PDUMH20HVAT
PDUMH20HVAT
    TRIPPLITE
    PDU METERED ATS 200V-240V 20A
PDUMH20HVAT 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 3.8kW Single-Phase Local Metered Automatic Transfer Switch PDU, Two 200-240V C20 Inlets, 8 C13 & 2 C19 Outputs, 1U, TAA Highlights ● Single phase 16A 200-240V Auto Transfer Switch / ATS PDU ● Enables redundant-power option for single-corded network devices ● Separate primary & secondary inputs connect to any two compatible power sources ● 1U horizontal rackmount; 2 C20 inputs; 8 C13 and 2 C19 outlets ● Two digit visual current meter; Upgrade options available ● Federal Trade Agreements Act / TAA Compliant for GSA Schedule purchases MODEL NUMBER: PDUMH20HVAT Package Includes Features ● 200-240V 20A Automatic Transfer Switch (ATS) / Local Metered PDU (Agency de-rated to 16A continuous) ● Provides a redundant power option for critical networking equipment with a single input power cord ● 2 digit display reports output power consumption in amps ● 1U horizontal rackmount form factor; 14.8 in. / 37.6 cm depth ● 10 outlets (8 C13, 2 C19) ● Set of Plug-lock output power cable retention sleeves prevent accidental disconnection of connected devices ● Set of two C20 inlets support connection to separate PRIMARY and SECONDARY power sources ● Two 12-ft. / 3.6m C19 to C20 power cables included ● ATS circuits normally maintain output sourced from the primary input cable; As primary input power fails or becomes unstable, the ATS will switch to maintain output sourced from the secondary input cable until power on the primary input is restored and stable ● ATS configurations enable fault-tolerant, hot-swappable UPS protection when used with a single UPS and fully redundant UPS protection when each cord is connected to a separate UPS system (in a twoUPS environment, the primary input cable must be supported by an online UPS with zero transfer time similar to Tripp Lite SmartOnline series) ● Advanced ATS configurations utilizing separate mains circuits, backup generators and even separate out of phase utility power grid feeds are fully supported ● On-board ATS processor constantly evaluates power quality on both inputs to prevent transfer to the secondary source when unavailable or of lower quality than the primary source ● Super-fast switchover between primary and secondary power sources occurs in 2-5 milliseconds ● Built-in card slot supports optional SNMPWEBCARD or WEBCARDLX for permanent upgrade to a switched & monitored PDU system ● Outlets are factory programmed for sequential turn-on at 250 millisecond intervals when the PDU is first energized to prevent inrush-related equipment interaction on startup ● Front panel LEDs confirm power availability on both input lines 1/4 ● Local Metered PDU with ATS Support ● 2x IEC C19-to-C20 AC input cables ● Plug-lock cable retention sleeves ● Mounting hardware ● User manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Federal Trade Agreements Act / TAA Compliant for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332156488 PDU Type Auto-Transfer Switch; Local Metered INPUT PDU Input Voltage 200; 208; 220; 230; 240 Recommended Electrical Service Two single-phase 16A 200-240V circuits Maximum Input Amps 16 Maximum Input Amps Details Agency de-rated to 16A continuous Input Connection Type Primary: C20 inlet and Secondary: C20 inlet PDU Plug Type (2) IEC-320 C20 Input Phase Single-Phase Input Cord Details Set of two inputs connect to separate PRIMARY and SECONDARY power sources Input Cord Length (ft.) 12 Input Cord Length (m) 3.66 OUTPUT Output Capacity Details 3.84kW (240V), 3.68kW (230V), 3.52kW (220V), 3.33kW (208V), 3.2kW (200V) / 16A total capacity; 16A max per C19 outlet; 12A (10A CE) max per C13 outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (8) C13; (2) C19 Output Nominal Voltage 200-240V Customized Load Management Receptacles Adding SNMPWEBCARD or WEBCARDLX accessory offers upgrade path to switched PDU (only C13 outlets are switchable upon upgrade); Management Cards can also can be inserted temporarily as a configuration tool to custom program power-on and power-off C13 outlet sequences with user-specified time delays in response to loss and restoration of primary input USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Digital display reports total PDU output current in amps Front Panel LEDs 8 front panel LEDs display power on/off status for each C13 outlet, plus 2 LEDs for power status on Primary and Secondary input connection Switches Toggle switch near digital display enables the setting of "HI" for 220, 230 or 240V nominal applications or "LO" for 200 or 208V applications SURGE / NOISE SUPPRESSION Automatic Shut-Off No 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Material of Construction Metal Form Factors Supported 1U rackmount Minimum Required Rack Depth (cm) 46.48 Minimum Required Rack Depth (inches) 18.3 PDU Form Factor Horizontal (1U) Shipping Dimensions (hwd / in.) 5.40 x 20.80 x 23.20 Shipping Dimensions (hwd / cm) 13.72 x 52.83 x 58.93 Shipping Weight (lbs.) 17.80 Shipping Weight (kg) 8.07 Unit Dimensions (hwd / in.) 1.720 x 17.330 x 14.770 Unit Dimensions (hwd / cm) 4,4 x 43,9 x 37,6 Unit Weight (lbs.) 10.30 Unit Weight (kg) 4.67 ENVIRONMENTAL Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range -30°C to +50°C (-22°F to +122°F) Relative Humidity 5-95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 COMMUNICATIONS Network Management Cards SNMPWEBCARD;  WEBCARDLX  SNMP Compatibility Includes slot for optional SNMPWEBCARD or  WEBCARDLX  accessory to add built-in network interface and enable remote individual outlet control over IP FEATURES & SPECIFICATIONS TVSS Grounding Rear grounding lug High Availability PDU Features Auto-Transfer Switching STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 60950-1 (Canada); NOM (Mexico); UL 60950-1 Product Compliance RoHS; CE (Europe); FCC Part 15 Class A (USA); UKCA; Trade Agreements Act (TAA) WARRANTY & SUPPORT 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
PDUMH20HVAT 价格&库存
很抱歉,暂时无法提供与“PDUMH20HVAT”相匹配的价格&库存,您可以联系我们找货
