PDUMVR30NET
PDUMVR30NET
    TRIPPLITE
    PDUSWITCHED5-15/20R24OUTLET
PDUMVR30NET 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2.9kW Single-Phase Switched PDU with Outlet Level Metering, 120V Outlets (24 5-15/20R), L530P, 10ft Cord, 0U Vertical, TAA Compliant Highlights ● Switched 30A 120V PDU, 0U 70 in. / 178cm Vertical Rackmount Format ● Reports voltage, frequency & load per-outlet or load bank via ethernet interface ● Visual current meter, Toolless button mount installation ● NEMA L5-30P input, attached 10 ft. / 3m cord ● 24 switched NEMA 5-15/20R outlets with cord retention brackets ● Temperature, humidity and contact closure monitoring options ● Federal Trade Agreements Act / TAA Compliant for GSA Schedule purchases MODEL NUMBER: PDUMVR30NET Package Includes Description Tripp Lite single phase Switched PDU / Power Distribution Unit with individual outlet metering offers advanced network control and monitoring with the ability to turn on, turn off, recycle or lock-out power to each individual receptacle, monitor site electrical conditions and remotely monitor output power consumption for each individual outlet. Built-in current monitoring offers 1% billing grade accuracy. PowerAlert interface supports remote control and custom notification of user-specified conditions via email, PowerAlert Console Launcher, SNMP, Telnet or SSH interface. Individually switched outlets can be controlled in real-time to remotely reboot unresponsive network hardware, or be custom programmed for user-defined power-up and power-down sequences to ensure proper startup of interdependent IT systems and prevent inrush-related overloads as network equipment is first energized. Unused PDU outlets can be electronically locked off to prevent the connection of unauthorized hardware. PDU output current consumption in amps is continuously displayed locally via visual meter and remotely via network interface to warn of potential overloads before critical IT mains or branch breakers trip. Specifications OVERVIEW UPC Code 037332166944 PDU Type Switched INPUT Recommended Electrical Service 30A 120V 1/3 ● Rackmount PDU ● Rackmount brackets ● PDUMVROTATEBRKT 1000 Eaton Boulevard Cleveland, OH 44122 United States Maximum Input Amps 30 Maximum Input Amps Details Agency de-rated to 24A continuous PDU Plug Type NEMA L5-30P Input Phase Single-Phase Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 OUTPUT Output Capacity Details 3.05kW (127V), 2.88kW (120V), 2.4kW (100V) / 30A total capacity (Agency de-rated 24A); 20A max per breakered load bank; 16A max per outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (24) 5-15/20R Output Nominal Voltage 100-127V nominal, single phase Overload Protection Two 20A breakers protect 12 outlets each Customized Load Management Receptacles Each outlet is individually controllable via remote interface USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Digital display reports load level in amps for LOAD BANK 1 (Outlets 1-12), LOAD BANK 2 (Outlets 13-24), LOAD BANKS 1&2 COMBINED (Outlets 1-24) and each individual output receptacle; Digital display can also be used to scroll the configured IP address Front Panel LEDs BANK 1 and BANK 2 LEDs verify which load bank the digital current display is reporting (Bank 1, Bank 2 or Banks 1&2 Combined); BANK 1 or BANK 2 LED will flash when the digital display is reporting output current for one of the outlets in that load bank; 24 additional LEDs, one near each output receptacle, will light continuously to verify power on/off status and flash to indicate that the digital display is reporting output current for just that individual receptacle Switches SELECT OUTLET and SELECT BANK switches advance the LCD screen and associated LED to display power consumption for individual output receptacles and output load banks; Press and hold the SELECT BANK button for 4 seconds to rotate the digital display 90 degrees for overhead power input; Press and hold the SELECT OUTLET button for 4 seconds to scroll the configured IP address SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Form Factors Supported 0U vertical rackmount; includes rackmount brackets. Supports toolless mounting in button-mount compatible racks PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 5.40 x 6.80 x 76.10 Shipping Dimensions (hwd / cm) 13.72 x 17.27 x 193.29 Shipping Weight (lbs.) 16.10 Shipping Weight (kg) 7.30 Unit Dimensions (hwd / in.) 70.000 x 2.200 x 2.050 Unit Dimensions (hwd / cm) 178 x 5.6 x 5.2 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Weight (lbs.) 10.2 Unit Weight (kg) 4.63 ENVIRONMENTAL Storage Temperature Range 5 to 122F (-15 to 50C) Relative Humidity 5-95% non condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 COMMUNICATIONS PowerAlert Software SNMPWEBCARD Interface: PowerAlert 12 Communications Cable RJ45-to-DB9 configuration/console Access cable SNMP Compatibility Built-in network interface provides remote monitoring via PowerAlert Console Launcher, Telnet, SSH, and SNMP management systems. Remote management enables outlets to be turned on and off individually Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDUMVR30NET
物料型号:PDUMVR30NET
器件简介: Tripp Lite的PDUMVR30NET是一款单相开关式PDU(电源分配单元),提供先进的网络控制和监控功能。
它允许对每个单独的插座进行开启、关闭、重启或锁定断电操作,并监测现场电气条件,以及远程监控每个单独插座的输出功耗。
内置的电流监测提供1%的双极精度。
PowerAlert界面支持通过电子邮件、PowerAlert控制台启动器、SNMP、Telnet或SSH界面远程控制和自定义通知用户指定条件。
引脚分配: 该PDU有24个NEMA 5-15/20R插座,分为两个输出负载组(1-12和13-24),每个插座都可以通过远程接口单独控制。
参数特性: - 支持通过以太网接口报告每个插座或负载组的电压、频率和负载。
- 具有可视电流表,无需工具即可安装的按钮式安装NEMA L5-30P输入,附带10英尺/3米长的线缆。
- 支持温度、湿度和接触闭合监测选项。
- 符合联邦贸易协定法案/TAA,适用于GSA计划购买。
功能详解: - 前面板LCD显示屏可报告负载组1(插座1-12)、负载组2(插座13-24)和负载组1&2合并(插座1-24)的负载水平,以及每个单独的输出插座的负载水平。
数字显示屏还可用于滚动显示配置的IP地址。
- 前面板LED灯可验证数字电流显示器报告的是哪个负载组的电流(负载组1、负载组2或负载组1&2合并)。
应用信息: 适用于需要远程控制和监控电源分配的数据中心和网络设备,可以远程重启不响应的网络硬件,或自定义编程用户定义的上电和断电序列,以确保相互依赖的IT系统的正确启动,并防止在网络设备首次通电时因电流冲击而超载。
封装信息: - 垂直机架安装格式,0U高度。
- 包括机架安装支架。
- 支持在兼容按钮式安装的机架中无需工具安装。
- 发货尺寸为5.40x6.80x76.10英寸,重量为16.10磅。
- 单元尺寸为70.00x2.20x2.05英寸,重量为10.2磅。
PDUMVR30NET 价格&库存
很抱歉,暂时无法提供与“PDUMVR30NET”相匹配的价格&库存,您可以联系我们找货
