PDU3VN6G60B
PDU3VN6G60B
    TRIPPLITE
    PDU 3-PHASE MONITORED
PDU3VN6G60B 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 14.5kW 3-Phase Monitored PDU, 200/208/240V Outlets (42-C13, 6-C19), IEC-309 60A Blue, 6ft Cord, 0U Vertical, TAA MODEL NUMBER: PDU3VN6G60B Highlights ● Monitored 14.5kW 3 Phase 200/208/240V PDU in 70 in. / 178cm 0U vertical mounting format ● Reports voltage and load perphase via built in ethernet interface ● 1% billing-grade accuracy, Multifunction digital display, Environmental monitoring options ● IEC-309 Blue 60A 200/208/240V 3 phase input; 6 ft. / 1.8m line cord ● 42 C13 & 6 C19 single phase outlets; Plug-lock cable retention sleeves ● Temperature, humidity and contact closure monitoring options ● TAA Compliant Package Includes ● Monitored rackmount PDU with pre-installed mounting buttons ● Spare installation buttons (2 9mm / 4 6mm) ● Rack mounting brackets ● Owner's manual Description Tripp Lite 3 phase Monitored PDU / Power Distribution Unit offers real-time remote monitoring of voltage and load levels via built-in network connection. PowerAlert interface supports custom notification of userspecified remote conditions via email, secure web, SNMP, Telnet or SSH interface. PDU output current consumption in amps is displayed per-phase via front panel lighted digital display and can be monitored remotely to warn of potential overloads before critical IT mains breakers trip. Features ● 14.5kW 3 phase 200/208/240V Monitored Power Distribution Unit / PDU with built-in web/network interface ● IEC-309 Blue 60A 200/208/240V 3 phase input plug with 6 ft. / 1.8m cord ● 0U, 70 in. / 178cm vertical form factor supports installation in 2 or 4 post equipment racks ● 48 total 200/208/240V outlets (42 C13, 6 C19) arranged in three breakered single phase output load banks ● Network interface provides PDU data regarding input voltage and per-phase load levels with +/-1% billing-grade accuracy ● Lighted display with scroll-button reports power consumption in amps for all 3 loading banks, IP-address self-identification and 180 degree display rotation for overhead or raised floor power feeds ● Built-in SNMP/ethernet interface reports voltage and PDU loading per-phase via network or secure web browser interface with options for user specified alarm and notification thresholds ● Supports in-rack environmental reporting with optional ENVIROSENSE temperature / humidity sensor and rack access notification with up to 4 optional SRSWITCH door sensors ● DHCP/Manual configuration support ● 10/100 Mbps auto-sensing allows optimal communication with 10/100 Base-T networks ● Real-time clock backup maintains the time of day and date even if the PDU is unpowered ● Tiered access privileges allow an administrator and a guest to login via web browser for monitoring ● Alert notifications via email or SNMP traps offer immediate event notification 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Firmware upgrade ability supports future product enhancements ● Supports HTTP, HTTPS, PowerAlert Network Management System, SMTP, SNMPv1, SNMPv2, SNMPv3, Telnet, SSH, FTP, DHCP, BOOTP, NTP protocols ● Fully compatible with FREE PowerAlert Network Management System / NMS Software ● Included set of plug-lock inserts keep C14 & C20 power cords solidly connected to PDU outlets ● Toolless mounting supported in button-mount compatible racks, plus nut-and-bolt mounting brackets for other mounting applications (set of 2 9mm buttons pre-installed, 2 9mm and 4 6mm spare buttons included) ● Federal Trade Agreements Act / TAA Compliant for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332184900 PDU Type Monitored INPUT Recommended Electrical Service 60A 208/240V with IEC309 60A Blue (3P+E) outlet Maximum Input Amps 35 Maximum Input Amps Details Agency de-rated to 35A continuous PDU Plug Type IEC-309 60A BLUE (3P+E) Input Phase 3-Phase Input Cord Length (ft.) 6 Input Cord Length (m) 1.83 OUTPUT Output Capacity Details 14.5kW (240V), 13.9kW (230V), 13.3kW (220V), 12.6kW (208V), 12.1kW (200V) total capacity; 20A max per breakered outlet bank; 16A max per C19 outlet; 12A max per C13 outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (42) C13; (6) C19 Output Nominal Voltage 200; 208; 240 Overload Protection 3 20A circuit breakers, 1 per outlet bank USER INTERFACE, ALERTS & CONTROLS Reported Load Segments Reports input current per phase (L1, L2, L3) and output current for each breakered load bank (20A balanced max per banks B1-B3); Outlets are color-coded and labeled for phase and load bank identification; L1-L2 feeds black outlets (B1); L2-L3 feeds dark-gray outlets (B2); L3-L1 feeds light-gray outlets (B3) Front Panel LCD Display Large digital display reports Amperage, Kilowatts, Voltage, Unbalance percentage, Temperature* and Humidity* information (*requires ENIVIROSENSE option); Small digital display provides detail on the measurement the large display is reporting: Input-phase (L#), Load bank (B#), Sensor (S#), Load unbalance (UB), Output power (OP) 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Front Panel LEDs Set of 6 LEDs identify the value displayed on the large digital display: Amperage (A), Kilowatts (kW), Voltage (V), Unbalance percentage (%UB), Temperature (T), Humidity (%RH); One additional LED for each output load bank (B1-B3) offers information power availability: GREEN (80% load), RED (Power OFF), RED FLASHING (Power OFF/breaker trip) Switches Set of UP/DOWN arrow buttons scroll through available Input, Bank, Power, Load balance and Sensor options; Additional MODE button advances the LEDs to view the next measurement Current Measurement Accuracy (Amps) +/-1% Voltage Measurement Accuracy (Volts) +/-1% Power Measurement Accuracy (Watts) +/-1% SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported Vertical rackmount installation supported with included mounting brackets; supports tooless mounting in buttonmount compatible racks PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 6.30 x 9.70 x 75.40 Shipping Dimensions (hwd / cm) 16.00 x 24.64 x 191.52 Shipping Weight (lbs.) 25.43 Shipping Weight (kg) 11.53 Unit Dimensions (hwd / in.) 70.000 x 2.170 x 2.490 Unit Dimensions (hwd / cm) 177.8 x 5.5 x 6.3 Unit Weight (lbs.) 18.66 Unit Weight (kg) 8.46 ENVIRONMENTAL Operating Temperature Range 32 to 122F (0C to 50C) Storage Temperature Range 5 to 140F (-15C to 60C) Relative Humidity 5-95% non condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 COMMUNICATIONS PowerAlert Software SNMPWEBCARD Interface: PowerAlert 12 Communications Cable RJ45-to-DB9 configuration/console Access cable Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet) 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
PDU3VN6G60B 价格&库存
很抱歉,暂时无法提供与“PDU3VN6G60B”相匹配的价格&库存,您可以联系我们找货
