PDUMNV20HV
PDUMNV20HV
    TRIPPLITE
    PDU MONITORED 208V-240V 20A C13
PDUMNV20HV 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 3.2-3.8kW Single-Phase Monitored PDU, 200240V Outlets (20-C13, 4-C19), C20/L6-20P, 0U Vertical, 70 in., TAA Highlights ● Monitored 16/20A 200-240V PDU; 0U 70in / 178cm vertical rackmount ● Reports voltage, frequency and load level via ethernet interface ● Visual current meter, Toolless button-mount installation ● C20 inlet, 10ft / 3m L6-20P power cable included ● 24 outlets (20 C13 & 4 C19) with included cord retention brackets ● Temperature, humidity and contact-closure monitoring options ● Federal Trade Agreements Act / TAA compliant for GSA schedule purchases MODEL NUMBER: PDUMNV20HV Package Includes Description Tripp Lite Monitored PDU / Power Distribution Unit offers real-time remote monitoring of voltage, frequency and load levels via built-in network connection. PowerAlert interface supports custom notification of user-specified remote conditions via email, PowerAlert Console Launcher, SNMP, Telnet or SSH interface. PDU output current consumption in amps is displayed via front panel lighted digital display and can be monitored remotely to warn of potential overloads before critical IT mains breakers trip. Features ● 200/208/230/240V Monitored PDU with built-in network interface in 0U 70 in. / 178cm rackmount form factor; 20A maximum capacity (agency de-rated to 16A) ● C20 inlet supports user supplied input cabling; 10ft / 3m L6-20P power cord included ● 24 outlets (20 C13 & 4 C19) ● 0U 70in / 178cm vertical rackmount form factor ● Network interface provides PDU control and data regarding input voltage, frequency and loading information ● Digital display reports load level information in amps ● Supports user-specified alarm notification thresholds ● In-rack environmental reporting with optional ENVIROSENSE temperature / humidity sensor and rack access notification with up to 4 optional SRSWITCH door sensors ● DHCP/Manual configuration support ● 10/100 Mbps auto-sensing ● Real-time clock backup maintains the time of day and date even if the PDU is unpowered ● Tiered access privileges allow an administrator and a guest to login simultaneously ● Alert notifications via email or SNMP traps offer immediate event notification ● Firmware upgrade ability supports future product enhancements ● Supports HTTP, HTTPS, PowerAlert Network Management System, SMTP, SNMPv1, SNMPv2, 1/3 ● Rackmount PDU ● Plug retention plates ● Rack mounting brackets ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States SNMPv3, Telnet, SSH, FTP, DHCP, BOOTP, NTP protocols ● Fully compatible with FREE PowerAlert Network Management System / NMS Software ● Included cord retention brackets ● Toolless mounting supported in button-mount compatible racks, plus nut-and-bolt mounting brackets for other mounting applications ● Federal Trade Agreements Act / TAA compliant for GSA schedule purchases Specifications OVERVIEW UPC Code 037332149534 PDU Type Monitored INPUT Recommended Electrical Service 20A 208/240V; 16A 230V Maximum Input Amps 20 Input Connection Type C20 inlet accepts included L6-20P input cable. Alternate C19 input cordsets supported. PDU Plug Type NEMA L6-20P; IEC-320 C20 Input Phase Single-Phase Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 OUTPUT Output Capacity Details 3.84kW (240V), 3.68kW (230V), 3.52kW (220V), 3.33kW (208V), 3.2kW (200V) / 16A total capacity; 16A max per C19 outlet; 12A (10A CE) max per C13 outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (20) C13; (4) C19 Output Nominal Voltage 200; 208; 220; 230; 240 USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Digital meter reports PDU output current in amps, Scroll IP-address information; Display can be rotated 180 degrees for installation with the input cable at the top Switches Press the SCROLL IP / ROTATE button and release after one second to display the configured IP address in 2 digit intervals; Press and release after two seconds to rotate the display 180 degrees SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Form Factors Supported 0U vertical rackmount installation supported with included mounting brackets; supports tooless mounting in buttonmount compatible racks 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 4.00 x 6.00 x 72.50 Shipping Dimensions (hwd / cm) 10.16 x 15.24 x 184.15 Shipping Weight (lbs.) 13.50 Shipping Weight (kg) 6.12 Unit Dimensions (hwd / in.) 70.000 x 2.190 x 2.650 Unit Dimensions (hwd / cm) 177,8 x 5,6 x 6,7 Unit Weight (lbs.) 8.50 Unit Weight (kg) 3.86 ENVIRONMENTAL Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range 5 to 122F (-15 to 50C) Relative Humidity 5-95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 COMMUNICATIONS PowerAlert Software LX Platform Interface: PowerAlert Device Manager Communications Cable RJ45-to-DB9 configuration/console Access cable SNMP Compatibility Pre-installed SNMPWEBCARD provides remote monitoring via PowerAlert Console Launcher, Telnet, SSH, and SNMP management systems Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDUMNV20HV
物料型号:PDUMNV20HV
器件简介:Tripp Lite品牌的监控型PDU(电源分配单元),提供实时远程监控电压、频率和负载水平,通过内置网络连接。
引脚分配:24个输出插座(20个C13和4个C19)
参数特性: - 单相输入 - 推荐电气服务:20A 208/240V;16A 230V - 最大输入安培:20 - 输出容量:3.84kW (240V), 3.68kW (230V), 3.52kW (220V), 3.33kW (208V), 3.2kW (200V) / 16A 总容量 - 频率兼容性:50 / 60 Hz - 输出名义电压:200; 208; 220; 230; 240
功能详解: - 通过以太网接口报告电压、频率和负载水平 - 前面板LCD显示屏显示PDU输出电流,可滚动显示IP地址信息 - 支持用户设定的报警通知阈值 - 支持最多4个可选的SRSWITCH门传感器进行机架内环境报告 - 支持DHCP/手动配置 - 支持多种协议,包括HTTP, HTTPS, SNMPv1, SNMPv2, SNMPv3, Telnet, SSH, FTP, DHCP, BOOTP, NTP
应用信息:适用于需要远程监控电源和环境条件的数据中心和网络机房。
封装信息:0U垂直机架安装,支持工具免安装在按钮安装兼容机架中,附带安装支架。
PDUMNV20HV 价格&库存
很抱歉,暂时无法提供与“PDUMNV20HV”相匹配的价格&库存,您可以联系我们找货
