1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartRack 2U Hinged Wall-Mount Patch Panel
Bracket, TAA
MODEL NUMBER: N060-002
Highlights
Laser cut 14-gauge steel results
in smooth edges
Keyholes on 16-inch centers
plus through-the-wall cabling
cut-out
Accepts any standard 19inch
Patch Panels
2U Height (3.50"): 19"wide x
3.50" high x 6.0" deep
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
Package Includes
Description
Tripp Lite's heavy duty 14-gauge steel, 2U (3.50") wall mount patch panel bracket, is the ideal alternative
to a full size rack. Standard EIA 19-inch width allows installation of any 19inch patch panel. Laser cut
metal ( not punched ) keeps all edges smooth, greatly reducing the possibility of injury, and, wear on cable
jackets. Universal mounting for right or left hinging. Keyholes are spaced 16inches for mounting on wall
studs. Stamped, horizontal reinforcement ribs allow for greater sturdiness and stability, and allow the
addition of a rear cutout for feeding cable through a wall opening. Smooth, glossy black finish.
Features
2U Height (3.50"), 6inch depth
Laser cut for smooth edges
16 -inch center mounting
Universal left or right hinge mounting
Rear cut-out for through the wall cabling
Standard EIA 19inch width accepts any manufacturers EIA compliant patch panel
Smooth, black glossy finish
Heavy duty 14 gauge steel with stamped reinforcement ribs
Specifications
OVERVIEW
UPC Code
037332126399
Accessory Type
Mounting Bracket
Accessory Class
Rack Accessories
PHYSICAL
1/2
2U Wallmount Patch Panel
Bracket
Pkg 10 mounting screws
Cleveland, OH 44122
United States
Color
Black
Rack Height
2U
Maximum Device Depth (cm)
13.97
Maximum Device Depth (in.)
5.5
Maximum Device Depth (mm)
140
Shipping Dimensions (hwd / in.)
4.10 x 20.30 x 6.70
Shipping Dimensions (hwd / cm)
10.41 x 51.56 x 17.02
Shipping Weight (lbs.)
2.90
Shipping Weight (kg)
1.32
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
Unit Dimensions (hwd / cm)
8.89 x 48.26 x 15.24
Unit Weight (lbs.)
2.5
Unit Weight (kg)
1.13
Weight Capacity - Stationary (kg)
8
Weight Capacity - Stationary (lbs.)
17
STANDARDS & COMPLIANCE
Product Certifications
IEC 60297-3; NOM (Mexico); UL 60950-1
Product Compliance
DIN 41494; RoHS; EIA/ECA-310-E; Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“N060-002”相匹配的价格&库存,您可以联系我们找货
