P08026
P08026
    HAMMONDMANUFACTURING
    POWER STRIP SURGE CHECK 6' 6OUT
P08026 数据手册
Plastic - Surge Check P0500 & P0800 Series P0802 (3’ Cord) & P08026 (6’ cord) • One MOV between line and neutral. • Molded with UL VO grade flame retardant plastic. • 15 Amp circuit breaker and on/off switch. • Features a surge status indicator (if light is on, the unit is protecting, if light is off, a surge has occurred and the unit should be replaced). P0803 (3’ Cord) & P08036 (6’ cord) • • • • • Part No. 6 6 6 6 Cord Length 3' 6' 4' 6' Surge Yes Yes Yes Yes Max. Spike Energy (Joules) 50 50 175 175 Status Indicator Yes Yes Yes Yes 1) Maximum spike voltage: 6,000 volts 2) Maximum spike current: 4,500 amps 3) Maximum clamping voltage: 340 volts 4) Clamping response time: less than 1 nanosecond 5) UL 1449: 500V www.hammondmfg.com EMI/RFI Yes Yes Protection Telco Coaxial - Outlet Strips with Surge Protection P0802 P08026 P0803 Home & Office P08036 Basic Outlets MOV protection in all 3 AC modes and EMI/RFI line filter. Noise attenuation: 10-35 dB@ 500Khz. - 30Mhz. Molded with UL VO grade flame retardant plastic. 15 Amp circuit breaker and lighted on/off switch. Features a surge status indicator (if light is on, the unit is protecting, if light is off, a surge has occurred and the unit should be replaced). 23
P08026 价格&库存
很抱歉,暂时无法提供与“P08026”相匹配的价格&库存,您可以联系我们找货
