PDUMV30HVNET
PDUMV30HVNET
    TRIPPLITE
    PDU SWITCHED 208V 240V 30A C13
PDUMV30HVNET 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 5/5.8kW Single-Phase Switched PDU, 208/240V Outlets (20-C13 and 4-C19), L6-30P, 10ft Cord, 0U Vertical, TAA Highlights ● Switched 30A 208/240V PDU; 70in / 178cm 0u Vertical Rackmount ● Reports voltage, frequency & loading information via ethernet interface ● Visual current meter; Toolless button mount installation ● 10ft / 3m cord with L6-30P input plug ● 24 switched outlets (20 C13, 4 C19); cord retention brackets ● Temperature, humidity and contact-closure monitoring options ● TAA Compliant MODEL NUMBER: PDUMV30HVNET Package Includes Description Tripp Lite Switched PDU / Power Distribution Unit offers advanced network control and monitoring with the ability to turn on, turn off, recycle or lock-out power to each individual receptacle, monitor site electrical conditions and remotely monitor output power consumption. PowerAlert interface supports remote control and custom notification of user-specified conditions via email, secure web, SNMP, Telnet or SSH interface. Individually switched outlets can be controlled in real-time to remotely reboot unresponsive network hardware, or be custom programmed for user-defined power-up and power-down sequences to ensure proper startup of interdependent IT systems and prevent inrush-related overloads as network equipment is first energized. Unused PDU outlets can be electronically locked off to prevent the connection of unauthorized hardware. PDU output current consumption in amps is displayed locally via visual meter and remotely via web/network interface to warn of potential overloads before critical IT mains or branch breakers trip. Features ● 208/240V Switched PDU with built-in web/network interface in 0U 70 inch / 178cm vertical rackmount form factor; 30A maximum capacity (agency de-rated to 24 amps) ● 10 ft. / 3m cord with L6-30P input plug ● 24 switched outlets (20 C13; 4 C19) ● Supports power-on, power-off or reboot of each outlet on a real-time or programmable basis ● Enables reboot of locked equipment, custom power-on/power-off sequences, load-shedding of optional loads and disabling unused outlets ● Network interface provides PDU control and data regarding input voltage, frequency and loading information ● Digital display reports output load in amps in 3 segments (load bank 1, load bank 2, total) ● Display also supports IP-address self-identification and 180 degree display rotation ● Supports user-specified alarm notification thresholds 1/4 ● Rackmount PDU ● Rack mounting brackets ● Owner's manual ● PDUMVROTATEBRKT mounting accessory 1000 Eaton Boulevard Cleveland, OH 44122 United States ● In-rack environmental reporting with optional ENVIROSENSE temperature / humidity sensor and rack access notification with up to 4 optional SRSWITCH door sensors ● DHCP/Manual configuration support ● 10/100 Mbps auto-sensing ● Real-time clock backup maintains the time of day and date even if the PDU is not powered on ● Tiered access privileges allow an administrator and a guest to login via web browser ● Alert notifications via email or SNMP traps offer immediate event notification ● Firmware upgrade ability supports future product enhancements ● Supports HTTP, HTTPS, PowerAlert Network Management System, SMTP, SNMPv1, SNMPv2, SNMPv3, Telnet, SSH, FTP, DHCP, BOOTP, NTP protocols ● Fully compatible with FREE PowerAlert Network Management System / NMS Software ● Included cord retention brackets ● Toolless mounting supported in button-mount compatible racks ● Included PDUMVROTATEBRKT enables space saving toolless installation in button-mount compatible racks with PDU outlets facing the rear ● Federal Trade Agreements Act / TAA Compliant for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332139740 PDU Type Switched INPUT Recommended Electrical Service 30A 208/240V Maximum Input Amps 30 Maximum Input Amps Details Agency de-rated to 24A continuous PDU Plug Type NEMA L6-30P Input Phase Single-Phase Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 OUTPUT Output Capacity Details 5.8kW (240V), 5kW (208V), 4.8kW (200V) total capacity / 30A max (Agency de-rated to 24A), 20A max per breakered outlet bank; 16A max per C19 outlet; 12A max per C13 outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (20) C13; (4) C19 Output Nominal Voltage 200; 208; 240 Overload Protection Two 20A breakers protect 12 outlets each Customized Load Management Receptacles Each outlet is individually controllable via remote interface 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Digital display reports output amps in 3 separately metered loading segments (BANK 1: Outlets #1-12; BANK 2: Outlets #13-24; BANK 3: All outlets combined) Front Panel LEDs 24 power availability LEDs confirm power off/on status for each built-in outlet Switches Pushbutton scroll button enables local power consumption display of each load bank, display rotate and display IP address functions SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Form Factors Supported 0U vertical rackmount. Includes mounting brackets. Supports toolless mounting in button-mount compatible racks PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 5.00 x 6.20 x 73.00 Shipping Dimensions (hwd / cm) 12.70 x 15.75 x 185.42 Shipping Weight (lbs.) 15.60 Shipping Weight (kg) 7.08 Unit Dimensions (hwd / in.) 70.000 x 2.190 x 2.650 Unit Dimensions (hwd / cm) 177.8 x 5.6 x 6.7 Unit Weight (lbs.) 11.5 Unit Weight (kg) 5.22 ENVIRONMENTAL Relative Humidity 0-95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 COMMUNICATIONS PowerAlert Software SNMPWEBCARD Interface: PowerAlert 12 Communications Cable RJ45-to-DB9 configuration/console Access cable SNMP Compatibility Yes, pre-installed SNMPWEBCARD provides remote monitoring via web, telnet, and SNMP management systems. Remote management gives user ability to turn connected loads on or off individually Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
PDUMV30HVNET 价格&库存
很抱歉,暂时无法提供与“PDUMV30HVNET”相匹配的价格&库存,您可以联系我们找货
