PDU3MV6L2120LV
PDU3MV6L2120LV
    TRIPPLITE
    PDU 3-PHASE METERED 120V 5.7 KW
PDU3MV6L2120LV 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 5.7kW 3-Phase Local Metered PDU, 120V Outlets (42 5-15/20R), 208V L21-20P input, 6 ft. (1.83 m) Cord, 0U Vertical, TAA Highlights ● Local Metered 5.7kW 3 Phase 120V output PDU; 70 in. / 178cm 0U vertical rackmount ● Reports load level per-phase via built in current meters ● NEMA L21-20P (3P+N+E) 208V 3 phase input; 6-ft. (1.83 m) line cord ● 42 NEMA 5-15/20R outlets (120V), Toolless button-mount installation; cord retention brackets included ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: PDU3MV6L2120LV Package Includes Features ● 5.7kW 3 phase 120V output Local Metered Power Distribution Unit / PDU ● Set of 3 built-in current meters continuously report load current per phase ● Attached NEMA L21-20P 20A (3P+N+E) 208V 3 phase input plug with 6 ft. / 1.8m cord ● 0U, 70 in. / 178cm vertical form factor supports installation in 2 or 4 post equipment racks ● 42 total outlets arranged in three single phase output load banks ● NEMA 5-15/20R outlets output 120V ● Included cord retention brackets keep vital network equipment plugged in and continuously powered ● Toolless mounting supported in button-mount compatible racks, plus nut-and-bolt mounting brackets for other mounting applications (set of 2 9mm buttons pre-installed, 2 9mm and 4 6mm spare buttons included) ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332163899 PDU Type Local Metered INPUT PDU Input Voltage 208 Recommended Electrical Service Three-phase 20A 208V service Maximum Input Amps 16 1/3 ● Local Metered Rackmount PDU with pre-installed mounting buttons ● Cord retention brackets ● Spare installation buttons (2 9mm / 4 6mm) ● Rack mounting brackets ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Maximum Input Amps Details Agency de-rated to 16A continuous PDU Plug Type NEMA L21-20P Input Phase 3-Phase Input Cord Length (ft.) 6 Input Cord Length (m) 1.83 OUTPUT Output Capacity Details 5.7kW (120V) total capacity / 16A max per output phase (L1, L2, L3); 16A max per 5-15/20R outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (42) 5-15/20R Output Nominal Voltage 120V USER INTERFACE, ALERTS & CONTROLS Reported Load Segments Supports local monitoring of current for each output phase (16A balanced max per L1, L2 and L3); Outlets are colorcoded and labeled for phase and load bank identification; L1-N feeds black 5-20R outlets; L2-N feeds dark-gray 520R outlets; L3-N feeds light-gray 5-20R outlets Front Panel LCD Display Set of 3 digital current meters report output current per phase SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported Vertical rackmount installation supported with included mounting brackets; supports toolless mounting in buttonmount compatible racks PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 5.40 x 6.80 x 76.00 Shipping Dimensions (hwd / cm) 13.72 x 17.27 x 193.04 Shipping Weight (lbs.) 14.60 Shipping Weight (kg) 6.62 Unit Dimensions (hwd / in.) 70.000 x 2.200 x 1.930 Unit Dimensions (hwd / cm) 177.8 x 5.6 x 4.34 Unit Weight (lbs.) 12.7 Unit Weight (kg) 5.76 ENVIRONMENTAL Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range -30°C to +60°C (-22°F to +140°F) Relative Humidity 5-95% non-condensing 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 STANDARDS & COMPLIANCE Product Certifications RETIE (Colombia); NOM (Mexico); UL 62368-1 Product Compliance RoHS; FCC Part 15 Class A (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDU3MV6L2120LV 价格&库存
很抱歉,暂时无法提供与“PDU3MV6L2120LV”相匹配的价格&库存,您可以联系我们找货
