1000 Eaton Boulevard
Cleveland, OH 44122
United States
27.6kW 3-Phase Switched PDU, 220/230/240V (12
C13 & 12 C19), IEC309 63A Red, 380/400/415V
Input, 6 ft. (1.83 m) Cord, 0U Vertical
Highlights
Switched 27.6kW 3-Phase
380/400/415V input,
220/230/240V output PDU
Reports voltage & load peroutlet or per phase via ethernet
interface
1% billing-grade accuracy;
Digital display reports detailed
status information
70in / 1778mm 0U vertical
format; Toolless button-mount
installation
12 C13 & 12 C19 single phase
outlets; Plug-lock cable retention
inserts
IEC309 63A Red (3P+N+E) 3
phase input; 6-ft. (1.83 m) line
cord
MODEL NUMBER: PDU3XVSR6G63A
Package Includes
Switched, vertical rackmount
PDU with pre-installed mounting
buttons
12 C13/C14 and 12 C19/C20
Plug-lock cable retention inserts
Spare installation buttons (2
9mm / 4 6mm), Mounting
brackets
Configuration cable
Owner's manual
Features
27.6kW Switched 380/400/415V input, 220/230/240V output PDU with built-in web/network interface
IEC309 63A Red (3P+N+E) 380/400/415V 3 phase input with 6 ft. / 1.8m line cord
0U, 70 inch / 178cm vertical form factor
24 switched 220/230/240V outlets (12 C13, 12 C19) in 6 separately breakered 20A single phase load
banks
Supports power-on, power-off or reboot of each outlet on a real-time or programmable basis
Enables reboot of locked equipment, custom power-on/power-off sequences, load shedding of optional
loads and disabling unused outlets
Network interface provides PDU control and data regarding input voltage and load levels per-outlet, perbreaker and per-phase
Built-in local digital display and remote web/network interface reports detailed voltage, amperage and
kilowatt output values per outlet, per breaker and per phase with additional reporting options for power
unbalance percentage, IP address and sensor based temperature and humidity data (requires
ENVIROSENSE sensor)
In-rack environmental reporting with optional ENVIROSENSE temperature / humidity sensor and rack
access notification with up to 4 optional SRSWITCH door sensors
Local display supports electronic 180 degree display rotation for overhead or under-floor input cable
orientation
Supports user-specified alarm notification thresholds
DHCP/Manual configuration support
10/100 Mbps auto-sensing
Real-time clock backup maintains the time of day and date even if the PDU is unpowered
Tiered access privileges allow an administrator and a guest to login via web browser
Alert notifications via email or SNMP traps offer immediate event notification
Firmware upgrade ability supports future product enhancements
Supports HTTP, HTTPS, PowerAlert Network Management System, SMTP, SNMPv1, SNMPv2,
SNMPv3, Telnet, SSH, FTPP, DHCP, BootP, NTP protocols
1/4
Cleveland, OH 44122
United States
Fully compatible with FREE PowerAlert Network Management System / NMS Software
Included set of Plug-lock inserts keep C14 and C20 power cords solidly connected to PDU outlets
Toolless mounting supported in button-mount compatible racks, plus nut-and-bolt mounting brackets for
other mounting applications (set of 2 9mm buttons pre-installed, 2 9mm and 4 6mm spare buttons
included)
Specifications
OVERVIEW
UPC Code
037332174291
PDU Type
Switched
INPUT
Recommended Electrical Service
63A 400/230V with IEC309 63A Red (3P+N+E) outlet
Maximum Input Amps
40
Maximum Input Amps Details
Agency de-rated to 40A continuous
PDU Plug Type
IEC-309 63A RED (3P+N+E)
Input Phase
3-Phase
Input Cord Length (ft.)
6
Input Cord Length (m)
1.83
OUTPUT
Output Capacity Details
28.8kW (415/240V), 27.7kW (400/230V), 26.3kW (380/220V) total capacity; 40A max per output phase (L1, L2, L3);
20A max per breakered outlet bank; 16A max per C19 outlet; 10A max per C13 outlet
Frequency Compatibility
50 / 60 Hz
Output Receptacles
(12) C13; (12) C19
Output Nominal Voltage
220 (380V input); 230 (400V input); 240 (415V input)
Overload Protection
6 20A circuit breakers, 1 per outlet bank
USER INTERFACE, ALERTS & CONTROLS
Reported Load Segments
Reports input current per phase (L1, L2, L3), plus output current for each output load bank (B1-B6) and individual
output receptacle (1-24); Outlets are color-coded and labeled for phase and load bank identification; L1-N feeds
black outlets (B1, B4); L2-N feeds dark-gray outlets (B2, B5); L3-N feeds light-gray outlets (B3, B6)
Front Panel LCD Display
Large digital display reports Amperage, Kilowatts, Voltage, Unbalance percentage, Temperature* and Humidity*
information (*requires ENIVIROSENSE option); Small digital display provides detail on the measurement the large
display is reporting: Input-phase (L#), Load bank (B#), Sensor (S#), Outlet (##), Load unbalance % (UB), Output
power (OP)
Front Panel LEDs
Set of 6 LEDs identify the value displayed on the large digital display: Amperage (A), Kilowatts (kW), Voltage (V),
Unbalance percentage (%UB), Temperature (T), Humidity (%RH); One additional LED for each output receptacle
offers power availability information: GREEN (Power ON, load bank capacity 80%), RED (Power OFF/undervoltage), RED FLASHING (Power OFF/breaker trip)
Switches
Set of UP/DOWN arrow buttons scroll through available Input, Bank, Power, Load balance and Sensor options;
Additional MODE button advances the LEDs to view the next measurement
2/4
Cleveland, OH 44122
United States
Current Measurement Accuracy
(Amps)
+/-1%
Voltage Measurement Accuracy
(Volts)
+/-1%
Power Measurement Accuracy
(Watts)
+/-1%
SURGE / NOISE SUPPRESSION
Automatic Shut-Off
No
PHYSICAL
Material of Construction
Metal
Form Factors Supported
Vertical rackmount installation supported with included mounting brackets; supports toolless mounting in buttonmount compatible racks
PDU Form Factor
Vertical (0U)
Shipping Dimensions (hwd / in.)
6.89 x 9.65 x 75.87
Shipping Dimensions (hwd / cm)
17.50 x 24.51 x 192.71
Shipping Weight (lbs.)
24.47
Shipping Weight (kg)
11.10
Unit Dimensions (hwd / in.)
70.000 x 2.170 x 2.520
Unit Dimensions (hwd / cm)
177.8 x 5.51 x 6.4
Unit Weight (lbs.)
17.3
Unit Weight (kg)
7.85
ENVIRONMENTAL
Operating Temperature Range
32 to 122F (0C to 50C)
Storage Temperature Range
-30°C to +60°C (-22°F to +140°F)
Relative Humidity
5-95% non condensing
Operating Elevation (ft.)
0-10,000
Operating Elevation (m)
0-3000
COMMUNICATIONS
PowerAlert Software
SNMPWEBCARD Interface: PowerAlert 12
Communications Cable
RJ45-to-DB9 configuration/console Access cable
Network Compatibility
10 Mbps; 100 Mbps (Fast Ethernet)
STANDARDS & COMPLIANCE
TAA Compliant Option
TAA Compliant version available - Order Tripp Lite PDU3XEVSR6G63A
WARRANTY & SUPPORT
3/4
Cleveland, OH 44122
United States
Product Warranty Period
(Worldwide)
2-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
