PDU3MV6H50
PDU3MV6H50
    TRIPPLITE
    PDU 3-PHASE METERED 208V 12.6 KW
PDU3MV6H50 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 12.6kW 3-Phase Local Metered PDU, 208V Outlets (36 C13 & 9 C19) Hubbell 50A CS8365C, 6 ft. (1.83 m) Cord, 0U Vertical, TAA Highlights ● Local Metered 12.6kW 3 Phase 208V PDU; 70 in. / 178cm 0U vertical rackmount ● Reports load current per-phase via set of 3 built-in current meters ● Hubbell CS8365C 50A (3P+E) 208V 3 phase input; 6-ft. (1.83 m) line cord ● 45 208V outlets total (36 C13, 9 C19) ● Toolless button-mount installation; cord retention brackets included ● Federal Trade Agreements Act / TAA Compliant for GSA Schedule purchases MODEL NUMBER: PDU3MV6H50 Package Includes ● Local Metered PDU with preinstalled mounting buttons ● Cord retention brackets ● Spare installation buttons (2 9mm / 4 6mm) ● Rack mounting brackets ● Owner's manual Features ● 12.6kW 3 phase 208V Local Metered Power Distribution Unit / PDU ● Set of 3 built-in current meters continuously report load current in amps for all 3 output phases ● Attached Hubbell CS8365C 50A (3P+E) 208V 3 phase input plug with 6 ft. / 1.8m cord ● 0U, 70 in. / 178cm vertical form factor supports installation in 2 or 4 post equipment racks ● 45 total 208V outlets (36 C13, 9 C19) arranged in three breakered single phase output load banks ● Included cord retention brackets keep vital network equipment plugged in and continuously powered ● Toolless mounting supported in button-mount compatible racks, plus nut-and-bolt mounting brackets for other mounting applications (set of 2 9mm buttons pre-installed, 2 9mm and 4 6mm spare buttons included) ● Federal Trade Agreements Act / TAA Compliant for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332163868 PDU Type Local Metered INPUT PDU Input Voltage 208 Recommended Electrical Service Three-phase 50A 208V service Maximum Input Amps 35 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Maximum Input Amps Details Agency de-rated to 35A continuous PDU Plug Type HUBBELL CS8365C 50A Input Phase 3-Phase Input Cord Length (ft.) 6 Input Cord Length (m) 1.83 OUTPUT Output Capacity Details 12.6kVA (208V) total capacity; 20A max per breakered outlet bank; 16A max per C19 outlet; 12A max per C13 outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (36) C13; (9) C19 Output Nominal Voltage 208V Overload Protection 3 20A circuit breakers, 1 per outlet bank USER INTERFACE, ALERTS & CONTROLS Reported Load Segments Supports local monitoring of current for each output phase (20A balanced max per L1-L2, L2-L3 and L3-L1); Outlets are color-coded and labeled for phase and load bank identification; L1-L2 feeds black outlets; L2-L3 feeds dark-gray outlets; L3-L1 feeds light-gray outlets Front Panel LCD Display Set of 3 digital current meters report current in amps for each output phase SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported Vertical rackmount installation supported with included mounting brackets; supports toolless mounting in buttonmount compatible racks PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 6.00 x 10.00 x 77.30 Shipping Dimensions (hwd / cm) 15.24 x 25.40 x 196.34 Shipping Weight (lbs.) 21.40 Shipping Weight (kg) 9.71 Unit Dimensions (hwd / in.) 70.000 x 2.200 x 2.650 Unit Dimensions (hwd / cm) 177.8 x 6.73 x 4.34 Unit Weight (lbs.) 14.5 Unit Weight (kg) 6.58 ENVIRONMENTAL Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range -30°C to +60°C (-22°F to +140°F) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Relative Humidity 5-95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 STANDARDS & COMPLIANCE Product Certifications RETIE (Colombia); NOM (Mexico); UL 62368-1 Product Compliance RoHS; FCC Part 15 Class A (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDU3MV6H50
物料型号:PDU3MV6H50 器件简介:这是 Tripp Lite 系列的 12.6kW 三相本地计量型 PDU,适用于 208V 电压,具有 36 个 C13 和 9 个 C19 插座。
引脚分配:总共有 45 个 208V 插座,其中 36 个 C13 和 9 个 C19。
参数特性:支持 3 相 208V 输入,最大输入安培数为 35A,具有 12.6kVA 的总容量,每个断路器输出负载银行最大 20A,C19 插座最大 16A,C13 插座最大 12A。
功能详解:具有 3 个内置电流表,可连续报告所有 3 个输出相位的负载电流;附带 Hubbell CS8365C 50A $(3P+E)$ 208V 三相输入插头和 6 英尺/1.8 米线缆。
应用信息:适用于需要本地计量和高电流容量的数据中心和网络机房。
封装信息:垂直安装形式,0U 机架安装,支持工具自由安装在按钮安装兼容的机架中,附带安装支架和备用安装按钮。
PDU3MV6H50 价格&库存
很抱歉,暂时无法提供与“PDU3MV6H50”相匹配的价格&库存,您可以联系我们找货
