1000 Eaton Boulevard
Cleveland, OH 44122
United States
7.4kW Single-Phase Switched PDU, 230V Outlets
(20 C13, 4 C19), IEC309 32A Blue, 10ft Cord, 0U
Vertical, TAA Compliant
Highlights
Switched 32A 230V PDU; 0U
Vertical Rackmount
Reports voltage, frequency &
loading information via ethernet
interface
Visual current meter; Toolless
button mount installation
Attached 10ft / 3m input cord
with IEC309 32A (2P+E) input
24 switched outlets (20 C13; 4
C19); cord retention brackets
Temperature, humidity and
contact-closure monitoring
options
TAA Compliant
MODEL NUMBER: PDUMV32HVNET
Package Includes
Description
Tripp Lite Switched PDU / Power Distribution Unit offers advanced network control and monitoring with the
ability to turn on, turn off, recycle or lock-out power to each individual receptacle, monitor site electrical
conditions and remotely monitor output power consumption. PowerAlert interface supports remote control
and custom notification of user-specified conditions via email, PowerAlert Console Launcher, SNMP,
Telnet or SSH interface. Individually switched outlets can be controlled in real-time to remotely reboot
unresponsive network hardware, or be custom programmed for user-defined power-up and power-down
sequences to ensure proper startup of interdependent IT systems and prevent inrush-related overloads as
network equipment is first energized. Unused PDU outlets can be electronically locked off to prevent the
connection of unauthorized hardware. PDU output current consumption in amps is displayed locally via
visual meter and remotely via network interface to warn of potential overloads before critical IT mains or
branch breakers trip.
Features
230V Switched PDU with built-in network interface in 0U 70 inch / 178 cm vertical rackmount form
factor; 32A maximum capacity
Attached 10ft / 3m line cord with IEC309 32A (2P+E) plug-in connection
24 switched outlets (20 C13; 4 C19)
Supports power-on, power-off or reboot of each outlet on a real-time or programmable basis
Enables reboot of locked equipment, custom power-on/power-off sequences, load-shedding of optional
loads and disabling unused outlets
Network interface provides PDU control and data regarding input voltage, frequency and loading
information
Digital display reports load level information in amps in 3 segments (bank 1, bank 2 and total)
Supports user-specified alarm notification thresholds
In-rack environmental reporting with optional ENVIROSENSE temperature / humidity sensor and rack
1/4
Rackmount PDU
Rackmount brackets
PDUMVROTATEBRKT
mounting accessory
Cleveland, OH 44122
United States
access notification with up to 4 optional SRSWITCH door sensors
DHCP/Manual configuration support
10/100 Mbps auto-sensing
Real-time clock backup maintains the time of day and date even if the PDU is unpowered
Tiered access privileges allow an administrator and a guest to login simultaneously
Alert notifications via email or SNMP traps offer immediate event notification
Firmware upgrade ability supports future product enhancements
Supports HTTP, HTTPS, PowerAlert Network Management System, SMTP, SNMPv1, SNMPv2,
SNMPv3, Telnet, SSH, FTP, DHCP, BOOTP, NTP protocols
Fully compatible with FREE PowerAlert Network Management System / NMS Software
Included cord retention brackets
Toolless mounting supported in button-mount compatible racks
Included PDUMVROTATEBRKT enables space saving toolless installation in button-mount compatible
racks with PDU outlets facing the rear
Federal Trade Agreements Act / TAA Compliant for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332153968
PDU Type
Switched
INPUT
Recommended Electrical Service
32A 230V
Maximum Input Amps
32
PDU Plug Type
IEC-309 32A BLUE (2P+E)
Input Phase
Single-Phase
Input Cord Length (ft.)
10
Input Cord Length (m)
3.05
OUTPUT
Output Capacity Details
7.7kW (240V), 7.4kW (230V), 7kW (220V), 6.7kW (208V), 6.4kW (200V) / 32A total capacity; 16A max per
breakered outlet bank; 16A max per C19 outlet; 10A max per C13 outlet
Frequency Compatibility
50 / 60 Hz
Output Receptacles
(20) C13; (4) C19
Output Nominal Voltage
230
Overload Protection
Two 20A circuit breakers protect 12 outlets each
Customized Load Management
Receptacles
Each outlet is individually controllable via remote interface
USER INTERFACE, ALERTS & CONTROLS
2/4
Cleveland, OH 44122
United States
Front Panel LCD Display
Digital display reports output amps in 3 separately metered loading segments (BANK 1: Outlets #1-12; BANK 2:
Outlets #13-24; BANK 3: All outlets combined)
Front Panel LEDs
24 power availability LEDs confirm power off/on status for each built-in outlet
Switches
Pushbutton control scrolls visual load meter display from bank 1, bank 2 and band 1&2 combined
SURGE / NOISE SUPPRESSION
Automatic Shut-Off
No
PHYSICAL
Form Factors Supported
0U vertical rackmount. Includes mounting brackets. Supports toolless mounting in button-mount compatible racks
PDU Form Factor
Vertical (0U)
Shipping Dimensions (hwd / in.)
5.43 x 6.57 x 73.31
Shipping Dimensions (hwd / cm)
13.79 x 16.69 x 186.21
Shipping Weight (lbs.)
16.71
Shipping Weight (kg)
7.58
Unit Dimensions (hwd / in.)
4.250 x 2.200 x 69.920
Unit Dimensions (hwd / cm)
177.8 x 5.6 x 12.1
Unit Weight (lbs.)
11.5
Unit Weight (kg)
5.22
ENVIRONMENTAL
Relative Humidity
5-95% non-condensing
Operating Elevation (ft.)
0-10,000
Operating Elevation (m)
0-3000
COMMUNICATIONS
PowerAlert Software
SNMPWEBCARD Interface: PowerAlert 12
Communications Cable
RJ45-to-DB9 configuration/console Access cable
SNMP Compatibility
Yes, pre-installed SNMPWEBCARD provides remote monitoring via PowerAlert Console Launcher, Telnet, SSH,
and SNMP management systems. Remote management gives user ability to turn connected loads on or off
individually
Network Compatibility
10 Mbps; 100 Mbps (Fast Ethernet)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
3/4
Cleveland, OH 44122
United States
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
