PDU3VN6L2120
PDU3VN6L2120
    TRIPPLITE
    PDU 3-PHASE MONITORED
PDU3VN6L2120 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 5.8kW 3-Phase Monitored PDU, 208/120V Outlets (36 C13, 6 C19, 3 5-15/20R), L21-20P, 6ft Cord, 0U Vertical, TAA MODEL NUMBER: PDU3VN6L2120 Highlights ● Monitored 5.8kW 3 Phase 208V input PDU with 208 & 120V output; 70 in. / 178cm 0U vertical rackmount ● Reports voltage & load perphase via ethernet interface ● 1% billing-grade accuracy, Multifunction digital display, Environmental monitoring options ● NEMA L21-20P 3 phase input; 6 ft. / 1.8m line cord ● 36 C13 & 6 C19 208v outlets, plus 3 NEMA 5-15/20R 120V outlets ● Temperature, humidity and contact closure monitoring options, Plug-lock cable retention sleeves ● TAA Compliant Package Includes Description ● Monitored rackmount PDU with pre-installed mounting buttons ● C14 and C20 Plug-lock cable retention sleeves ● Spare installation buttons (2 9mm / 4 6mm) ● Rack mounting brackets ● Owner's manual Tripp Lite 3 phase Monitored PDU / Power Distribution Unit offers real-time remote monitoring of voltage and load levels via built-in network connection. PowerAlert interface supports custom notification of userspecified remote conditions via email, secure web, SNMP, Telnet or SSH interface. PDU output current consumption in amps is displayed per-phase via front panel lighted digital display and can be monitored remotely to warn of potential overloads before critical IT mains breakers trip. Features ● 5.8kW 3 phase 208V input PDU with 208 & 120V output Monitored Power Distribution Unit / PDU with built-in web/network interface ● Attached NEMA L21-20P 3 phase input; 6 ft. / 1.8m cord ● 0U, 70 inch / 178cm vertical form factor ● 36 C13 (208V), 6 C19 (208V) and 3 NEMA 5-15/20R (120V) outlets in 3 single phase output load banks ● Network interface provides PDU data regarding input voltage and per-phase load levels with +/-1% billing-grade accuracy ● Built-in local digital display and remote web/network interface reports detailed voltage, amperage and kilowatt output values per phase with additional reporting options for power unbalance percentage, IP address and sensor* based temperature and humidity data (*requires ENVIROSENSE sensor) ● In-rack environmental reporting with optional ENVIROSENSE temperature / humidity sensor and rack access notification with up to 4 optional SRSWITCH door sensors ● Local display supports electronic 180 degree display rotation for overhead or under-floor input cable orientation ● Supports user-specified alarm notification thresholds ● DHCP/Manual configuration support ● 10/100 Mbps auto-sensing ● Real-time clock backup maintains the time of day and date even if the PDU is unpowered ● Tiered access privileges allow an administrator and a guest to login via web browser 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Alert notifications via email or SNMP traps offer immediate event notification ● Firmware upgrade ability supports future product enhancements ● Supports HTTP, HTTPS, PowerAlert Network Management System, SMTP, SNMPv1, SNMPv2, SNMPv3, Telnet, SSH, FTP, DHCP, BOOTP, NTP protocols ● Fully compatible with FREE PowerAlert Network Management System / NMS Software ● Included set of Plug-lock inserts keep C14 power cords solidly connected to PDU outlets ● Toolless mounting supported in button-mount compatible racks, plus nut-and-bolt mounting brackets for other mounting applications (set of 2 9mm buttons pre-installed, 2 9mm and 4 6mm spare buttons included) ● Federal Trade Agreements Act / TAA Compliant for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332180988 PDU Type Monitored INPUT Recommended Electrical Service 20A 208V with NEMA L21-20R outlet Maximum Input Amps 16 Maximum Input Amps Details Agency de-rated to 16A continuous PDU Plug Type NEMA L21-20P Input Phase 3-Phase Input Cord Length (ft.) 6 Input Cord Length (m) 1.83 OUTPUT Output Capacity Details 5.7kW (208/120V) total capacity; 9.2A (208V) max per output phase (L1-L2, L2-L3, L3-L1) / 16A (120V) max per output phase (L1, L2, L3) Frequency Compatibility 50 / 60 Hz Output Receptacle Details 5-15/20R outlets provide 120V output; C13 and C19 outlets provide 208V output Output Receptacles (3) 5-15/20R; (36) C13; (6) C19 Output Nominal Voltage 120; 208 USER INTERFACE, ALERTS & CONTROLS Reported Load Segments Supports monitoring of input current per phase (L1, L2, L3) and output current for each output load bank (B1-B6); Outlets are color-coded and labeled for phase and load bank identification; L1-L2 feeds black C13/C19 outlets (B1); L2-L3 feeds dark-gray C13/C19 outlets (B2); L3-L1 feeds light-gray C13/C19 outlets (B3); L1-N feeds black 5-20R outlet (B4); L2-N feeds dark-gray 5-20R outlet (B5); L3-N feeds light-gray 5-20R outlet (B6) Front Panel LCD Display Large digital display reports Amperage, Kilowatts, Voltage, Unbalance percentage, Temperature* and Humidity* information (*requires ENIVIROSENSE option); Small digital display provides detail on the measurement the large display is reporting: Input-phase (L#), Load bank (B#), Sensor (S#), Load unbalance (UB), Output power (OP) 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Front Panel LEDs Set of 6 LEDs identify the value displayed on the large digital display: Amperage (A), Kilowatts (kW), Voltage (V), Unbalance percentage (%UB), Temperature (T), Humidity (%RH); 3 additional multi-color LEDs offer power availability information for each pair of output load banks (Bank 1&4 / Bank 2&5 / Bank 3&6): GREEN (80% load), RED (Power OFF), RED FLASHING (Power OFF/breaker trip) Switches Set of UP/DOWN arrow buttons scroll through available Input, Bank, Power, Load balance and Sensor options; Additional MODE button advances the LEDs to view the next measurement Current Measurement Accuracy (Amps) +/-1% Voltage Measurement Accuracy (Volts) +/-1% Power Measurement Accuracy (Watts) +/-1% SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported Vertical rackmount installation supported with included mounting brackets; supports toolless mounting in buttonmount compatible racks PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 7.09 x 9.65 x 75.87 Shipping Dimensions (hwd / cm) 18.01 x 24.51 x 192.71 Shipping Weight (lbs.) 17.75 Shipping Weight (kg) 8.05 Unit Dimensions (hwd / in.) 70.000 x 2.170 x 2.520 Unit Dimensions (hwd / cm) 177.8 x 5.5 x 6.3 Unit Weight (lbs.) 13.50 Unit Weight (kg) 6.12 ENVIRONMENTAL Operating Temperature Range 32 to 122F (0 to 50C) Storage Temperature Range 5 to 140F (-15 to 60C) Relative Humidity 5-95% non condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 COMMUNICATIONS PowerAlert Software SNMPWEBCARD Interface: PowerAlert 12 Communications Cable RJ45-to-DB9 configuration/console Access cable SNMP Compatibility Yes, pre-installed SNMPWEBCARD provides remote monitoring via web, telnet, SSH and SNMP management systems 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
PDU3VN6L2120
物料型号:PDU3VN6L2120
器件简介:这款3相监控型PDU通过内置的网络连接提供实时的电压和负载水平远程监控。PowerAlert界面支持通过电子邮件、安全网页、SNMP、Telnet或SSH接口定制通知用户指定的远程条件。
引脚分配:36个C13(208V)、6个C19(208V)和3个NEMA 5-15/20R(120V)输出插座,分布在3个单相输出负载组中。
参数特性:5.8kW 3相输入PDU,208V和120V输出,具有网络接口,提供有关输入电压和每相负载水平的PDU数据,精度为±1%。
功能详解:具有内置的本地数字显示和远程Web/网络接口,报告每相详细的电压、电流和千瓦输出值,还包括功率不平衡百分比、IP地址和基于传感器的温度和湿度数据(需要ENVIROSENSE传感器)。
应用信息:适用于机架安装,支持0U垂直机架安装,附带安装按钮和支架。
封装信息:金属材质,垂直机架安装形式,附带安装支架;提供2年有限保修。
PDU3VN6L2120 价格&库存
很抱歉,暂时无法提供与“PDU3VN6L2120”相匹配的价格&库存,您可以联系我们找货
