PDUMH30HV
PDUMH30HV
    TRIPPLITE
    PDU METERED 208V 240V 30A 16 C13
PDUMH30HV 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 5.5kW Single-Phase Local Metered PDU, 208/230V Outlets (16 C13 & 2 C19), L6-30P, 12 ft. (3.66 m) Cord, 2U Rack-Mount, TAA Highlights ● Local metered single phase 24A 208/230V 2U horizontal rackmount PDU ● Two built-in meters report output current in amps for each load bank ● Attached 12-ft. (3.66 m) cord with NEMA L6-30P input plug ● 18 total outlets (16 C13, 2 C19) ● Reversible housing, 2U 208/230V rackmount local metered PDU ● TAA Compliant MODEL NUMBER: PDUMH30HV Package Includes Features ● 30A single phase 208/230V Local Metered Power Distribution Unit / PDU (Agency derated to 24A continuous) ● Set of two lighted meters report PDU output current in amps for each 9 outlet load bank ● Attached NEMA L6-30P 30A 208/230V input plug and 12-ft. (3.66 m) cord ● 2U horizontal rackmount format installs in two rack spaces ● 18 output receptacles (16 C13, 2 C19) ● Outlets are arranged in two 9 outlet load banks, each with separate 20A breaker and current metering ● Mounting flanges support installation in 2 and 4 post racks, with additional support for wall-mount and under-counter installation formats ● Mounting ears are reversible for front or rear facing rackmount installation ● Cord retention brackets keep vital equipment plugs connected ● Grounding lug ● Compliant with the Federal Trade Agreements Act(TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332159021 PDU Type Local Metered INPUT PDU Input Voltage 208; 230 1/3 ● 2U rack PDU ● Mounting brackets ● Plug retention plates ● User manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Recommended Electrical Service Single-phase 30A 208/230V service Maximum Input Amps 24 Maximum Input Amps Details Agency de-rated to 24A continuous PDU Plug Type NEMA L6-30P Input Phase Single-Phase Input Cord Length (ft.) 12 Input Cord Length (m) 3.66 OUTPUT Output Capacity Details 5.5kW (230V), 5kW (208V) total capacity / 30A max (Agency de-rated to 24A), 20A max per breakered outlet bank; 16A max per C19 outlet; 12A max per C13 outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (16) C13; (2) C19 Output Nominal Voltage 208/230V Overload Protection Two 20A breakers protect 9 outlets each USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Set of 2 digital meters continuously report output current for breakered load banks 1 & 2 (Bank 1: upper row of 9 outlets / Bank 2: lower row of 9 outlets) SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported 2U rackmount; mounting accessories included Minimum Required Rack Depth (cm) 40.64 Minimum Required Rack Depth (inches) 16 PDU Form Factor Horizontal (2U) Shipping Dimensions (hwd / in.) 7.80 x 16.70 x 19.80 Shipping Dimensions (hwd / cm) 19.81 x 42.42 x 50.29 Shipping Weight (lbs.) 15.80 Shipping Weight (kg) 7.17 Unit Dimensions (hwd / in.) 3.500 x 17.500 x 12.500 Unit Dimensions (hwd / cm) 8.8 x 44.4 x 31.8 Unit Weight (lbs.) 13.7 Unit Weight (kg) 6.21 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States ENVIRONMENTAL Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range -30°C to +50°C (-22°F to +122°F) Relative Humidity 5-95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 FEATURES & SPECIFICATIONS TVSS Grounding Grounding lug STANDARDS & COMPLIANCE Product Certifications NOM (Mexico); UL 62368-1 Product Compliance RoHS; FCC Part 15 Class A (USA); UKCA; Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDUMH30HV 价格&库存
很抱歉,暂时无法提供与“PDUMH30HV”相匹配的价格&库存,您可以联系我们找货
