PDU3VN10L1520
PDU3VN10L1520
    TRIPPLITE
    PDU 3-PHASE MONITORED 208V 5.7KW
PDU3VN10L1520 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 5.7kW 3-Phase Monitored PDU, 208V Outlets (30 C13 & 6 C19), L15-20P, 10ft Cord, 0U Vertical MODEL NUMBER: PDU3VN10L1520 Highlights ● Monitored 5.7kW 3 Phase 208V PDU; 70 in. / 178cm 0U vertical rackmount ● Reports voltage, frequency and load per-phase via built in ethernet interface ● Visual current meter; Toolless button-mount installation ● NEMA L15-20P 20A (3P+E) 3 phase input; 10 ft. / 3m line cord ● 30 C13 & 6 C19 single phase outlets; Included cord retention brackets ● Temperature, humidity and contact closure monitoring options Package Includes ● Monitored rackmount PDU with pre-installed mounting buttons ● Cord retention brackets ● Spare installation buttons (2 9mm / 4 6mm) Tripp Lite 3 phase Monitored PDU / Power Distribution Unit offers real-time remote monitoring of voltage, ● Rack mounting brackets frequency and load levels via secure web, SNMP or Telnet interface. PowerAlert interface supports ● Owner's manual Description custom notification of user-specified remote conditions via email, secure web, SNMP, Telnet or SSH interface. PDU output current consumption in amps is displayed per-phase via front panel lighted digital display and can be monitored remotely to warn of potential overloads before critical IT mains breakers trip. Features ● 5.7kW 3 phase 208V Monitored Power Distribution Unit / PDU with built-in web/network interface ● NEMA L15-20P 20A (3P+E) 208V 3 phase input plug with 10 ft. / 3m cord ● 0U, 70 in. / 178cm vertical form factor supports installation in 2 or 4 post equipment racks ● 36 total 208V outlets (30 C13, 6 C19) arranged in three single phase output load banks ● Lighted display with scroll-button reports power consumption in amps for all 3 loading banks, IP-address self-identification and 180 degree display rotation for overhead or raised floor power feeds ● Built-in SNMP/ethernet interface reports voltage, frequency and PDU loading per-phase via network or secure web browser interface with options for user specified alarm and notification thresholds ● Supports in-rack environmental reporting with optional ENVIROSENSE temperature / humidity sensor and rack access notification with up to 4 optional SRSWITCH door sensors ● DHCP/Manual configuration support ● 10/100 Mbps auto-sensing allows optimal communication with 10/100 Base-T networks ● Real-time clock backup maintains the time of day and date even if the PDU is unpowered ● Tiered access privileges allow an administrator and a guest to login via web browser for monitoring ● Alert notifications via email or SNMP traps offer immediate event notification ● Firmware upgrade ability supports future product enhancements ● Supports HTTP, HTTPS, PowerAlert Network Management System, SMTP, SNMPv1, SNMPv2, SNMPv3, Telnet, SSH, FTP, DHCP, BOOTP, NTP protocols ● Fully compatible with FREE PowerAlert Network Management System / NMS Software 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Included cord retention brackets keep vital network equipment plugged in and continuously powered ● Toolless mounting supported in button-mount compatible racks, plus nut-and-bolt mounting brackets for other mounting applications (set of 2 9mm buttons pre-installed, 2 9mm and 4 6mm spare buttons included) ● TAA Compliant Version Available - Order Tripp Lite PDU3VN10L152TAA Specifications OVERVIEW UPC Code 037332149879 PDU Type Monitored INPUT Recommended Electrical Service 20A 208V with NEMA L15-20R outlet Maximum Input Amps 16 Maximum Input Amps Details Agency de-rated to 16A continuous PDU Plug Type NEMA L15-20P Input Phase 3-Phase Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 OUTPUT Output Capacity Details 5.7kW (208V) total capacity / 9.2A max per output phase (L1-L2, L2-L3, L3-L1) Frequency Compatibility 50 / 60 Hz Output Receptacles (30) C13; (6) C19 Output Nominal Voltage 208 USER INTERFACE, ALERTS & CONTROLS Reported Load Segments Supports local monitoring of current for each output phase (9.2A max per L1-L2, L2-L3, L3-L1 balanced); BANK "L1" is powered by L1-L2 (outlets 1-12); BANK "L2" is powered by L2-L3 (outlets 13-24); BANK "L3" is powered by L3-L1 (outlets 25-36) Front Panel LCD Display Digital display reports output load level in amps separately for each output phase; Can also be used to scroll the configured IP address Front Panel LEDs Set of 3 LEDs (L1, L2, L3) indicate the output load segment the digital current display is reporting Switches SELECT switch advances the digital display and LED to report power consumption for load segments L1, L2 and L3 (short press); SELECT switch also rotates the local display 90 degrees for overhead power input (long press); SCROLL IP button scrolls the configured IP address (long press) Current Measurement Accuracy (Amps) +/-1% Voltage Measurement Accuracy (Volts) +/-1% 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Power Measurement Accuracy (Watts) +/-1% SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported Vertical rackmount installation supported with included mounting brackets; supports tooless mounting in buttonmount compatible racks PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 6.60 x 10.20 x 75.50 Shipping Dimensions (hwd / cm) 16.76 x 25.91 x 191.77 Shipping Weight (lbs.) 18.10 Shipping Weight (kg) 8.21 Unit Dimensions (hwd / in.) 70.000 x 2.190 x 3.260 Unit Dimensions (hwd / cm) 177.8 x 5.6 x 4.47 Unit Weight (lbs.) 9.9 Unit Weight (kg) 4.49 ENVIRONMENTAL Operating Temperature Range 32 to 122F (0C to 50C) Storage Temperature Range -30°C to +60°C (-22°F to +140°F) Relative Humidity 5-95% non condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 COMMUNICATIONS PowerAlert Software SNMPWEBCARD Interface: PowerAlert 12 Communications Cable RJ45-to-DB9 configuration/console Access cable Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet) STANDARDS & COMPLIANCE TAA Compliant Option TAA Compliant Version Available - Order Tripp Lite PDU3VN10L152TAA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
PDU3VN10L1520
1. 物料型号: - 型号编号:PDU3VN10L1520
2. 器件简介: - Tripp Lite的三相监控PDU(电源分配单元)提供通过安全的Web、SNMP或Telnet接口实时远程监控电压、频率和负载水平。PowerAlert界面支持通过电子邮件、安全的Web、SNMP、Telnet或SSH界面自定义通知用户指定的远程条件。PDU输出电流消耗以安培为单位显示在前面板的数字显示屏上,并且可以远程监控,以在关键IT主断路器跳闸之前警告潜在的过载。
3. 引脚分配: - 输出插座:30个C13和6个C19单相插座,分为三个单相输出负载组。
4. 参数特性: - 输入相位:三相 - 推荐电气服务:20A 208V,带有NEMA L15-20R插座 - 最大输入安培数:16A(连续) - PDU插头类型:NEMA L15-20P - 输入线缆长度:10英尺(3.05米) - 输出容量详情:5.7kW(208V)总容量/每输出相位最大9.2A(L1-L2、L2-L3、L3-L1) - 频率兼容性:50/60Hz - 输出名义电压:208V
5. 功能详解: - 支持通过内置以太网接口报告每相的电压、频率和负载。 - 前面板LCD显示屏分别报告每个输出相位的输出负载水平。 - 支持本地监控每个输出相位的电流(每L1-L2、L2-L3、L3-L1平衡;最大9.2A)。 - 支持远程监控和用户指定的报警和通知阈值。 - 支持可选的ENVIROSENSE温湿度传感器和最多4个可选的SRSWITCH门传感器进行机架访问通知。
6. 应用信息: - 适用于需要远程监控电压、频率和负载水平的数据中心和网络设备。
7. 封装信息: - 物理结构材料:金属 - 支持垂直机架安装,包括随附的安装支架;支持在按钮式兼容机架中进行无工具安装。 - PDU形式因素:垂直(0U) - 发货尺寸:6.60x10.20x75.50英寸(16.76x25.91x191.77厘米) - 发货重量:18.10磅(8.21千克) - 单位尺寸:70.000x2.190x3.260英寸(177.8x5.6x4.47厘米) - 单位重量:9.9磅(4.49千克)
PDU3VN10L1520 价格&库存
很抱歉,暂时无法提供与“PDU3VN10L1520”相匹配的价格&库存,您可以联系我们找货
