PDUB30
PDUB30
    TRIPPLITE
    PDUDUALHOTSWAP120V30A
PDUB30 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2.9kW Single-Phase Hot-Swap PDU, 120V 30A (1 L5-30R, 6 5-15/20R), 2 L5-30P, 10ft & 6ft Cords, 2U Rack-Mount Highlights ● Single phase 30A 120V Hotswap PDU ● Enables live replacement of a standard UPS with zero downtime ● 2U horizontal rackmount installation ● Compatible with any UPS with a L5-30P input plug ● Manual transfer switch controls PDU input power source ● Pair of L5-30P input cables connect to separate Utility and UPS inputs ● 7 outlets (6 5-15/20 & 1 L5-30R) MODEL NUMBER: PDUB30 Package Includes Description Tripp Lite’s Hot-swap PDU systems enable live-replacement of standard UPS systems for maintenance with no interruption of connected server or networking loads. Dual input power cables support PDU connection to separate Utility and UPS power sources. Manual transfer switch with lighted status indicators controls the source of power to connected equipment between Utility and UPS. Set the switch to UPS during normal operation and connected equipment will receive full-time conditioned power from the UPS. Set the switch to Utility to momentarily power connected equipment from the Utility line cord and bypass the UPS while the UPS system is removed and replaced with a fresh one. Once the new UPS is up and running with all data and electrical connections restored, set the switch back to the UPS setting to once again provide fully-conditioned UPS power to connected equipment. Features ● Tripp Lite Hot-swap PDU systems support live-replacement of standard UPS systems for maintenance with no interruption of connected server or networking loads ● PDUB30 is universally compatible with any Tripp Lite or other brand of 100-127V UPS rated up to 3000VA or 2880 watts with a NEMA L5-30P input cable ● 2U horizontal rackmount form factor compatible with 2 or 4 post racks ● Supports space saving rear-post mounting in the same rack space as many Tripp Lite Rackmount UPS systems (select installations, see manual) ● Pair of attached L5-30P PDU input cables connect to separate Utility and UPS power sources ● 6 5-15/20R and 1 L5-30R outlets support critical networking loads in both Utility and UPS operating modes ● One additional L5-30R pass-through outlet supports UPS input power cord ● Dual input power cables support PDU connection to separate Utility and UPS power sources ● Manual transfer switch with lighted status indicators controls the source of power to connected equipment between Utility and UPS ● Set the switch to UPS during normal operation and connected equipment will receive full-time 1/3 ● Hot-swap PDU System ● 2U mounting brackets ● User manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States conditioned power from the UPS ● Set the switch to Utility to bypass the UPS and provide connected equipment with unfiltered power directly from the Utility line cord while the UPS system is removed and replaced with a fresh one ● Once the new UPS is up and running with all connections restored, set the switch back to the UPS setting to once again provide fully-conditioned UPS power to connected equipment ● TAA Compliant Version Available - Order Tripp Lite PDUB30TAA Specifications OVERVIEW UPC Code 037332153890 PDU Type Hot-Swap INPUT Recommended Electrical Service 30A 120V Maximum Input Amps 24 Maximum Input Amps Details Agency de-rated to 24A continuous PDU Plug Type NEMA L5-30P Input Cord Length Details Utility input cable (10 ft / 3m) / UPS input cable (6 ft / 1.8m) Input Phase Single-Phase OUTPUT Output Capacity (Watts) 2880 Output Capacity Details 3.05kW (127V), 2.88kW (120V), 2.4kW (100V) / 30A total capacity (Agency de-rated to 24A); 24A max per L5-30R outlet; 20A max per breakered load bank; 16A max per 5-15/20R outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (6) 5-15/20R; (1) L5-30R Output Nominal Voltage 100; 120; 127 USER INTERFACE, ALERTS & CONTROLS Front Panel LEDs Lighted indicators confirm UPS and Utility switch position and operating mode Switches Manual 2 position transfer switch offers fast switching between UPS and Utility operating modes in less than 6 milliseconds SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported 2U rackmount in 2 or 4 post racks 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Minimum Required Rack Depth (cm) 21.59 Minimum Required Rack Depth (inches) 8.5 PDU Form Factor Horizontal (1U) Shipping Dimensions (hwd / in.) 12.20 x 20.30 x 6.30 Shipping Dimensions (hwd / cm) 30.99 x 51.56 x 16.00 Shipping Weight (lbs.) 12.00 Shipping Weight (kg) 5.44 Unit Dimensions (hwd / in.) 3.420 x 17.320 x 3.030 Unit Dimensions (hwd / cm) 8.7 x 44 x 7.7 Unit Weight (lbs.) 7.7 Unit Weight (kg) 3.49 ENVIRONMENTAL Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range -15°C to +50°C (+5°F to +122°F) Relative Humidity 5-95% non condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 STANDARDS & COMPLIANCE TAA Compliant Option TAA Compliant Version Available - Order Tripp Lite PDUB30TAA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDUB30 价格&库存
很抱歉,暂时无法提供与“PDUB30”相匹配的价格&库存,您可以联系我们找货
