PDU3VN6G30B
PDU3VN6G30B
    TRIPPLITE
    PDU 3-PHASE MONITORED
PDU3VN6G30B 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 10kW 3-Phase Monitored PDU, 200-240V Outlets (42-C13, 6-C19), IEC-309 30A Blue, 6 ft. (1.8m) Cord, 0U Vertical, TAA MODEL NUMBER: PDU3VN6G30B Highlights ● Monitored 10kW 3 Phase 200240V output PDU in 70 in. / 178cm 0U vertical mounting format ● Reports voltage and load perphase via built in ethernet interface ● 1% billing-grade accuracy, Multifunction digital display, Environmental monitoring options ● Blue IEC-309 30A (3P+E) 200240V 3 phase input; 6-ft. (1.83 m) line cord ● 42 C13 & 6 C19 single phase outlets; Plug-lock cable retention sleeves ● TAA Compliant Package Includes Features ● 10kW 3 phase 200-240V output Monitored Power Distribution Unit / PDU with built-in web/network interface ● Attached Blue IEC-309 30A (3P+E) 200-240V 3 phase input plug with 6 ft. / 1.8m cord ● 0U, 70 in. / 178cm vertical form factor supports installation in 2 or 4 post equipment racks ● 48 total outlets (42 C13, 6 C19) arranged in three breakered single phase output load banks ● Network interface provides PDU data regarding input voltage and per-phase load levels with +/-1% billing-grade accuracy ● Lighted display with scroll-button reports power consumption in amps for all 3 loading banks, IP-address self-identification and 180 degree display rotation for overhead or raised floor power feeds ● Built-in SNMP/ethernet interface reports voltage and PDU loading per-phase via network or secure web browser interface with options for user specified alarm and notification thresholds ● Supports in-rack environmental reporting with optional ENVIROSENSE temperature / humidity sensor and rack access notification with up to 4 optional SRSWITCH door sensors ● DHCP/Manual configuration support ● 10/100 Mbps auto-sensing allows optimal communication with 10/100 Base-T networks ● Real-time clock backup maintains the time of day and date even if the PDU is unpowered ● Tiered access privileges allow an administrator and a guest to login via web browser for monitoring ● Alert notifications via email or SNMP traps offer immediate event notification ● Firmware upgrade ability supports future product enhancements ● Supports HTTP, HTTPS, PowerAlert Network Management System, SMTP, SNMPv1, SNMPv2, SNMPv3, Telnet, SSH, FTP, DHCP, BOOTP, NTP protocols ● Fully compatible with FREE PowerAlert Network Management System / NMS Software ● Included set of plug-lock inserts keep C14 & C20 power cords solidly connected to PDU outlets ● Toolless mounting supported in button-mount compatible racks, plus nut-and-bolt mounting brackets for other mounting applications (set of 2 9mm buttons pre-installed, 2 9mm and 4 6mm spare buttons included) 1/4 ● Monitored rackmount PDU with pre-installed mounting buttons ● Spare installation buttons (2 9mm / 4 6mm) ● Rack mounting brackets ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Federal Trade Agreements Act / TAA Compliant for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332182951 PDU Type Monitored INPUT PDU Input Voltage 200-240V Recommended Electrical Service Three-phase 30A 200-240V service Maximum Input Amps 24 Maximum Input Amps Details Agency de-rated to 24A continuous PDU Plug Type IEC-309 30A BLUE (3P+E) Input Phase 3-Phase Input Cord Length (ft.) 6 Input Cord Length (m) 1.83 OUTPUT Output Capacity Details 10kW (240V), 9.6kW (230V), 9.1kW (220V), 8.6kW (208V), 8.3kW (200V) total capacity; 13.9A max per breakered outlet bank; 12A max per C13 outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (42) C13; (6) C19 Output Nominal Voltage 200-240V Overload Protection 3 20A circuit breakers, one per output load bank USER INTERFACE, ALERTS & CONTROLS Reported Load Segments Reports input current per phase (L1, L2, L3) and output current for each breakered load bank (13.9A balanced max per banks B1-B3); Outlets are color-coded and labeled for phase and load bank identification; L1-L2 feeds black outlets (B1); L2-L3 feeds dark-gray outlets (B2); L3-L1 feeds light-gray outlets (B3) Front Panel LCD Display Large digital display reports Amperage, Kilowatts, Voltage, Unbalance percentage, Temperature* and Humidity* information (*requires ENIVIROSENSE option); Small digital display provides detail on the measurement the large display is reporting: Input-phase (L#), Load bank (B#), Sensor (S#), Load unbalance (UB), Output power (OP) Front Panel LEDs Set of 6 LEDs identify the value displayed on the large digital display: Amperage (A), Kilowatts (kW), Voltage (V), Unbalance percentage (%UB), Temperature (T), Humidity (%RH); One additional LED for each output load bank (B1-B3) offers information power availability: GREEN (80% load), RED (Power OFF), RED FLASHING (Power OFF/breaker trip) Switches Set of UP/DOWN arrow buttons scroll through available Input, Bank, Power, Load balance and Sensor options; Additional MODE button advances the LEDs to view the next measurement Current Measurement Accuracy (Amps) +/-1% 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Voltage Measurement Accuracy (Volts) +/-1% Power Measurement Accuracy (Watts) +/-1% SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported Vertical rackmount installation supported with included mounting brackets; supports tooless mounting in buttonmount compatible racks PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 6.89 x 9.65 x 75.87 Shipping Dimensions (hwd / cm) 17.50 x 24.51 x 192.71 Shipping Weight (lbs.) 21.96 Shipping Weight (kg) 9.96 Unit Dimensions (hwd / in.) 70.000 x 2.170 x 2.860 Unit Dimensions (hwd / cm) 177.8 x 5.5 x 7.3 Unit Weight (lbs.) 15.20 Unit Weight (kg) 6.89 ENVIRONMENTAL Operating Temperature Range 0C ~ 50C (32F ~ 122F) Storage Temperature Range -30°C to +60°C (-22°F to +140°F) Relative Humidity 5-95% non condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 COMMUNICATIONS PowerAlert Software SNMPWEBCARD Interface: PowerAlert 12 Communications Cable RJ45-to-DB9 configuration/console Access cable Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
PDU3VN6G30B 价格&库存
很抱歉,暂时无法提供与“PDU3VN6G30B”相匹配的价格&库存,您可以联系我们找货
