1000 Eaton Boulevard
Cleveland, OH 44122
United States
3.2-3.8kW Single-Phase Monitored PDU, 200240V Outlets (18-C13 & 2-C19), C20/L6-20P, 0U
Vertical, 35.5 in., TAA
Highlights
Monitored 16/20A 200-240V
PDU; 0U 35.5 in / 90.2cm
vertical rackmount
Reports voltage, frequency &
loading information via ethernet
interface
Visual current meter; Toolless
button-mount installation
C20 inlet; 10ft / 3m L6-20P
power cable included
20 outlets (18 C13 & 2 C19);
cord retention brackets included
Temperature, humidity and
contact-closure monitoring
options
TAA Compliant
MODEL NUMBER: PDUMNV20HV2
Package Includes
Description
Tripp Lite Monitored PDU / Power Distribution Unit offers real-time remote monitoring of voltage,
frequency and load levels via built-in network connection. PowerAlert interface supports custom
notification of user-specified remote conditions via email, PowerAlert Console Launcher, SNMP, Telnet or
SSH interface. PDU output current consumption in amps is displayed via front panel lighted digital display
and can be monitored remotely to warn of potential overloads before critical IT mains breakers trip.
Features
200/208/230/240V Monitored PDU with built-in network interface in 0U 35.5 in. / 90.2cm rackmount form
factor; 20A maximum capacity (agency de-rated to 16A)
C20 inlet supports user supplied input cabling; 10ft / 3m L6-20P power cord included
0U 35.5in / 90.2cm vertical rackmount form factor
Network interface provides PDU control and data regarding input voltage, frequency and loading
information
Digital display reports load level information in amps
Supports user-specified alarm notification thresholds
In-rack environmental reporting with optional ENVIROSENSE temperature / humidity sensor and rack
access notification with up to 4 optional SRSWITCH door sensors
DHCP/Manual configuration support
10/100 Mbps auto-sensing
Real-time clock backup maintains the time of day and date even if the PDU is unpowered
Tiered access privileges allow an administrator and a guest to login simultaneously
Alert notifications via email or SNMP traps offer immediate event notification
Firmware upgrade ability supports future product enhancements
Supports HTTP, HTTPS, PowerAlert Network Management System, SMTP, SNMPv1, SNMPv2,
1/3
Rackmount PDU
Plug retention plates
Rack mounting brackets
Owner's manual
Cleveland, OH 44122
United States
SNMPv3, Telnet, SSH, FTP, DHCP, BOOTP, NTP protocols
Fully compatible with FREE PowerAlert Network Management System / NMS Software
Included cord retention brackets
Toolless mounting supported in button-mount compatible racks, plus nut-and-bolt mounting brackets for
other mounting applications
Compliant with the Federal Trade Agreements Act(TAA) for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332162564
PDU Type
Monitored
INPUT
Recommended Electrical Service
20A 208/240V; 16A 230V
Maximum Input Amps
Maximum Input Amps Details
Agency de-rated to 16A continuous
Input Connection Type
C20 inlet accepts included L6-20P input cable. Alternate C19 input cordsets supported.
PDU Plug Type
NEMA L6-20P; IEC-320 C20
Input Phase
Single-Phase
Input Cord Length (ft.)
10
Input Cord Length (m)
3.05
OUTPUT
Output Capacity Details
3.84kW (240V), 3.68kW (230V), 3.52kW (220V), 3.33kW (208V), 3.2kW (200V) / 16A total capacity; 16A max per
C19 outlet; 12A (10A CE) max per C13 outlet
Frequency Compatibility
50 / 60 Hz
Output Receptacles
(18) C13; (2) C19
Output Nominal Voltage
200; 208; 220; 230; 240
USER INTERFACE, ALERTS & CONTROLS
Front Panel LCD Display
Digital meter reports PDU output current in amps, Scroll IP-address information; Display can be rotated 180 degrees
for installation with the input cable at the top
Switches
Press the SCROLL IP / ROTATE button and release after one second to display the configured IP address in 2 digit
intervals; Press and release after two seconds to rotate the display 180 degrees
SURGE / NOISE SUPPRESSION
Automatic Shut-Off
No
PHYSICAL
2/3
Cleveland, OH 44122
United States
Form Factors Supported
0U vertical rackmount installation supported with included mounting brackets; supports tooless mounting in buttonmount compatible racks
PDU Form Factor
Vertical (0U)
Shipping Dimensions (hwd / in.)
42.00 x 6.20 x 4.50
Shipping Dimensions (hwd / cm)
106.68 x 15.75 x 11.43
Shipping Weight (lbs.)
11.50
Shipping Weight (kg)
5.22
Unit Dimensions (hwd / in.)
35.500 x 2.200 x 1.850
Unit Dimensions (hwd / cm)
90,2 X 5,6 X 4,7
Unit Weight (lbs.)
6.50
Unit Weight (kg)
2.95
ENVIRONMENTAL
Operating Temperature Range
0C ~ 40C (32F ~ 104F)
Storage Temperature Range
5 to 122F (-15 to 50C)
Relative Humidity
5-95% non-condensing
Operating Elevation (ft.)
0-10,000
Operating Elevation (m)
0-3000
COMMUNICATIONS
PowerAlert Software
LX Platform Interface: PowerAlert Device Manager
Communications Cable
RJ45-to-DB9 configuration/console Access cable
SNMP Compatibility
Pre-installed SNMPWEBCARD provides remote monitoring via PowerAlert Console Launcher, Telnet, and SNMP
management systems
Network Compatibility
10 Mbps; 100 Mbps (Fast Ethernet)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“PDUMNV20HV2”相匹配的价格&库存,您可以联系我们找货
