PDUMH30NET
PDUMH30NET
    TRIPPLITE
    PDU SWITCHED 5-15/20R 16 OUTLET
PDUMH30NET 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2.9kW Single-Phase Switched PDU - LX Interface, 120V Outlets (16 5-15/20R), 10 ft. (3.05 m) Cord with L5-30P, 2U, TAA MODEL NUMBER: PDUMH30NET Highlights ● 2.9kW 120V single-phase 2U rack-mount switched PDU ● 16 controllable NEMA 5-15/20R outlets in 2 load banks ● Pre-installed WEBCARDLX with latest version of PADM20 for IPbased Auto Probe feature ● Digital ammeter for on-site load monitoring in real time ● NEMA L5-30P input with 10-ft. (3.05 m) AC power cord Package Includes 2.9kW switched PDU distributes, monitors and manages single-phase power in an IT environment. Built-in Java-free network interface helps you remotely monitor load levels to prevent overloads that cause downtime. Description The PDUMH30NET 2.9kW Single-Phase Switched PDU provides advanced network control and remote power monitoring with the ability to turn on, turn off, reboot or lock out power to each outlet. By reducing the frequency of on-site visits, these advanced remote capabilities can save you money and reduce downtime. The switched PDU features 16 individually controllable NEMA 5-15/20R outlets with included cord retention brackets to prevent cables from becoming accidentally disconnected. A 10-ft. (3.05 m) power cord with NEMA L5-30P plug connects the PDU to a compatible AC source, generator or protected UPS. The built-in Java-free HTML5-based LX Platform network interface enables full remote access for PDU status monitoring and email notifications via secure web browser, SNMP, telnet or SSH. It supports 10/100 Mbps auto-sensing for optimum communication with an Ethernet network. Optional EnviroSense2 modules (sold separately) provide a variety of environmental monitoring capabilities. Protocols supported include IPv4, IPv6, HTTP, HTTPS, SMTP, SNMPv1, SNMPv2, SNMPv3, telnet, SSH, FTP, DHCP, BOOTP and NTP. A digital ammeter allows you to monitor each load bank's current and the total connected PDU load in real time to ensure they remain well below maximum capacity with no danger of overload. The switched PDU mounts in 2U of space in EIA-standard 19-inch racks using the included hardware or beneath a counter with user-supplied screws. Features Distributes, Monitors and Manages Network-Grade AC Power2.9kW 120V switched PDU with singlephase inputNEMA L5-30P plug with 10-ft. (3.05 m) cord connects to compatible AC power sourceFirmware upgrades support future product enhancements 16 Switched NEMA 5-15/20R Outlets Distribute AC PowerIndividual outlets can be remotely controlled to power up, power down, reboot or lock out devicesIncluded cord retention brackets prevent cables from becoming accidentally disconnected Digital AmmeterReports current for each load bank and total connected PDU load Built-In LX Platform InterfacePre-installed WEBCARDLX with the latest version of PowerAlert Device 1/4 ● PDUMH30NET 2.9kW SinglePhase Switched PDU ● Built-in LX Platform interface ● Configuration cable ● Cord retention brackets ● (16) Cable ties ● Rack-mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Manager firmware (PADM20) provides enhanced remote management capabilitiesPADM20 and PowerAlert Element Manager (PAEM) form a powerful tool for expanding maintenance functions in large installations, including firmware update checks and backup and restoration of device configurationsIPbased Auto Probe detects lost connectivity and restores service autonomously Essential Safety FeaturesTiered access allows administrator and guest to log in via web browserImmediate alert notifications via email or SNMP trapsSupports user-specified alarm notification thresholdsReal-time clock backup maintains day/date even if PDU is unpowered Easy 2U Installation in EIA-Standard 19 in. RacksRack-mounting hardware included for front- or rearfacing installationUnder-counter mounting also available with included hardware and user-supplied screws TAA-CompliantCompliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332139313 PDU Type Switched INPUT PDU Input Voltage 120 Recommended Electrical Service Single-phase 30A 120V service Maximum Input Amps 24 Maximum Input Amps Details Agency de-rated to 24A continuous PDU Plug Type NEMA L5-30P Input Phase Single-Phase Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 OUTPUT Output Capacity Details 2.88kW (120V) / 24A total capacity; 20A max per breakered load bank; 16A max per outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (16) 5-20R Output Nominal Voltage 120V Overload Protection Two 20A breakers protect 8 outlets each Customized Load Management Receptacles Each outlet is individually controllable via remote interface USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Digital current display with toggle switch reports output load level in 3 segments (Bank 1: Outlets #1-8, Bank 2: Outlets #9-16, Bank 3: All outlets combined) 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Front Panel LEDs 16 power availability LEDs confirm power off/on status for each built-in outlet. Two additional LEDs with toggle button identify which bank the visual current meter is reporting (Bank 1, Bank 2 or Bank 1&2 combined); WEBCARDLX: Link/Activity LED (Yellow), Network Speed (Green), LX operational status LED (Green)) Switches Toggle switch advances the digitial display to report output current on Bank 1, Bank 2 or Banks 1&2 combined;  WEBCARDLX : Recessed reset switch to reboot or reset network card to factory defaults SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported 2U rackmount. Includes 2U mounting accessories for 4 post and 2 post rack installation Minimum Required Rack Depth (cm) 44.45 Minimum Required Rack Depth (inches) 17.5 PDU Form Factor Horizontal (2U) Shipping Dimensions (hwd / in.) 7.80 x 16.80 x 19.80 Shipping Dimensions (hwd / cm) 19.81 x 42.67 x 50.29 Shipping Weight (lbs.) 17.30 Shipping Weight (kg) 7.85 Unit Dimensions (hwd / in.) 3.500 x 17.500 x 12.500 Unit Dimensions (hwd / cm) 8.9 x 44.5 x 31.75 Unit Weight (lbs.) 13.8 Unit Weight (kg) 6.26 ENVIRONMENTAL Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range -30°C to +50°C (-22°F to +122°F) Relative Humidity 5-95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 COMMUNICATIONS PowerAlert Software LX Platform Interface: PowerAlert Device Manager Communications Cable Micro-USB- to-USB A configuration/console Access cable Network Monitoring Port RJ45 Network port, Micro-USB Configuration port, USB A port supports a variety of Envirosense2 environmental and control modules. See Accessories>Management Hardware section for more information about these modules. SNMP Compatibility Pre-installed LX platform interface provides remote monitoring via Java-free HTML5 web interface, telnet, SSH and SNMP management systems 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet) FEATURES & SPECIFICATIONS High Availability PDU Features Auto Probe Monitoring and Reboot (included); Auto Load Shedding STANDARDS & COMPLIANCE Product Certifications NOM (Mexico); UL 60950-1 Product Compliance RoHS; FCC Part 15 Class A (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
PDUMH30NET 价格&库存
很抱歉,暂时无法提供与“PDUMH30NET”相匹配的价格&库存,您可以联系我们找货
