Plastic - Surge Check
P0500 & P0800 Series
P0802 (3’ Cord) & P08026 (6’ cord)
• One MOV between line and neutral.
• Molded with UL VO grade flame
retardant plastic.
• 15 Amp circuit breaker and on/off switch.
• Features a surge status indicator (if
light is on, the unit is protecting, if light
is off, a surge has occurred and the unit
should be replaced).
P0803 (3’ Cord) & P08036 (6’ cord)
Part No.
6
6
6
6
Cord
Length
3'
6'
4'
6'
Surge
Yes
Yes
Yes
Yes
Max. Spike
Energy (Joules)
50
50
175
175
Status
Indicator
Yes
Yes
Yes
Yes
1) Maximum spike voltage: 6,000 volts
2) Maximum spike current: 4,500 amps
3) Maximum clamping voltage: 340 volts
4) Clamping response time: less than 1 nanosecond
5) UL 1449: 500V
www.hammondmfg.com
EMI/RFI
Yes
Yes
Protection
Telco
Coaxial
Outlet Strips with Surge Protection
P0802
P08026
P0803
Home & Office
P08036
Basic
Outlets
MOV protection in all 3 AC modes and EMI/RFI line filter.
Noise attenuation: 10-35 dB@ 500Khz. - 30Mhz.
Molded with UL VO grade flame retardant plastic.
15 Amp circuit breaker and lighted on/off switch.
Features a surge status indicator (if light is on, the unit is protecting, if light is off, a
surge has occurred and the unit should be replaced).
23
很抱歉,暂时无法提供与“P08036”相匹配的价格&库存,您可以联系我们找货
