PDUMV20NET
PDUMV20NET
    TRIPPLITE
    PDUSWITCHED5-15/20R24OUTLET
PDUMV20NET 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 1.9kW Single-Phase Switched PDU, 120V Outlets (24 5-15/20R), L5-20P/5-20P, 10ft Cord, 0U Vertical, TAA Highlights ● Switched 20A 120V PDU, 0U 70 in. / 178cm Vertical Rackmount Format ● Reports voltage, frequency & load level via ethernet interface ● Visual current meter, Toolless button mount installation ● NEMA L5-20P input with 5-20P adapter, attached 10 ft. / 3m cord ● 24 switched NEMA 5-15/20R outlets with cord retention brackets ● Temperature, humidity and contact closure monitoring options ● Federal Trade Agreements Act / TAA Compliant for GSA Schedule purchases MODEL NUMBER: PDUMV20NET Package Includes ● Rackmount PDU ● L5-20R to 5-15/20P adapter Description ● Rackmount brackets Tripp Lite single phase Switched PDU / Power Distribution Unit offers advanced network control and ● PDUMVROTATEBRKT monitoring with the ability to turn on, turn off, recycle or lock-out power to each individual receptacle, monitor site electrical conditions and remotely monitor output power consumption. PowerAlert interface supports remote control and custom notification of user-specified conditions via email, PowerAlert Console Launcher, SNMP, Telnet or SSH interface. Individually switched outlets can be controlled in realtime to remotely reboot unresponsive network hardware, or be custom programmed for user-defined power-up and power-down sequences to ensure proper startup of interdependent IT systems and prevent inrush-related overloads as network equipment is first energized. Unused PDU outlets can be electronically locked off to prevent the connection of unauthorized hardware. PDU output current consumption in amps is continuously displayed locally via visual meter and remotely via network interface to warn of potential overloads before critical IT mains or branch breakers trip. Features Specifications OVERVIEW UPC Code 037332139719 PDU Type Switched INPUT 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Recommended Electrical Service 20A 120V Maximum Input Amps 20 Maximum Input Amps Details Agency de-rated to 16A continuous PDU Plug Type NEMA 5-20P; NEMA L5-20P Input Phase Single-Phase Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 OUTPUT Output Capacity Details 2.03kW (127V), 1.92kW (120V), 1.6kW (100V) / 20A total capacity (Agency de-rated to 16A); 16A max per outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (24) 5-15/20R Output Nominal Voltage 100; 120; 127 Customized Load Management Receptacles Each outlet is individually controllable via remote interface USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Digital meter reports PDU output current in amps Front Panel LEDs 24 power availability LEDs confirm power off/on status for each built-in outlet Switches Recessed reset switch for interface reboot and factory reset SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Form Factors Supported 0U vertical rackmount; includes rackmount brackets. Supports toolless mounting in button-mount compatible racks PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 4.00 x 6.00 x 72.50 Shipping Dimensions (hwd / cm) 10.16 x 15.24 x 184.15 Shipping Weight (lbs.) 15.50 Shipping Weight (kg) 7.03 Unit Dimensions (hwd / in.) 70.000 x 2.190 x 2.650 Unit Dimensions (hwd / cm) 178 x 5.6 x 6.7 Unit Weight (lbs.) 10 Unit Weight (kg) 4.54 ENVIRONMENTAL Relative Humidity 0-95% non-condensing 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 COMMUNICATIONS PowerAlert Software SNMPWEBCARD Interface: PowerAlert 12 Communications Cable RJ45-to-DB9 configuration/console Access cable SNMP Compatibility Pre-installed SNMPWEBCARD provides remote monitoring via PowerAlert Console Launcher, Telnet, SSH, and SNMP management systems. Remote management enables outlets to be turned on and off individually Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDUMV20NET 价格&库存
很抱歉,暂时无法提供与“PDUMV20NET”相匹配的价格&库存,您可以联系我们找货
