BP240V10RT3U
BP240V10RT3U
    TRIPPLITE
    BATT PACK 240V SMART SERIE UPS
BP240V10RT3U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States External 240V 3U Rack/Tower Battery Pack Enclosure + DC Cabling for select UPS Systems (BP240V10RT3U) Highlights ● Extends the runtime of expandable 240V DC Tripp Lite UPS Systems ● Included daisychain connector supports the addition of multiple compatible external battery packs ● Supports 3U rackmount installation; 4 post installation accessories included ● Options for 2 post rackmount and tower installation available MODEL NUMBER: BP240V10RT3U Package Includes Need more runtime? The BP240V10RT3U external battery pack extends the runtime of compatible Tripp Lite UPS Systems and has a rear connector for daisy-chaining multiple battery packs together to achieve an even longer runtime. Installation is quick, simple and versatile—the battery pack can be adapted to rackmount (3U), tower or stack form factors. Description BP240V10RT3U rack/tower external battery pack offers extended battery runtime when used in conjunction with expandable 240V Tripp Lite rackmount and tower UPS systems. Includes heavy gauge cabling with high current DC connector for safe, simple installation. Included daisychain connector enables the connection of additional compatible 240V external battery packs to the host UPS. Included mounting accessories support 3U rackmount installation in 4 post racks. Options for 2 post centermounting and upright tower installation available. Compatible with these UPS Systems - SU6000RT3U, SU6000RT3UHV, SU8000RT3U, SU8000RT3U1TF, SU8000RT3UG, SU8000RT3UHW, SU8000RT3UN50, SU8000RT3UN50TF, SU10000RT3U, SU10000RT3U2TF, SU10000RT3UG, SU10KRT3U, SU10KRT3UHV, SU10K3/1INTPM, SU16KRT, SU16KRT-1TF, SU16KRT8, SU16KRTG, SU16KRTHW, SU20KRT, SU20KRT-1TF, SU20KRT8, SU20KRTG, SU20KRTHW and other Tripp Lite UPS systems that specify the use of this battery pack. Features ● Offers extended-run UPS operation when used in conjunction with compatible 240V DC Tripp Lite UPS systems ● Includes heavy gauge cabling with high current DC connectors for simple installation ● Daisychain connector enables the connection of additional compatible 240V external battery packs to the host UPS ● Included mounting brackets support rackmount installation in 4 post racks using only 3 rack spaces (3U) ● 2POSTRMKITHD option supports balanced 2 point center-mounting in 2 post equipment racks ● 2-9USTAND option enables upright tower placement Specifications 1/3 ● BP240V10RT3U external battery pack with attached DC cabling ● 4 post compatible mounting hardware ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332115843 INPUT Input Phase Single-Phase BATTERY Expandable Runtime Yes DC System Voltage (VDC) 240 UPS Connection Detachable cable with UPS specific DC connector (91.4 cm length, 6 gauge) Typical Battery Lifespan 4-6 years typical (North America) PHYSICAL Material of Construction Steel Rack Height 3U External Battery Pack Form Factor Rack/Tower Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITHD ); Tower ( 2-9USTAND ) Minimum Required Rack Depth (cm) 71.12 Minimum Required Rack Depth (inches) 28 Shipping Dimensions (hwd / in.) 11.50 x 23.00 x 33.00 Shipping Dimensions (hwd / cm) 29.21 x 58.42 x 83.82 Shipping Weight (lbs.) 184.00 Shipping Weight (kg) 83.46 Unit Dimensions (hwd / in.) 5.250 x 17.500 x 25.000 Unit Dimensions (hwd / cm) 13.34 x 44.45 x 63.5 Unit Weight (lbs.) 158.70 Unit Weight (kg) 71.99 STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe) WARRANTY & SUPPORT Product Warranty Period (U.S. & Canada) 2-year limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (International) 1-year limited warranty Product Warranty Period (Mexico) 1-year limited warranty Product Warranty Period (Puerto Rico) 1-year limited warranty Optional Coverage 3 year, 5 year, next day and on-site warranty coverage available © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
BP240V10RT3U
1. 物料型号: - 型号编号:BP240V10RT3U
2. 器件简介: - BP240V10RT3U是一个外部电池包,用于扩展与兼容的Tripp Lite不间断电源(UPS)系统的运行时间。它具有后连接器,可以将多个电池包串联在一起,以实现更长的运行时间。安装快速、简单且多功能,电池包可以适配机架式(3U)、塔式或堆叠式形态。
3. 引脚分配: - 包括与UPS特定DC连接器的可拆卸电缆(长度91.4厘米,6号线规)。
4. 参数特性: - 输入相位:单相 - 可扩展运行时间:是 - DC系统电压:240V直流 - 典型电池寿命:北美地区通常为4-6年 - 材料构成:钢 - 机架高度:3U - 外部电池包形态:机架/塔式 - 支持的安装形态:包括4柱19英寸机架安装 - 可选配件支持的安装形态:2柱机架安装(需购买配件2POSTRMKITHD);塔式安装(需购买配件2-9USTAND)
5. 功能详解: - 与兼容的240V直流UPS系统一起使用时,提供延长运行时间的UPS操作。 - 包括重型电缆和高电流DC连接器,便于简单安装。 - 支持串联连接器,可连接额外的兼容240V外部电池包至主机UPS。 - 包括的安装支架支持在4柱机架上进行3U机架安装。
6. 应用信息: - 与SU6000RT3U、SU6000RT3UHV、SU8000RT3U等UPS系统兼容,具体型号请参考文档。
7. 封装信息: - 产品符合RoHS和CE(欧洲)标准。 - 产品保修期(美国&加拿大):2年有限保修。 - 产品保修期(国际):1年有限保修。 - 产品保修期(墨西哥&波多黎各):1年有限保修。 - 可选的3年、5年、次日和现场保修服务。
BP240V10RT3U 价格&库存
很抱歉,暂时无法提供与“BP240V10RT3U”相匹配的价格&库存,您可以联系我们找货
