BP72V15-2U
BP72V15-2U
    TRIPPLITE
    BATT PACK 72V SMART SERIES UPS
BP72V15-2U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States External 72V 2U Rackmount Battery Pack for select Tripp Lite UPS Systems (BP72V15-2U) MODEL NUMBER: BP72V15-2U Highlights ● Extends the runtime of compatible 72V Tripp Lite UPS Systems ● Supports 2U rackmount installation, 4 post installation accessories included ● Options for 2 post rackmount and wallmount installation available Package Includes Description BP72V15-2U rackmount external battery pack offers extended battery runtime when used in conjunction with expandable 72V Tripp Lite rackmount and tower UPS systems. Includes heavy gauge cabling with high current DC connector for safe, simple installation. Included mounting accessories support 2U rackmount installation in 4 post racks. Options for 2 post center-mounting and wall mount installation available. Compatible with these UPS Systems - SU3000RTXL2U, SU3000RTXL3U, SU3000RTXLCD2U, SU3000RTXLCD3U, SU3000RTXR3U, SU3000RTXR3UHW, SU3000XL, SU3000XLCD, SUINT3000RTXL2U, SUINT3000RTXL3U, SU3000LCD2UHV, SUINT3000LCD2U and other Tripp Lite UPS systems that specify the use of this battery pack. Features ● Offers extended-run UPS operation when used in conjunction with compatible 72V DC Tripp Lite UPS systems ● Includes heavy gauge cabling with high current DC connectors for simple installation ● Included mounting brackets support rackmount installation in 4 post racks using only 2 rack spaces (2U) ● 2POSTRMKITWM option supports balanced 2 point center-mounting in 2 post equipment racks ● 2POSTRMKITWM option also enables wallmount installation ● NOTE: LIMIT OF 1 BP72V15-2U PER UPS, SEE BP72V18-2US or BP72V28RT-3U FOR MULTI-PACK COMPATIBILITY Specifications OVERVIEW UPC Code 037332124333 INPUT Input Phase Single-Phase 1/3 ● BP72V15-2U external battery pack with attached DC cabling ● 4 post compatible rack mounting hardware ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States BATTERY DC System Voltage (VDC) 72 UPS Connection Attached cable with black 3-point DC connector Typical Battery Lifespan 4-6 years typical (North America) PHYSICAL Material of Construction Steel Rack Height 2U External Battery Pack Form Factor Rack Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITWM ); Wallmount ( 2POSTRMKITWM ) Minimum Required Rack Depth (cm) 60.96 Minimum Required Rack Depth (inches) 24 Shipping Dimensions (hwd / in.) 10.00 x 26.00 x 28.00 Shipping Dimensions (hwd / cm) 25.40 x 66.04 x 71.12 Shipping Weight (lbs.) 120.00 Shipping Weight (kg) 54.43 Unit Dimensions (hwd / in.) 3.500 x 17.500 x 20.750 Unit Dimensions (hwd / cm) 8.9 x 52.7 x 52.7 Unit Weight (lbs.) 72.4 Unit Weight (kg) 32.84 STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe) WARRANTY & SUPPORT Product Warranty Period (U.S. & Canada) 2-year limited warranty Product Warranty Period (International) 1-year limited warranty Product Warranty Period (Mexico) 1-year limited warranty Product Warranty Period (Puerto Rico) 1-year limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
BP72V15-2U
- 物料型号:BP72V15-2U - 器件简介:这是一款适用于特定不间断电源(UPS)系统的外部72V 2U机架安装电池包。 - 引脚分配:包括带有黑色3点直流连接器的附件电缆。 - 参数特性: - 直流系统电压:72伏 - UPS连接方式:附件电缆与黑色3点直流连接器 - 典型电池寿命:北美地区通常为4-6年 - 材料:钢 - 机架高度:2U - 外部电池包形态:机架式 - 支持的安装形态:4柱19英寸机架安装 - 可选配件支持的安装形态:2柱机架安装和壁挂安装 - 最小所需机架深度:24英寸或60.96厘米 - 发货尺寸和重量:10x26x28英寸,120磅或25.4x66.04x71.12厘米,54.43公斤 - 单位尺寸和重量:3.5x17.5x20.75英寸,72.4磅或8.9x52.7x52.7厘米,32.84公斤 - 功能详解:提供与可扩展的72V机架式和塔式UPS系统联合使用的延长电池运行时间。包括厚电缆和高电流直流连接器,安装安全简单。包括的安装配件支持在4柱机架中进行2U机架安装。 - 应用信息:与SU3000RTXL2U、SU3000RTXL3U、SU3000RTXLCD3U、SU3000RTXR3U、SU3000RTXR3UHW、SU3000XL、SUINT3000RTXL2U、SUINT3000RTXL3U、SU3000LCD2UHV、SUINT3000LCD2U等UPS系统兼容,并指定使用此电池包。 - 封装信息:产品符合RoHS和CE(欧洲)标准。美国和加拿大提供2年有限保修期,国际市场提供1年有限保修期,墨西哥和波多黎各提供1年有限保修期。
BP72V15-2U 价格&库存
很抱歉,暂时无法提供与“BP72V15-2U”相匹配的价格&库存,您可以联系我们找货
