PDU3VN3G30
PDU3VN3G30
    TRIPPLITE
    PDU 3-PHASE MONITORED 208V 8.6KW
PDU3VN3G30 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 10kW 3-Phase Monitored PDU, 200/208/240V Outlets (42 C13 & 6 C19), IEC-309 30A Blue, 3 ft. (0.91 m) Cord, 0U Vertical, TAA MODEL NUMBER: PDU3VN3G30 Highlights ● Ideal for 3-phase configurations in high-density data centers ● 3-phase input and single-phase 200/208/240V output ● 48 outlets (42 C13, 6 C19) in 3 load banks with 20A breakers ● Ethernet network interface for full remote access 24/7 ● Digital LED display for local load monitoring Package Includes ● PDU3VN3G30 10kW 200/208/240V 3-Phase Monitored PDU, 3 ft. cord ● (42) C13/C14 plug-lock inserts ● (6) C19/C20 plug-lock inserts ● Spare mounting buttons ● (2) Conventional mounting brackets ● Configuration cable for network interface ● Button/bracket-mounting hardware ● Owner’s manual High-capacity 10kW PDU powers high-density data center equipment racks. LED display and Ethernet interface help you monitor load levels with billing-grade accuracy to prevent PDU and circuit overloads that cause downtime. Features Distributes Network-Grade Power ● 42 C13 and 6 C19 outlets distribute network-grade power to connected equipment ● 3 load banks with individual 20A circuit breakers ● Outlets numbered and color-coded for easy identification of phase and load bank Multi-Function Digital LED Display ● Indicates amps, watts, volts, power unbalance percentage, as well as selected input phase, load bank, output power and sensor option ● Rotates 180° for overhead or raised-floor power feeds Advanced Network Monitoring ● Built-in SNMPWEBCARD enables full remote access for power monitoring, configuration and control via secure web browser, telnet or SSH ● Real-time load/current data with billing-grade accuracy (+/- 1%) ● Tiered access allows administrator and guest to log in ● Automated alerts help prevent accidental overloads, power loss and downtime ● Optional ENVIROSENSE module (sold separately) monitors temperature and humidity conditions Broad Communications Compatibility ● Supports HTTP, HTTPS, PowerAlert, SMTP, SNMPv1, SNMPv2, SNMPv3, telnet, SSH, FTP, DHCP, BOOTP and NTP ● Network settings can be automatically or manually assigned via permanent IP addresses 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Connects to AC Power Source ● IEC-309 30A Blue (3P+E) input plug with 3 ft. cord for connection to mains power source, generator or protected UPS ● Plug-lock inserts keep equipment power cords connected to outlets Ready for Immediate 0U Toolless Rack-Mounting ● Pre-installed buttons for toolless mounting in compatible EIA-standard 2-post and 4-post racks ● Conventional 0U installation possible with included mounting hardware TAA-Compliant ● Complies with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332195517 PDU Type Monitored INPUT PDU Input Voltage 200; 208; 240 Recommended Electrical Service 30A 208/240V with IEC309 30A Blue (3P+E) outlet Maximum Input Amps 24 Maximum Input Amps Details Agency de-rated to 24A continuous PDU Plug Type IEC-309 30A BLUE (3P+E) Input Phase 3-Phase Input Cord Details Cord length specifications are nominal and subject to manufacturing variance Input Cord Length (ft.) 3 Input Cord Length (m) 0.91 OUTPUT Output Capacity Details 10kW (240V), 9.6kW (230V), 9.1kW (220V), 8.6kW (208V), 8.3kW (200V) total capacity; 13.9A max per breakered outlet bank; 12A max per C13 outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (42) C13; (6) C19 Output Nominal Voltage 200; 208; 240 Overload Protection 3 20A circuit breakers, one per output load bank USER INTERFACE, ALERTS & CONTROLS 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Reported Load Segments Reports input current per phase (L1, L2, L3) and output current for each breakered load bank (13.9A balanced max per banks B1-B3); Outlets are color-coded and labeled for phase and load bank identification; L1-L2 feeds black outlets (B1); L2-L3 feeds dark-gray outlets (B2); L3-L1 feeds light-gray outlets (B3) Front Panel LCD Display Large digital display reports Amperage, Kilowatts, Voltage, Unbalance percentage, Temperature* and Humidity* information (*requires ENIVIROSENSE option); Small digital display provides detail on the measurement the large display is reporting: Input-phase (L#), Load bank (B#), Sensor (S#), Load unbalance (UB), Output power (OP) Front Panel LEDs Set of 6 LEDs identify the value displayed on the large digital display: Amperage (A), Kilowatts (kW), Voltage (V), Unbalance percentage (%UB), Temperature (T), Humidity (%RH); One additional LED for each output load bank (B1-B3) offers information power availability: GREEN (80% load), RED (Power OFF), RED FLASHING (Power OFF/breaker trip) Switches Set of UP/DOWN arrow buttons scroll through available Input, Bank, Power, Load balance and Sensor options; Additional MODE button advances the LEDs to view the next measurement Current Measurement Accuracy (Amps) +/-1% Voltage Measurement Accuracy (Volts) +/-1% Power Measurement Accuracy (Watts) +/-1% SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported Vertical rackmount installation supported with included mounting brackets; supports tooless mounting in buttonmount compatible racks PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 6.89 x 9.65 x 75.87 Shipping Dimensions (hwd / cm) 17.50 x 24.51 x 192.71 Shipping Weight (lbs.) 20.11 Shipping Weight (kg) 9.12 Unit Dimensions (hwd / in.) 70.000 x 2.170 x 2.860 Unit Dimensions (hwd / cm) 177.8 x 5.512 x 7.264 Unit Weight (lbs.) 15.19 Unit Weight (kg) 6.89 ENVIRONMENTAL Operating Temperature Range 32 to 122F (0C to 50C) Storage Temperature Range 5 to 140F (-15 to 60C) Relative Humidity 5-95% non condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States COMMUNICATIONS PowerAlert Software SNMPWEBCARD Interface: PowerAlert 12 Communications Cable RJ45-to-DB9 configuration/console Access cable Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet) FEATURES & SPECIFICATIONS High Availability PDU Features Remote Network Notifications STANDARDS & COMPLIANCE Product Certifications UL 60950-1; NOM (Mexico) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
PDU3VN3G30
物料型号:TRIPP·LITE PDU3VN3G30
器件简介: 这款PDU(电源分配单元)是10kW的三相监测型PDU,适用于200/208/240V的电源环境,配备42个C13和6个C19插座,支持IEC-309 30A蓝色插头,附带3英尺(0.91米)的电源线,为0U垂直安装设计。
引脚分配: - 42个C13插座和6个C19插座分布在3个负载银行中,每个银行有20A的断路器保护。
- 插座编号并采用颜色编码,以便于识别相位和负载银行。
参数特性: - 电源输入为三相,接受200/208/240V输入,最大输入电流为24A。
- 输出能力为10kW(240V),9.6kW(230V),9.1kW(220V),8.6kW(208V),8.3kW(200V)。
- 支持50/60Hz的频率兼容性。
- 过载保护由3个20A的断路器提供,每个输出负载银行一个。
功能详解: - 该PDU具备网络级电力分配功能,拥有数字LED显示屏,可以显示电流、功率、电压、功率不平衡百分比等信息。
- 支持通过SNMP/WEBCARD进行远程监控和控制,具有实时负载/电流数据,准确度为±1%。
- 支持多种通讯协议,包括HTTP、HTTPS、PowerAlert、SMTP、SNMPv1/2/3、telnet、SSH、FTP、DHCP、BOOTP和NTP。
应用信息: - 适用于高密度数据中心的三相配置,支持全天候远程监控。
- 适合需要大量C13和C19插座的设备,例如服务器、网络交换机等。
封装信息: - 为垂直机架安装设计,支持工具免费安装在兼容的EIA标准2柱和4柱机架上。
- 产品的物理尺寸为7.000 x 2.170 x 2.860英寸(177.8 x 5.512 x 7.264厘米)。
- 产品重量为15.19磅(6.89千克)。
以上信息摘自PDF文档,提供了对TRIPP·LITE PDU3VN3G30的详细技术规格和功能描述。
PDU3VN3G30 价格&库存
很抱歉,暂时无法提供与“PDU3VN3G30”相匹配的价格&库存,您可以联系我们找货
