PDU3VN3L2120
PDU3VN3L2120
    TRIPPLITE
    PDU 3-PHASE MONITORED 208V 5.7KW
PDU3VN3L2120 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 5.7kW 3-Phase Monitored PDU, 208V Outlets (30 C13 & 6 C19), L21-20P, 3ft Cord, 0U Vertical MODEL NUMBER: PDU3VN3L2120 Highlights ● Monitored 5.7kW 3 Phase 208V PDU; 70 in. / 178cm 0U vertical rackmount ● Reports voltage, frequency and load per-phase via built in ethernet interface ● Visual current meter; Toolless button-mount installation ● NEMA L21-20P 20A (3P+N+E) 208V 3 phase input; 3 ft. / 1m line cord ● 30 C13 & 6 C19 single phase outlets; Included cord retention brackets ● Temperature, humidity and contact closure monitoring options Package Includes Description ● Monitored rackmount PDU with pre-installed mounting buttons ● Cord retention brackets ● Spare installation buttons (2 9mm / 4 6mm) ● Rack mounting brackets ● Owner's manual Tripp Lite 3 phase Monitored PDU / Power Distribution Unit offers real-time remote monitoring of voltage, frequency and load levels via built-in network connection. PowerAlert interface supports custom notification of user-specified remote conditions via email, secure web, SNMP, Telnet or SSH interface. PDU output current consumption in amps is displayed per-phase via front panel lighted digital display and can be monitored remotely to warn of potential overloads before critical IT mains breakers trip. Features ● 5.7kW 3 phase 208V Monitored Power Distribution Unit / PDU with built-in web/network interface ● Attached NEMA L21-20P 20A (3P+N+E) 208V 3 phase input plug with 3 ft. / 1m cord ● 0U, 70 in. / 178cm vertical form factor supports installation in 2 or 4 post equipment racks ● 36 total 208V outlets (30 C13, 6 C19) arranged in three single phase output load banks ● Lighted display with scroll-button reports power consumption in amps for all 3 loading banks, IP-address self-identification and 180 degree display rotation for overhead or raised floor power feeds ● Built-in SNMP/ethernet interface reports voltage, frequency and PDU loading per-phase via network or secure web browser interface with options for user specified alarm and notification thresholds ● Supports in-rack environmental reporting with optional ENVIROSENSE temperature / humidity sensor and rack access notification with up to 4 optional SRSWITCH door sensors ● DHCP/Manual configuration support ● 10/100 Mbps auto-sensing allows optimal communication with 10/100 Base-T networks ● Real-time clock backup maintains the time of day and date even if the PDU is unpowered ● Tiered access privileges allow an administrator and a guest to login via web browser for monitoring ● Alert notifications via email or SNMP traps offer immediate event notification ● Firmware upgrade ability supports future product enhancements ● Supports HTTP, HTTPS, PowerAlert Network Management System, SMTP, SNMPv1, SNMPv2, SNMPv3, Telnet, SSH, FTP, DHCP, BOOTP, NTP protocols ● Fully compatible with FREE PowerAlert Network Management System / NMS Software 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Included cord retention brackets keep vital network equipment plugged in and continuously powered ● Toolless mounting supported in button-mount compatible racks, plus nut-and-bolt mounting brackets for other mounting applications (set of 2 9mm buttons pre-installed, 2 9mm and 4 6mm spare buttons included) Specifications OVERVIEW UPC Code 037332158208 PDU Type Monitored INPUT Recommended Electrical Service 20A 208V with NEMA L21-20R outlet Maximum Input Amps 16 Maximum Input Amps Details Agency de-rated to 16A continuous PDU Plug Type NEMA L21-20P Input Phase 3-Phase Input Cord Details Cord length specifications are nominal and subject to manufacturing variance Input Cord Length (ft.) 3 Input Cord Length (m) 0.91 OUTPUT Output Capacity Details 5.7kW (208V) total capacity / 9.2A max per output phase (L1-L2, L2-L3, L3-L1) Frequency Compatibility 50 / 60 Hz Output Receptacles (30) C13; (6) C19 Output Nominal Voltage 208 USER INTERFACE, ALERTS & CONTROLS Reported Load Segments Supports local monitoring of current for each output phase (9.2A max per L1-L2, L2-L3, L3-L1 balanced); BANK "L1" is powered by L1-L2 (outlets 1-12); BANK "L2" is powered by L2-L3 (outlets 13-24); BANK "L3" is powered by L3-L1 (outlets 25-36) Front Panel LCD Display Digital display reports output load level in amps separately for each output phase; Can also be used to scroll the configured IP address Front Panel LEDs Set of 3 LEDs (L1, L2, L3) indicate the output load segment the digital current display is reporting Switches SELECT switch advances the digital display and LED to report power consumption for load segments L1, L2 and L3; Press and hold the SELECT switch to rotate the digital display 90 degrees for overhead power input; Press and hold the SCROLL IP button to scroll the configured IP address Current Measurement Accuracy (Amps) +/-1% Voltage Measurement Accuracy (Volts) +/-1% 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Power Measurement Accuracy (Watts) +/-1% SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported Vertical rackmount installation supported with included mounting brackets; supports tooless mounting in buttonmount compatible racks PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 6.61 x 9.25 x 75.47 Shipping Dimensions (hwd / cm) 16.79 x 23.50 x 191.69 Shipping Weight (lbs.) 15.00 Shipping Weight (kg) 6.80 Unit Dimensions (hwd / in.) 70.000 x 2.190 x 3.260 Unit Dimensions (hwd / cm) 177.8 x 5.6 x 4.24 Unit Weight (lbs.) 7.2 Unit Weight (kg) 3.27 ENVIRONMENTAL Storage Temperature Range -15°C to +50°C (+5°F to +122°F) Relative Humidity 5-95% non condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 COMMUNICATIONS PowerAlert Software SNMPWEBCARD Interface: PowerAlert 12 Communications Cable RJ45-to-DB9 configuration/console Access cable Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet) STANDARDS & COMPLIANCE TAA Compliant Option TAA Compliant Version Available - Order Tripp Lite PDU3EVN6L2120 WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
PDU3VN3L2120 价格&库存
很抱歉,暂时无法提供与“PDU3VN3L2120”相匹配的价格&库存,您可以联系我们找货
