PDU3VSR10G30
PDU3VSR10G30
    TRIPPLITE
    PDU3-PHASESWITCHED208V8.6KW
PDU3VSR10G30 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 8.6kW 3-Phase Switched PDU, 208V Outlets (21 C13 & 3 C19), IEC-309 30A Blue, 10ft Cord, 0U Vertical Highlights ● Switched 8.6kW 3 Phase 208V PDU; 70 in. / 178cm 0U vertical rackmount ● Reports voltage, frequency & load per-outlet or phase via ethernet interface ● Visual current meter; Toolless button-mount installation ● IEC-309 Blue 30A (3P+E) 208V 3 phase input; 10 ft. / 3m line cord ● 21 C13 & 3 C19 single phase switched outlets with cord retention brackets ● Temperature, humidity and contact closure monitoring options MODEL NUMBER: PDU3VSR10G30 Package Includes ● Switched rackmount PDU with pre-installed mounting buttons ● Cord retention brackets ● Spare installation buttons (2 9mm / 4 6mm) ● Rack mounting brackets ● Owner's manual Description Tripp Lite 3 phase Switched PDU / Power Distribution Unit offers advanced network control and monitoring with the ability to turn on, turn off, recycle or lock-out power to each individual receptacle, monitor site electrical conditions and remotely monitor output power consumption per-phase or perreceptacle. PowerAlert interface supports remote control and custom notification of user-specified conditions via email, secure web, SNMP, Telnet or SSH interface. Individually switched outlets can be controlled in real-time to remotely reboot unresponsive network hardware, or be custom programmed for user-defined power-up and power-down sequences to ensure proper startup of interdependent IT systems and prevent inrush-related overloads as network equipment is first energized. Unused PDU outlets can be electronically locked off to prevent the connection of unauthorized hardware. PDU output current consumption in amps per-phase or per-receptacle can be displayed locally via visual meter or remotely via web/network interface to warn of potential overloads before critical IT mains or branch breakers trip. Features ● 8.6kW 3 phase 208V Switched Power Distribution Unit / PDU with built-in web/network interface ● Attached IEC-309 Blue 30A (3P+E) 208V 3 phase input; 10 ft. / 3m cord ● 0U, 70 inch / 178cm vertical form factor ● 24 switched 208V outlets (21 C13, 3 C19) in 3 single phase load banks ● Supports power-on, power-off or reboot of each outlet on a real-time or programmable basis ● Enables reboot of locked equipment, custom power-on/power-off sequences, load-shedding of optional loads and disabling unused outlets ● Network interface provides PDU control and data regarding input voltage, per-outlet and per-phase load levels ● Digital display with scroll-buttons supports per-outlet or per-phase load levels, IP-address selfidentification and 180 degree display rotation ● Supports user-specified alarm notification thresholds 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States ● In-rack environmental reporting with optional ENVIROSENSE temperature / humidity sensor and rack access notification with up to 4 optional SRSWITCH door sensors ● DHCP/Manual configuration support ● 10/100 Mbps auto-sensing ● Real-time clock backup maintains the time of day and date even if the PDU is unpowered ● Tiered access privileges allow an administrator and a guest to login via web browser ● Alert notifications via email or SNMP traps offer immediate event notification ● Firmware upgrade ability supports future product enhancements ● Supports HTTP, HTTPS, PowerAlert Network Management System, SMTP, SNMPv1, SNMPv2, SNMPv3, Telnet, SSH, FTP, DHCP, BOOTP, NTP protocols ● Fully compatible with FREE PowerAlert Network Management System / NMS Software ● Included cord retention brackets ● Toolless mounting supported in button-mount compatible racks, plus nut-and-bolt mounting brackets for other mounting applications (set of 2 9mm buttons pre-installed, 2 9mm and 4 6mm spare buttons included) ● Nut-and-bolt mounting support for other racks ● TAA Compliant version available - Order Tripp Lite PDU3VSR10G3TAA Specifications OVERVIEW UPC Code 037332153616 PDU Type Switched INPUT Recommended Electrical Service 30A 208V with IEC309 30A Blue (3P+E) outlet Maximum Input Amps 24 Maximum Input Amps Details Agency de-rated to 24A continuous PDU Plug Type IEC-309 30A BLUE (3P+E) Input Phase 3-Phase Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 OUTPUT Output Capacity Details 8.6kW (208V) total capacity; 13.9A max per output phase (L1-L2, L2-L3, L3-L1), 12A max per C13 outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (21) C13; (3) C19 Output Nominal Voltage 208 Overload Protection 3 20A circuit breakers, one per output load bank Customized Load Management Receptacles Each outlet is individually controllable via remote interface 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States USER INTERFACE, ALERTS & CONTROLS Reported Load Segments Supports local monitoring of current for each output phase (13.9A max per L1-L2, L2-L3, L3-L1 balanced) and for each output receptacle; BANK "L1" is powered by L1-L2 (outlets 1-8); BANK "L2" is powered by L2-L3 (outlets 9-16); BANK "L3" is powered by L3-L1 (outlets 17-24) Front Panel LCD Display Digital display reports output load level in amps separately for each output phase and each individual output receptacle; Can also be used to scroll the configured IP address Front Panel LEDs Digital display reports output load level in amps separately for each output phase and each individual output receptacle; Can also be used to scroll the configured IP address Switches SELECT switch advances the digital display and LED to report power consumption for load segments L1, L2, L3 and for each individual output receptacle (short press); SELECT switch also rotates the local display 90 degrees for overhead power input (long press); SCROLL IP button scrolls the configured IP address (long press) Current Measurement Accuracy (Amps) +/-1% Voltage Measurement Accuracy (Volts) +/-1% Power Measurement Accuracy (Watts) +/-1% SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported Vertical rackmount installation supported with included mounting brackets; supports tooless mounting in buttonmount compatible racks PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 7.20 x 9.65 x 75.86 Shipping Dimensions (hwd / cm) 18.29 x 24.51 x 192.68 Shipping Weight (lbs.) 21.53 Shipping Weight (kg) 9.77 Unit Dimensions (hwd / in.) 70.000 x 2.200 x 3.580 Unit Dimensions (hwd / cm) 177.8 x 5.6 x 8.3 Unit Weight (lbs.) 14.35 Unit Weight (kg) 6.51 ENVIRONMENTAL Storage Temperature Range 5 to 122F (-15 to 50C) Relative Humidity 5-95% non condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 COMMUNICATIONS 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States PowerAlert Software SNMPWEBCARD Interface: PowerAlert 12 Communications Cable RJ45-to-DB9 configuration/console Access cable SNMP Compatibility Yes, pre-installed SNMPWEBCARD provides remote monitoring via web, telnet, SSH and SNMP management systems Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet) STANDARDS & COMPLIANCE TAA Compliant Option TAA Compliant version available - Order Tripp Lite PDU3VSR10G3TAA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
PDU3VSR10G30
物料型号:PDU3VSR10G30
器件简介:Tripp Lite的3相开关型PDU具有高级网络控制和监控功能,可以远程开启、关闭、重启或锁定每个单独的插座,监控现场电气条件,并远程监控每相或每个插座的输出功率消耗。
引脚分配:包含21个C13和3个C19单相开关插座。
参数特性:8.6kW总容量,每相最大13.9A,每个C13插座最大12A。
功能详解:支持实时或可编程基础上每个插座的开启、关闭或重启,可重新启动锁定的设备,自定义开启/关闭序列,负载削减和禁用未使用的插座。
应用信息:适用于需要远程控制和监控电源分配的IT系统。
封装信息:0U垂直机架安装,附带安装按钮,IEC-309 Blue 30A (3P+E) 208V 3相输入,10英尺/3米电源线。
PDU3VSR10G30 价格&库存
很抱歉,暂时无法提供与“PDU3VSR10G30”相匹配的价格&库存,您可以联系我们找货
