30”相匹配的价格&库存,您可以联系我们找货
