PDU3VSR10H50
PDU3VSR10H50
    TRIPPLITE
    PDU3-PHASESWITCHED208V12.6KW
PDU3VSR10H50 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 12.6kW 3-Phase Switched PDU, 208V Outlets (21 C13 & 3 C19), Hubbell 50A CS8365C, 10ft Cord, 0U Vertical Highlights ● Switched 12.6kW 3 Phase 208V PDU; 70 in. / 178cm 0U vertical rackmount ● Reports voltage, frequency & load per-outlet or phase via ethernet interface ● Visual current meter; Toolless button-mount installation ● 50A Hubbell CS8365C 208V 3 phase input; 10 ft. / 3m line cord ● 21 C13 & 3 C19 single phase switched outlets with cord retention brackets ● Temperature, humidity and contact closure monitoring options MODEL NUMBER: PDU3VSR10H50 Package Includes ● Switched rackmount PDU with pre-installed mounting buttons ● Plug retention plates ● Spare installation buttons (2 9mm / 4 6mm) Description ● Rack mounting brackets Tripp Lite 3 phase Switched PDU / Power Distribution Unit offers advanced network control and ● Owner's manual monitoring with the ability to turn on, turn off, recycle or lock-out power to each individual receptacle, monitor site electrical conditions and remotely monitor output power consumption per-phase or perreceptacle. PowerAlert interface supports remote control and custom notification of user-specified conditions via email, secure web, SNMP, Telnet or SSH interface. Individually switched outlets can be controlled in real-time to remotely reboot unresponsive network hardware, or be custom programmed for user-defined power-up and power-down sequences to ensure proper startup of interdependent IT systems and prevent inrush-related overloads as network equipment is first energized. Unused PDU outlets can be electronically locked off to prevent the connection of unauthorized hardware. PDU output current consumption in amps per-phase or per-receptacle can be displayed locally via visual meter or remotely via web/network interface to warn of potential overloads before critical IT mains or branch breakers trip. Features ● 12.6kW 3 phase 208V Switched Power Distribution Unit / PDU with built-in web/network interface ● Attached 50A Hubbell CS8365C 208V 3 phase input; 10 ft. / 3m cord ● 0U, 70 inch / 178cm vertical form factor ● 24 switched 208V outlets (21 C13, 3 C19) in 3 single phase load banks ● Supports power-on, power-off or reboot of each outlet on a real-time or programmable basis ● Enables reboot of locked equipment, custom power-on/power-off sequences, load-shedding of optional loads and disabling unused outlets ● Network interface provides PDU control and data regarding input voltage, per-outlet and per-phase load levels ● Digital display with scroll-buttons supports per-outlet or per-phase load levels, IP-address selfidentification and 180 degree display rotation ● Supports user-specified alarm notification thresholds 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States ● In-rack environmental reporting with optional ENVIROSENSE temperature / humidity sensor and rack access notification with up to 4 optional SRSWITCH door sensors ● DHCP/Manual configuration support ● 10/100 Mbps auto-sensing ● Real-time clock backup maintains the time of day and date even if the PDU is unpowered ● Tiered access privileges allow an administrator and a guest to login via web browser ● Alert notifications via email or SNMP traps offer immediate event notification ● Firmware upgrade ability supports future product enhancements ● Supports HTTP, HTTPS, PowerAlert Network Management System, SMTP, SNMPv1, SNMPv2, SNMPv3, Telnet, SSH, FTP, DHCP, BOOTP, NTP protocols ● Fully compatible with FREE PowerAlert Network Management System / NMS Software ● Included cord retention brackets ● Toolless mounting supported in button-mount compatible racks, plus nut-and-bolt mounting brackets for other mounting applications (set of 2 9mm buttons pre-installed, 2 9mm and 4 6mm spare buttons included) ● Nut-and-bolt mounting support for other racks ● TAA Compliant Version Available - Order Tripp Lite PDU3VSR10H50TAA Specifications OVERVIEW UPC Code 037332149770 PDU Type Switched INPUT Recommended Electrical Service 50A 208V with Hubbell CS8365C outlet Maximum Input Amps 35 Maximum Input Amps Details Agency de-rated to 35A continuous PDU Plug Type HUBBELL CS8365C 50A Input Phase 3-Phase Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 OUTPUT Output Capacity Details 12.6kVA (208V) total capacity; 20A max per breakered outlet bank; 16A max per C19 outlet; 12A max per C13 outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (21) C13; (3) C19 Output Nominal Voltage 208 Overload Protection 3 20A circuit breakers, 1 per outlet bank Customized Load Management Receptacles Each outlet is individually controllable via remote interface 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States USER INTERFACE, ALERTS & CONTROLS Reported Load Segments Supports local monitoring of current for each output phase (20A max per L1-L2, L2-L3, L3-L1) and for each output receptacle; BANK "L1" is powered by L1-L2 (outlets 1-8); BANK "L2" is powered by L2-L3 (outlets 9-16); BANK "L3" is powered by L3-L1 (outlets 17-24) Front Panel LCD Display Digital display reports output load level in amps separately for each output phase and each individual output receptacle; Can also be used to scroll the configured IP address Front Panel LEDs Set of 3 LEDs (L1, L2, L3) indicate the output load segment the digital current display is reporting; Individual LED for L1, L2, L3 will also flash to indicate that the display is reporting current level for one of the outlets in that load bank; One additional LED per output receptacle indicates power ON/OFF status for that outlet Switches SELECT switch advances the digital display and LED to report power consumption for load segments L1, L2, L3 and for each individual output receptacle (short press); SELECT switch also rotates the local display 90 degrees for overhead power input (long press); SCROLL IP button scrolls the configured IP address (long press) Current Measurement Accuracy (Amps) +/-1% Voltage Measurement Accuracy (Volts) +/-1% Power Measurement Accuracy (Watts) +/-1% SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported Vertical rackmount installation supported with included mounting brackets; supports tooless mounting in buttonmount compatible racks PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 6.40 x 9.70 x 75.50 Shipping Dimensions (hwd / cm) 16.26 x 24.64 x 191.77 Shipping Weight (lbs.) 24.20 Shipping Weight (kg) 10.98 Unit Dimensions (hwd / in.) 70.000 x 2.200 x 3.580 Unit Dimensions (hwd / cm) 177.8 x 5.6 x 8.3 Unit Weight (lbs.) 13.2 Unit Weight (kg) 5.99 ENVIRONMENTAL Storage Temperature Range 5 to 122F (-15 to 50C) Relative Humidity 5-95% non condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States COMMUNICATIONS PowerAlert Software SNMPWEBCARD Interface: PowerAlert 12 Communications Cable RJ45-to-DB9 configuration/console Access cable SNMP Compatibility Yes, pre-installed SNMPWEBCARD provides remote monitoring via web, telnet, SSH and SNMP management systems Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet) STANDARDS & COMPLIANCE TAA Compliant Option TAA Compliant Version Available - Order Tripp Lite PDU3VSR10H50TAA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
PDU3VSR10H50 价格&库存
很抱歉,暂时无法提供与“PDU3VSR10H50”相匹配的价格&库存,您可以联系我们找货
