PDU3VSR10L1530
PDU3VSR10L1530
    TRIPPLITE
    PDU3-PHASESWITCHED208V8.6KW
PDU3VSR10L1530 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 8.6 kW 3-Phase Switched PDU, 208V (21 C13 & 3 C19), L15-30P, 10ft Cord, 0U Vertical MODEL NUMBER: PDU3VSR10L1530 Highlights ● Switched 8.6kW 3 Phase 208V PDU; 70 in. / 178cm 0U vertical rackmount ● Reports voltage, frequency & load per-outlet or phase via ethernet interface ● Visual current meter; Toolless button-mount installation ● NEMA L15-30P 30A (3P+E) 208V 3 phase input; 10 ft. / 3m line cord ● 21 C13 & 3 C19 single phase switched outlets with cord retention brackets ● Temperature, humidity and contact closure monitoring options Package Includes Description ● Switched rackmount PDU with pre-installed mounting buttons ● Plug retention plates ● Spare installation buttons (2 9mm / 4 6mm) ● Rack mounting brackets ● Owner's manual Tripp Lite 3 phase Switched PDU / Power Distribution Unit offers advanced network control and monitoring with the ability to turn on, turn off, recycle or lock-out power to each individual receptacle, monitor site electrical conditions and remotely monitor output power consumption per-phase or perreceptacle. PowerAlert interface supports remote control and custom notification of user-specified conditions via email, secure web, SNMP, Telnet or SSH interface. Individually switched outlets can be controlled in real-time to remotely reboot unresponsive network hardware, or be custom programmed for user-defined power-up and power-down sequences to ensure proper startup of interdependent IT systems and prevent inrush-related overloads as network equipment is first energized. Unused PDU outlets can be electronically locked off to prevent the connection of unauthorized hardware. PDU output current consumption in amps per-phase or per-receptacle can be displayed locally via visual meter or remotely via web/network interface to warn of potential overloads before critical IT mains or branch breakers trip. Features ● 8.6kW 3 phase 208V Switched Power Distribution Unit / PDU with built-in web/network interface ● Attached NEMA L15-30P 30A (3P+E) 208V 3 phase input; 10 ft. / 3m cord ● 0U, 70 inch / 178cm vertical form factor ● 24 switched 208V outlets (21 C13, 3 C19) in 3 single phase load banks ● Supports power-on, power-off or reboot of each outlet on a real-time or programmable basis ● Enables reboot of locked equipment, custom power-on/power-off sequences, load-shedding of optional loads and disabling unused outlets ● Network interface provides PDU control and data regarding input voltage, per-outlet and per-phase load levels ● Digital display with scroll-buttons supports per-outlet or per-phase load levels, IP-address selfidentification and 180 degree display rotation ● Supports user-specified alarm notification thresholds ● In-rack environmental reporting with optional ENVIROSENSE temperature / humidity sensor and rack access notification with up to 4 optional SRSWITCH door sensors 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States ● DHCP/Manual configuration support ● 10/100 Mbps auto-sensing ● Real-time clock backup maintains the time of day and date even if the PDU is unpowered ● Tiered access privileges allow an administrator and a guest to login via web browser ● Alert notifications via email or SNMP traps offer immediate event notification ● Firmware upgrade ability supports future product enhancements ● Supports HTTP, HTTPS, PowerAlert Network Management System, SMTP, SNMPv1, SNMPv2, SNMPv3, Telnet, SSH, FTP, DHCP, BOOTP, NTP protocols ● Fully compatible with FREE PowerAlert Network Management System / NMS Software ● Included cord retention brackets ● Toolless mounting supported in button-mount compatible racks, plus nut-and-bolt mounting brackets for other mounting applications (set of 2 9mm buttons pre-installed, 2 9mm and 4 6mm spare buttons included) ● Nut-and-bolt mounting support for other racks ● TAA Compliant Version Available - Order Tripp Lite PDU3VSR10L13TAA Specifications OVERVIEW UPC Code 037332149787 PDU Type Switched INPUT Recommended Electrical Service 30A 208V with NEMA L15-30R outlet Maximum Input Amps 24 Maximum Input Amps Details Agency de-rated to 24A continuous PDU Plug Type NEMA L15-30P Input Phase 3-Phase Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 OUTPUT Output Capacity Details 8.6kW (208V) total capacity; 13.9A max per output phase (L1-L2, L2-L3, L3-L1), 12A max per C13 outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (21) C13; (3) C19 Output Nominal Voltage 208 Overload Protection 3 20A double-pole circuit breakers (1 per output phase) Customized Load Management Receptacles Each outlet is individually controllable via remote interface USER INTERFACE, ALERTS & CONTROLS 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Reported Load Segments Supports local monitoring of current for each output phase (13.9A max per L1-L2, L2-L3, L3-L1, balanced) and for each output receptacle; BANK "L1" is powered by L1-L2 (outlets 1-8); BANK "L2" is powered by L2-L3 (outlets 9-16); BANK "L3" is powered by L3-L1 (outlets 17-24) Front Panel LCD Display Digital display reports output load level in amps separately for each output phase and each individual output receptacle; Can also be used to scroll the configured IP address Front Panel LEDs Set of 3 LEDs (L1, L2, L3) indicate the output load segment the digital current display is reporting; LEDs for L1, L2, L3 will also flash to indicate that the display is reporting current level for one of the outlets in that load bank; One additional LED per output receptacle indicates power ON/OFF status for that outlet Switches SELECT switch advances the digital display and LED to report power consumption for load segments L1, L2, L3 and for each individual output receptacle (short press); SELECT switch also rotates the local display 90 degrees for overhead power input (long press); SCROLL IP button scrolls the configured IP address (long press) Current Measurement Accuracy (Amps) +/-1% Voltage Measurement Accuracy (Volts) +/-1% Power Measurement Accuracy (Watts) +/-1% SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported Vertical rackmount installation supported with included mounting brackets; supports toolless mounting in buttonmount compatible racks PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 7.00 x 9.70 x 75.10 Shipping Dimensions (hwd / cm) 17.78 x 24.64 x 190.75 Shipping Weight (lbs.) 19.90 Shipping Weight (kg) 9.03 Unit Dimensions (hwd / in.) 70.000 x 2.200 x 3.580 Unit Dimensions (hwd / cm) 177.8 x 5.6 x 8.3 Unit Weight (lbs.) 13.2 Unit Weight (kg) 5.99 ENVIRONMENTAL Storage Temperature Range 5 to 122F (-15 to 50C) Relative Humidity 0-95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 COMMUNICATIONS PowerAlert Software SNMPWEBCARD Interface: PowerAlert 12 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Communications Cable RJ45-to-DB9 configuration/console Access cable SNMP Compatibility Yes, pre-installed SNMPWEBCARD provides remote monitoring via web, telnet, SSH and SNMP management systems Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet) STANDARDS & COMPLIANCE TAA Compliant Option TAA Compliant Version Available - Order Tripp Lite PDU3VSR10L13TAA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
PDU3VSR10L1530
物料型号:PDU3VSR10L1530
器件简介:Tripp Lite的3相可切换PDU(电源分配单元),提供8.6千瓦的功率,适用于208V环境,具有21个C13和3个C19插座,支持远程控制和监测。
引脚分配:该PDU有24个可控制的208V插座,分为3个单相负载组,其中21个为C13,3个为C19。
参数特性: - 支持每相或每个插座的电流消耗显示,最大每相13.9A,每个C13插座最大12A。
- 支持50/60 Hz的频率兼容性。
- 具有3个20A双极断路器,每个输出相位一个。
- 每个插座都可以通过远程接口单独控制。
功能详解: - 提供远程控制和监测,可以远程重启不响应的网络硬件,或自定义编程电源开启和关闭序列。
- 可以电子锁定未使用的PDU插座,以防止未经授权的硬件连接。
- 支持通过以太网接口报告每个插座或相位的电压、频率和负载。
- 具有数字显示和滚动按钮,支持每插座或每相位的负载水平显示,IP地址自我识别和180度显示旋转。
应用信息:适用于需要远程控制和监测电源分配的数据中心和网络设备。
封装信息:垂直安装,0U机架式,支持工具自由安装在按钮安装兼容的机架中,或使用螺母和螺栓安装在其他机架上(预装2个9mm按钮,额外包括2个9mm和4个6mm备用按钮)。
PDU3VSR10L1530 价格&库存
很抱歉,暂时无法提供与“PDU3VSR10L1530”相匹配的价格&库存,您可以联系我们找货
