PDUMH32HV
PDUMH32HV
    TRIPPLITE
    PDU METERED 230V 32A 7.3KW
PDUMH32HV 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 7.4kW Single-Phase Local Metered PDU, 230V Outlets (2-C19, 16-C13), IEC-309 230V 32A Blue, 12 ft. (3.66 m) Cord, 2U Rack-Mount, TAA Highlights ● Local Metered single phase 32A 230V 2U horizontal rackmount PDU ● Set of 2 current meters reports current in amps for each output load bank ● Attached 12-ft. (3.66 m) cord with IEC-309 32A (2P+E) input plug ● 18 total 230V outlets (2 C19, 16 C13) ● Reversible housing, 12.5 in. / 31.75cm depth ● TAA Compliant MODEL NUMBER: PDUMH32HV Package Includes Features ● 32A single phase 230V Local Metered Power Distribution Unit / PDU ● Set of two lighted current meters separately report power consumption in amps for each output load bank ● Attached IEC-309 32A (2P+E) input plug with 12-ft. (3.66 m) line cord ● 2U horizontal rackmount format installs in two rack spaces ● 18 total 230V outlets (2 C19, 16 C13) ● Outlets are arranged in two separately breakered and local metered 16A load banks (each with 8 C13 and 1 C19 outlet) ● Mounting flanges support installation in 2 and 4 post racks, with additional support for wall-mount and under-counter installation formats ● Mounting ears are reversible for front or rear facing rackmount installation ● Front-panel grounding lug ● Included cord retention brackets Specifications OVERVIEW UPC Code 037332159045 PDU Type Local Metered INPUT PDU Input Voltage 230 1/3 ● 2U local metered PDU ● Mounting brackets ● Plug retention brackets ● User manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Recommended Electrical Service Single-phase 32A 230V service Maximum Input Amps 32 PDU Plug Type IEC-309 32A BLUE (2P+E) Input Phase Single-Phase Input Cord Length (ft.) 12 Input Cord Length (m) 3.66 OUTPUT Output Capacity Details 7.4kW (230V) / 32A total capacity / 16A max per breakered outlet bank; 16A max per C19 outlet; 10A max per C13 outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (16) C13; (2) C19 Output Nominal Voltage 230V Overload Protection Two 20A circuit breakers protect 9 outlets each USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Set of 2 digital meters continuously report output current for breakered load bank; Bank 1 (Upper row of 9 outlets), Bank 2 (Lower row of 9 outlets) SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported 2U rackmount Minimum Required Rack Depth (cm) 40.64 Minimum Required Rack Depth (inches) 16 PDU Form Factor Horizontal (2U) Shipping Dimensions (hwd / in.) 7.80 x 16.80 x 19.30 Shipping Dimensions (hwd / cm) 19.81 x 42.67 x 49.02 Shipping Weight (lbs.) 14.70 Shipping Weight (kg) 6.67 Unit Dimensions (hwd / in.) 3.500 x 17.500 x 12.500 Unit Dimensions (hwd / cm) 8.9 x 44.5 x 31.75 Unit Weight (lbs.) 13.7 Unit Weight (kg) 6.21 ENVIRONMENTAL 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range -30°C to +50°C (-22°F to +122°F) Relative Humidity 5-95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 STANDARDS & COMPLIANCE Product Certifications IEC 62368-1; GOST (Russia); UL 62368-1 Product Compliance RoHS; CE (Europe); EAC (Belarus, Kazakhstan, Russia); FCC Part 15 Class A (USA); UKCA; Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDUMH32HV 价格&库存
很抱歉,暂时无法提供与“PDUMH32HV”相匹配的价格&库存,您可以联系我们找货
