PDUMNH20HV
PDUMNH20HV
    TRIPPLITE
    PDU MONITORED 20A C13 8 OUTLET
PDUMNH20HV 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 3.7kW Single-Phase 208/230V Monitored PDU LX Platform, 8 C13 Outlets, C20 Input with L620P Adapter, 2.4m Cord, 1U Rack-Mount MODEL NUMBER: PDUMNH20HV Highlights ● Monitored 16A 208/230V PDU, 1U horizontal rackmount ● Reports voltage, frequency & load level via ethernet interface ● Visual current meter, Reversible housing ● C20 inlet; 8ft / 2.4m C20 cable with L6-20P plug adapter ● 8 C13 outlets with included pluglock retention sleeves ● Pre-installed WEBCARDLX with latest version of PADM20 for enhanced remote management ● TAA Compliant for GSA Schedule purchases Package Includes Features ● 16/20A 230/208V Monitored Power Distribution Unit / PDU (agency derated to 16A continuous) ● C20 inlet; 8ft / 2.4m C20 cable and NEMA L6-20P plug adapter included ● 1U horizontal rackmount installation ● 8 C13 outlets ● Lighted display reports output power consumption in amps ● Built-in network interface reports voltage, frequency and PDU loading via network or secure web browser interface with options for user specified alarm and notification thresholds ● Pre-installed WEBCARDLX with the latest version of PowerAlert Device Manager firmware (PADM20) provides enhanced remote management capabilities ● PADM20 and PowerAlert Element Manager (PAEM) form a powerful tool for expanding maintenance functions in large installations, including firmware update checks and backup and restoration of device configurations ● Optional EnviroSense2 modules (sold separately) provide a variety of environmental monitoring capabilities ● 10/100 Mbps auto-sensing allows optimal communication with 10/100 Base-T networks ● Real-time clock backup maintains the time of day and date even if the PDU is unpowered ● Tiered access privileges allow an administrator and a guest to login via web browser for monitoring ● Alert notifications via email or SNMP traps offer immediate event notification ● Firmware upgrade ability supports future product enhancements. ● Mounting flanges support installation in 2 and 4 post racks, with additional support for wall-mount and under-counter installation formats ● Mounting ears are reversible for front or rear facing rackmount installation ● Included cord retention brackets keep vital network equipment plugged in and continuously powered ● TAA Compliant for GSA Schedule purchases 1/3 ● Rackmount PDU ● Rack mounting brackets ● Plug retention inserts ● 2.6m C19-to-C20 power cord ● C19-to-L6-20P plug adapter ● Mounting hardware ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332160928 PDU Type Monitored INPUT PDU Input Voltage 208; 230 Recommended Electrical Service Single-phase 16/20A 230/208V service Maximum Input Amps 16 Maximum Input Amps Details Agency de-rated to 16A continuous Input Connection Type C20 inlet accepts included C19-C20 cable with included plug adapters PDU Plug Type NEMA L6-20P; IEC-320 C20 Input Phase Single-Phase Input Cord Length (ft.) 8.5 Input Cord Length (m) 2.59 OUTPUT Output Capacity Details 3.68kW (230V), 3.33kW (208V) / 16A total capacity; 12A (10A CE) max per C13 outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (8) C13 Output Nominal Voltage 208/230V USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Digital meter reports PDU output current in amps SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported 1U horizontal rackmount in 2 or 4 post racks Minimum Required Rack Depth (cm) 43.43 Minimum Required Rack Depth (inches) 17.1 PDU Form Factor Horizontal (1U) Shipping Dimensions (hwd / in.) 6.00 x 20.75 x 23.00 Shipping Dimensions (hwd / cm) 15.24 x 52.70 x 58.42 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (lbs.) 13.50 Shipping Weight (kg) 6.12 Unit Dimensions (hwd / in.) 1.750 x 17.500 x 14.800 Unit Dimensions (hwd / cm) 4,4 x 44,4 x 37,6 Unit Weight (lbs.) 9.00 Unit Weight (kg) 4.08 ENVIRONMENTAL Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range -30°C to +50°C (-22°F to +122°F) Relative Humidity 5-95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 COMMUNICATIONS PowerAlert Software LX Platform Interface: PowerAlert Device Manager Communications Cable Micro-USB- to-USB A configuration/console Access cable Network Monitoring Port RJ45 Network port, Micro-USB Configuration port, USB A port supports a variety of Envirosense2 environmental and control modules. See Accessories>Management Hardware section for more information about these modules. SNMP Compatibility Pre-installed LX platform interface provides remote monitoring via Java-free HTML5 web interface, telnet, SSH and SNMP management systems Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet) FEATURES & SPECIFICATIONS High Availability PDU Features Remote Network Notifications STANDARDS & COMPLIANCE Product Certifications NOM (Mexico); UL 60950-1 Product Compliance RoHS; CE (Europe); FCC Part 15 Class A (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDUMNH20HV
1. 物料型号: - 型号编号:PDUMNH20HV
2. 器件简介: - 该PDU为1U机架式,提供8个C13输出口,带有C20输入接口和2.4米C20电缆,以及L6-20P插头适配器。支持通过以太网接口报告电压、频率和负载水平。
3. 引脚分配: - 输入:C20入口,接受附带的C19-C20电缆和插头适配器。 - 输出:8个C13输出口。
4. 参数特性: - 输入电压:208V/230V。 - 最大输入电流:16A(机构额定为连续16A)。 - 输出容量:3.68kW(230V),3.33kW(208V)/16A总容量;每个C13输出口最大12A(10A CE)。 - 频率兼容性:50/60 Hz。
5. 功能详解: - 前面板LCD显示屏:数字表显示PDU输出电流(安培)。 - 网络接口:内置网络接口,通过网络或安全网站报告电压、频率和PDU负载。 - WEBCARDLX预装有最新版本的PowerAlert设备管理器固件(PADM20),提供增强的远程管理能力。 - 可选EnviroSense2模块(单独出售)提供各种环境监测功能。 - 10/100 Mbps自动感应,与10/100 Base-T网络最佳通信。 - 实时时钟备份,即使PDU断电也能保持日期和时间。 - 通过电子邮件或SNMP陷阱提供即时事件通知的警报通知。
6. 应用信息: - 适用于需要远程监控和管理电源分配的数据中心和网络机房环境。
7. 封装信息: - 机架高度:1U。 - 支持的机架形式:1U水平机架安装在2或4柱机架中。 - 最小所需机架深度:43.43厘米(17.1英寸)。 - PDU形式因素:水平(1U)。 - 发货尺寸:6.00x 20.75x23.00英寸(15.24x52.70x58.42厘米)。 - 发货重量:13.50磅(6.12千克)。
PDUMNH20HV 价格&库存
很抱歉,暂时无法提供与“PDUMNH20HV”相匹配的价格&库存,您可以联系我们找货
