PDUMH15HVNET
PDUMH15HVNET
    TRIPPLITE
    PDU SWITCHED 200V - 240V 15A
PDUMH15HVNET 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2.5kW Single-Phase 208/230V Switched PDU - LX Platform, 8 C13 Outlets, C14 Input 2m Cord, 1U Rack-Mount, TAA Highlights ● Switched 10/12A 208/230V PDU; 1U horizontal rackmount ● Pre-installed WEBCARDLX with latest version of PADM20 for IPbased Auto Probe feature ● Visual current meter; reversible housing ● C14 inlet; 6.5ft / 2m C14 power cable included ● 8 C13 switched outlets with cord retention brackets ● Temperature, humidity and contact-closure monitoring options ● TAA Compliant MODEL NUMBER: PDUMH15HVNET Package Includes Features ● 208/230V Switched Power Distribution Unit / PDU with built-in web/network interface (12A 208V and 10A at 230V) ● C14 power inlet accepts a wide variety of worldwide input cord options ● Includes 6.5 ft. / 2m C14 cable ● 1U horizontal rackmount form factor ● 8 switched C13 outlets ● Supports power-on, power-off or reboot of each outlet on a real-time or programmable basis ● Enables reboot of locked equipment, custom power-on/power-off sequences, load-shedding of optional loads and disabling unused outlets ● Pre-installed WEBCARDLX with the latest version of PowerAlert Device Manager firmware (PADM20) provides enhanced remote management capabilities ● PADM20 and PowerAlert Element Manager (PAEM) form a powerful tool for expanding maintenance functions in large installations, including firmware update checks and backup and restoration of device configurations ● IP-based Auto Probe detects lost connectivity and restores service autonomously ● In-rack environmental reporting with optional temperature, humidity and contact-closure sensor options ● 10/100 Mbps auto-sensing ● Included cord retention brackets keep vital network equipment plugged in and continuously powered Specifications OVERVIEW UPC Code 037332139276 PDU Type Switched 1/3 ● 1U Switched PDU ● Mounting brackets ● Cord retention plates ● C13 to C14 power cable 1000 Eaton Boulevard Cleveland, OH 44122 United States INPUT PDU Input Voltage 208; 230 Recommended Electrical Service Single-phase 12/10A 208/230V service Maximum Input Amps 12 Maximum Input Amps Details Agency de-rated to 12A at 200, 208, 220 & 240V; Agency de-rated to 10A at 230V Input Connection Type C14 inlet PDU Plug Type IEC-320 C14 Input Phase Single-Phase Input Cord Length (ft.) 6.5 Input Cord Length (m) 1.98 OUTPUT Output Capacity Details 2.5kW (208V), 2.3kW (230V) / 12A (10A CE) total capacity Frequency Compatibility 50 / 60 Hz Output Receptacles (8) C13 Output Nominal Voltage 208/230V Customized Load Management Receptacles 8 individually switched output receptacles USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Digital display reports total PDU output current in amps Front Panel LEDs 8 LEDs display power on-off status for each output receptacle SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported 1U rackmount. Includes mounting accessories for 2-4 post racks Minimum Required Rack Depth (cm) 43.43 Minimum Required Rack Depth (inches) 17.1 PDU Form Factor Horizontal (1U) Shipping Dimensions (hwd / in.) 5.70 x 20.70 x 23.00 Shipping Dimensions (hwd / cm) 14.48 x 52.58 x 58.42 Shipping Weight (lbs.) 13.20 Shipping Weight (kg) 5.99 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Dimensions (hwd / in.) 1.720 x 14.770 x 17.330 Unit Dimensions (hwd / cm) 2,87 x 43,9 x 37,6 Unit Weight (lbs.) 9.00 Unit Weight (kg) 4.08 ENVIRONMENTAL Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range -30°C to +50°C (-22°F to +122°F) Relative Humidity 5-95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 COMMUNICATIONS PowerAlert Software LX Platform Interface: PowerAlert Device Manager Communications Cable Micro-USB- to-USB A configuration/console Access cable Network Monitoring Port RJ45 Network port, Micro-USB Configuration port, USB A port supports a variety of Envirosense2 environmental and control modules. See Accessories>Management Hardware section for more information about these modules. SNMP Compatibility Pre-installed LX platform interface provides remote monitoring via Java-free HTML5 web interface, telnet, SSH and SNMP management systems Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet) FEATURES & SPECIFICATIONS TVSS Grounding Back panel grounding lug High Availability PDU Features Auto Probe Monitoring and Reboot (included); Auto Load Shedding STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 60950-1 (Canada); NOM (Mexico); UL 60950-1 Product Compliance RoHS; CE (Europe); FCC Part 15 Class A (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDUMH15HVNET 价格&库存
很抱歉,暂时无法提供与“PDUMH15HVNET”相匹配的价格&库存,您可以联系我们找货
