PDUMH30HVAT
PDUMH30HVAT
    TRIPPLITE
    PDU METERED ATS 208V 240V 30A
PDUMH30HVAT 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 5.8kW Single-Phase Local Metered Automatic Transfer Switch PDU, Two 200-240V L6-30P Inputs, 16-C13 2-C19 & 1 L6-30R Outlet, 2U, TAA MODEL NUMBER: PDUMH30HVAT Highlights ● Single phase 24A 200-240V Auto Transfer Switch / ATS Local Metered PDU with Solid State Switching ● Enables redundant-power configurations for single-corded network devices ● Separate primary & secondary inputs connect to any two compatible power sources ● 2U horizontal rackmount; 2 L630P inputs; 19 outlets (16 C13, 2 C19, 1 L6-30R) ● Front panel digital display with LED indicators reports output amps in 4 loading segments, plus total kW and input voltage ● Trade Agreements Act / TAA Compliant for GSA Schedule purchases Package Includes Features ● 200-240V 30A Automatic Transfer Switch (ATS) / Local Metered PDU (Agency de-rated to 24A continuous) ● ATS features provide redundant power for critical network equipment with a single input power cord ● Digital display with selection button reports voltage, amperage and kilowatt loading information in four output segments (Segment 1: 8 C13 & 1 C19 outlets / Segment 2: 8 C13 & 1 C19 outlets / Segment 3: L6-30R outlet / Segment 4: total output of all outlets combined) ● 19 built-in outlets (16 C13, 2 C19, 1 L6-30R) ● Set of Plug-lock output power cable retention sleeves prevent accidental disconnection of connected devices ● Set of two 10-ft. / (3.05 m) NEMA L6-30P input cables support connection to separate PRIMARY and SECONDARY power sources ● ATS circuits normally maintain output sourced from the primary input cable; As primary input power fails or becomes unstable, the ATS will switch to maintain output as sourced from the secondary input cable until power on the primary input is restored and stable ● ATS configurations enable fault-tolerant, hot-swappable UPS protection when used with a single UPS and fully redundant UPS protection when each cord is connected to a separate UPS system (in a 2 UPS environment, the primary input must be connected to an online double conversion UPS similar to Tripp Lite SmartOnline series) ● Advanced ATS configurations utilizing separate mains circuits, backup generators and even separate out of phase utility power grid feeds are fully supported ● On-board ATS processor constantly evaluates power quality on both inputs to prevent transfer to the secondary source when unavailable or of lower quality than the primary source ● Super-fast switchover between primary and secondary power sources occurs in 1-5 milliseconds ● Front panel LEDs confirm power availability on both input lines ● Trade Agreements Act / TAA Compliant for GSA Schedule purchases Specifications 1/3 ● Auto Transfer Switch PDU ● Rackmount installation brackets ● Plug-lock cable retention sleeves ● Installable plug-retention shelves & cable ties 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332159212 PDU Type Local Metered; Auto-Transfer Switch INPUT PDU Input Voltage 200; 208; 220; 230; 240 Recommended Electrical Service Two single-phase 30A 200-240V circuits Maximum Input Amps 24 Maximum Input Amps Details Agency de-rated to 24A continuous PDU Plug Type (2) NEMA L6-30P Input Phase Single-Phase Input Cord Details Set of two inputs connect to separate PRIMARY and SECONDARY power sources Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 OUTPUT Output Capacity Details 5.8kW (240V), 5.5kW (230V), 5.3kW (220V), 5kW (208V), 4.8kW (200V) total capacity / 30A max (Agency de-rated to 24A), 24A max per L6-30R outlet; 20A max per breakered outlet bank; 16A max per C19 outlet; 12A max per C13 outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (16) C13; (2) C19; (1) L6-30R Output Nominal Voltage 200-240V Overload Protection Includes two 20A output circuit breakers; Breaker 1 controls the upper row of 9 outlets (8 C13, 1 C19); Breaker 2 controls the lower row of outlets (8 C13, 1 C19); L6-30R outlet is unbreakered USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Digital display reports output amps in 4 separately metered loading segments (BANK 1: Outlets #1-9; BANK 2: Outlets #10-18; BANK 3: Outlet #19), whole-PDU output kW load level and input voltage on primary and secondary input lines Front Panel LEDs Front panel LEDs confirms amp / kilowatt / voltage reporting information Switches ENTER and MODE switches toggle the digital display to show output amps (Banks 1-4), total kW output and input voltage (primary, secondary) SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported 2U rackmount Minimum Required Rack Depth (cm) 40.64 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Minimum Required Rack Depth (inches) 16 PDU Form Factor Horizontal (2U) Shipping Dimensions (hwd / in.) 7.70 x 16.70 x 19.30 Shipping Dimensions (hwd / cm) 19.56 x 42.42 x 49.02 Shipping Weight (lbs.) 20.30 Shipping Weight (kg) 9.21 Unit Dimensions (hwd / in.) 3.500 x 17.500 x 12.500 Unit Dimensions (hwd / cm) 8.8 x 44.4 x 31.7 Unit Weight (lbs.) 13.7 Unit Weight (kg) 6.21 ENVIRONMENTAL Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range -30°C to +50°C (-22°F to +122°F) Relative Humidity 5-95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 FEATURES & SPECIFICATIONS High Availability PDU Features Auto-Transfer Switching STANDARDS & COMPLIANCE Product Certifications NOM (Mexico); UL 60950-1 Product Compliance RoHS; FCC Part 15 Class A (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDUMH30HVAT 价格&库存
很抱歉,暂时无法提供与“PDUMH30HVAT”相匹配的价格&库存,您可以联系我们找货
