48VDCSPLITTER
48VDCSPLITTER
    TRIPPLITE
    YSPLITTERCABLEFORSELECTTRIP
48VDCSPLITTER 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Y Splitter Cable for Select Tripp Lite Battery Packs, Blue 175A DC Connectors, 1 ft. (0.31 m) MODEL NUMBER: 48VDCSPLITTER Highlights ● Heavy-duty 4 AWG 2-conductor black cabling ● 3 blue 175A DC connectors (2 output, 1 input) ● 1-ft. (0.31 m) in length Package Includes ● Connects two Tripp Lite BP48V24-2U and other select external battery packs to a compatible UPS system to extend runtime. Description The 48VDCSPLITTER Y Splitter Cable connects two Tripp Lite external battery packs to a compatible UPS system to extend runtime. It is compatible with Tripp Lite's non-expandable BP48V24-2U and other select battery packs that specify compatibility with this cable. The 1-ft. (0.31 m) 48VDCSPLITTER is constructed using 4 AWG two-conductor black cabling. It features three blue 175A DC connectors: two outputs for the battery packs and one input for a UPS system that specifies the use of a BP48V24-2U battery pack. Features Connects 2 Select Tripp Lite Battery Packs to a Compatible UPS System ● Compatible with BP48V24-2U and other select battery packs that specify compatibility with this cable ● Heavy-duty 4 AWG 2-conductor black cabling ● 3 blue 175A DC connectors (2 output, 1 input) ● 1-ft. (0.31 m) in length Specifications OVERVIEW UPC Code 037332158468 Accessory Type Extender Accessory Class UPS Accessories INPUT Input Connection Type 175A Blue 48V DC Connector (1) 1/2 48VDCSPLITTER Y Splitter Cable, 1-ft. (0.31 m) 1000 Eaton Boulevard Cleveland, OH 44122 United States OUTPUT Output Connector Type 175A Blue 48V DC Connector (2) PHYSICAL Cable Length (ft.) 1 Cable Length (m) 0.30 Shipping Dimensions (hwd / in.) 10.00 x 10.00 x 4.00 Shipping Dimensions (hwd / cm) 25.40 x 25.40 x 10.16 Shipping Weight (lbs.) 2.00 Shipping Weight (kg) 0.91 Unit Weight (lbs.) 2 Unit Weight (kg) 0.91 WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
48VDCSPLITTER 价格&库存
很抱歉,暂时无法提供与“48VDCSPLITTER”相匹配的价格&库存,您可以联系我们找货
48VDCSPLITTER
    • 1+2107.521131+264.26458
    • 10+1791.6504910+224.65718
    • 25+1757.2831425+220.34782
    库存:1
