PDUMNH15
PDUMNH15
    TRIPPLITE
    PDU MONITORED 5-15R 8 OUTLET
PDUMNH15 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 1.4kW Single-Phase Monitored PDU with LX Platform Interface, 120V Outlets (8 5-15R), 5-15P, 12 ft. (3.66 m) Cord, 1U Rack-Mount, TAA MODEL NUMBER: PDUMNH15 Highlights ● Monitored 12A 120V PDU, 1U horizontal rackmount format ● Reports voltage, frequency & load level via ethernet interface ● Visual current meter, Reversible housing ● NEMA 5-15P input with attached 12-ft. (3.66 m) line cord ● 8 NEMA 5-15R outlets with included cord retention brackets ● Pre-installed WEBCARDLX with latest version of PADM20 for enhanced remote management Package Includes Features ● 15A single phase 120V Monitored Power Distribution Unit / PDU (agency derated to 12A continuous) ● Attached NEMA 5-15P input plug with 12-ft. (3.66 m) line cord ● 1U horizontal rackmount installation format supports installation in 2 or 4 post equipment racks ● 8 NEMA 5-15R outlets ● Lighted display reports output power consumption in amps ● Pre-installed WEBCARDLX with the latest version of PowerAlert Device Manager firmware (PADM20) provides enhanced remote management capabilities ● PADM20 and PowerAlert Element Manager (PAEM) form a powerful tool for expanding maintenance functions in large installations, including firmware update checks and backup and restoration of device configurations ● Mounting flanges support installation in 2 and 4 post racks, with additional support for wall-mount and under-counter installation formats ● Mounting ears are reversible for front or rear facing rackmount installation ● Included cord retention brackets keep vital network equipment plugged in and continuously powered ● TAA Compliant Specifications OVERVIEW UPC Code 037332152022 PDU Type Monitored INPUT 1/3 ● Rackmount PDU ● Rack mounting brackets ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States PDU Input Voltage 120 Recommended Electrical Service Single-phase 15A 120V service Maximum Input Amps 12 Maximum Input Amps Details Agency de-rated to 12A continuous PDU Plug Type NEMA 5-15P Input Phase Single-Phase Input Cord Length (ft.) 12 Input Cord Length (m) 3.66 OUTPUT Output Capacity Details 1.44kW (120V) / 12A total capacity; 12A max per outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (8) 5-15R Output Nominal Voltage 120V USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Digital meter reports PDU output current in amps SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported 1U horizontal rackmount in 2 or 4 post racks Minimum Required Rack Depth (cm) 23.37 Minimum Required Rack Depth (inches) 9.2 PDU Form Factor Horizontal (1U) Shipping Dimensions (hwd / in.) 2.09 x 11.00 x 20.50 Shipping Dimensions (hwd / cm) 5.31 x 27.94 x 52.07 Shipping Weight (lbs.) 7.00 Shipping Weight (kg) 3.18 Unit Dimensions (hwd / in.) 1.700 x 17.300 x 6.200 Unit Dimensions (hwd / cm) 4.3 x 43.9 x 15.7 Unit Weight (lbs.) 6.5 Unit Weight (kg) 2.95 ENVIRONMENTAL 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range -30°C to +50°C (-22°F to +122°F) Relative Humidity 5-95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 COMMUNICATIONS PowerAlert Software LX Platform Interface: PowerAlert Device Manager Communications Cable Micro-USB- to-USB A configuration/console Access cable Network Monitoring Port RJ45 Network port, Micro-USB Configuration port, USB A port supports a variety of Envirosense2 environmental and control modules. See Accessories>Management Hardware section for more information about these modules. SNMP Compatibility Pre-installed LX platform interface provides remote monitoring via Java-free HTML5 web interface, telnet, SSH and SNMP management systems Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet) FEATURES & SPECIFICATIONS High Availability PDU Features Remote Network Notifications STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 60950-1 (Canada); NOM (Mexico); UL 60950-1 Product Compliance RoHS; FCC Part 15 Class A (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDUMNH15 价格&库存
很抱歉,暂时无法提供与“PDUMNH15”相匹配的价格&库存,您可以联系我们找货
