PDUMNV20
PDUMNV20
    TRIPPLITE
    PDU MONITORED 5-15/20R 24 OUTLET
PDUMNV20 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 1.9kW Single-Phase Monitored PDU, 120V Outlets (24 5-15/20R), L5-20P/5-20P Adapter, 0U Vertical, 70 in., TAA MODEL NUMBER: PDUMNV20 Highlights ● Monitored 20A 120V PDU, 0U 70in / 178cm vertical rackmount ● Reports voltage, frequency and load level via ethernet interface ● Visual current meter, Toolless button-mount installation ● NEMA L5-20P input with 5-20P adapter and 10ft / 3m line cord ● 24 NEMA 5-15/20R outlets with included cord retention brackets ● Temperature, humidity and contact closure monitoring options ● TAA Compliant Package Includes ● Rackmount PDU ● Plug retention plates ● Rack mounting brackets ● Additional button mounts ● Configuration cable Description ● Owner's manual Tripp Lite Monitored PDU / Power Distribution Unit offers real-time remote monitoring of voltage, ● L5-20R to 5-20P adapter frequency and load levels via built-in network connection. PowerAlert interface supports custom notification of user-specified remote conditions via email, PowerAlert Console Launcher, SNMP, Telnet or SSH interface. PDU output current consumption in amps is displayed via front panel lighted digital display and can be monitored remotely to warn of potential overloads before critical IT mains breakers trip. Features ● 120V Monitored PDU with built-in network interface in 0U 70 in. / 178cm rackmount form factor; 20A maximum capacity (agency de-rated to 16A) ● Attached 10 ft. / 3m NEMA L5-20P input cable with NEMA 5-20P adapter included ● 24 NEMA 5-15/20R outlets ● 0U 70 in. / 178cm vertical rackmount form factor ● Network interface provides PDU control and data regarding input voltage, frequency and loading information ● Digital display reports load level information in amps ● Supports user-specified alarm notification thresholds ● In-rack environmental reporting with optional ENVIROSENSE temperature / humidity sensor and rack access notification with up to 4 optional SRSWITCH door sensors ● DHCP/Manual configuration support ● 10/100 Mbps auto-sensing ● Real-time clock backup maintains the time of day and date even if the PDU is unpowered ● Tiered access privileges allow an administrator and a guest to login simultaneously ● Alert notifications via email or SNMP traps offer immediate event notification ● Firmware upgrade ability supports future product enhancements ● Supports HTTP, HTTPS, PowerAlert Network Management System, SMTP, SNMPv1, SNMPv2, 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States SNMPv3, Telnet, SSH, FTP, DHCP, BOOTP, NTP protocols ● Fully compatible with FREE PowerAlert Network Management System / NMS Software ● Included cord retention brackets ● Toolless mounting supported in button-mount compatible racks, plus nut-and-bolt mounting brackets for other mounting applications ● Federal Trade Agreements Act / TAA Compliant for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332149527 PDU Type Monitored INPUT Recommended Electrical Service 20A 120V Maximum Input Amps 20.0 PDU Plug Type NEMA 5-20P; NEMA L5-20P Input Phase Single-Phase Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 OUTPUT Output Capacity Details 2.03kW (127V), 1.92kW (120V), 1.6kW (100V) / 20A total capacity (Agency de-rated to 16A); 16A max per outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (24) 5-15/20R Output Nominal Voltage 100; 120; 127 USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Digital meter reports PDU output current in amps, Scroll IP-address information; Display can be rotated 180 degrees for installation with the input cable at the top Switches Press the SCROLL IP / ROTATE button and release after one second to display the configured IP address in 2 digit intervals; Press and release after two seconds to rotate the display 180 degrees SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported 0U vertical rackmount installation supported with included mounting brackets; supports toolless mounting in buttonmount compatible racks 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 5.00 x 6.30 x 73.20 Shipping Dimensions (hwd / cm) 12.70 x 16.00 x 185.93 Shipping Weight (lbs.) 13.30 Shipping Weight (kg) 6.03 Unit Dimensions (hwd / in.) 70.000 x 2.190 x 1.750 Unit Dimensions (hwd / cm) 177.8 x 5.56 x 4.45 Unit Weight (lbs.) 12.20 Unit Weight (kg) 5.53 ENVIRONMENTAL Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range 5 to 122F (-15 to 50C) Relative Humidity 5-95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 COMMUNICATIONS PowerAlert Software LX Platform Interface: PowerAlert Device Manager Communications Cable RJ45-to-DB9 configuration/console Access cable SNMP Compatibility Pre-installed SNMPWEBCARD provides remote monitoring via PowerAlert Console Launcher, Telnet, SSH, and SNMP management systems Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDUMNV20 价格&库存
很抱歉,暂时无法提供与“PDUMNV20”相匹配的价格&库存,您可以联系我们找货
