BP192V12-3U
BP192V12-3U
    TRIPPLITE
    BATT PACK 192V SMART SERIE UPS
BP192V12-3U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States External 192V 3U Rack/Tower Battery Pack for select Tripp Lite UPS Systems (BP192V12-3U) MODEL NUMBER: BP192V12-3U Highlights ● Extends the runtime of expandable 192V DC Tripp Lite UPS Systems ● Included daisychain connector supports the addition of multiple compatible external battery packs ● Supports 3U rackmount installation; 4 post installation accessories included ● Options for 2 post rackmount and tower installation available Package Includes Description Tripp Lite's BP192V12-3U rack/tower external battery pack offers extended battery runtime when used in conjunction with compatible Tripp Lite UPS systems. Multi-use form factor supports configuration in rackmount or stacking applications using only 3 rack spaces (3U). Upright tower configuration supported with optional 2-9USTAND accessory. Includes heavy-gauge cabling with high-current DC connectors for simple installation. Additional output connector allows multiple BP192V12-3U battery packs to be daisychained to the UPS for even longer extended run operation. COMPATIBLE UPS SYSTEMS - SU12KRT4UHW, SU5000RT4U, SU5000RT4UHV, SU5000RT4UTF, SU6000RT4U, SU6000RT4UHV, SU6000RT4UHVG, SU6000RT4UHVHW, SU6000RT4UTF, SU6000RT4UTFHW, SU8000RT4U and other Tripp Lite UPS systems that specify the use of this battery pack. Features ● Offers extended-run UPS operation when used in conjunction with compatible Tripp Lite UPS systems ● Supports stacking or rackmount installation using only 3 rack spaces (3U) ● Supports upright tower installation with optional 2-9USTAND accessory (holds 3 battery packs in tower configuration) ● Set of two input/output connectors allows multiple BP192V12-3U battery packs to be daisy-chained to the UPS for even longer extended run operation ● Includes heavy-gauge cabling with high-current DC connectors for simple installation Specifications OVERVIEW UPC Code 037332125903 INPUT Input Phase Single-Phase 1/3 ● BP192V12-3U external battery pack ● Mounting hardware ● Warranty information ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States UPS Input Cord Length (ft.) 3 UPS Input Cord Length (m) 0.9 OUTPUT Overload Protection 50A DC output fuse BATTERY Expandable Runtime Yes DC System Voltage (VDC) 192 UPS Connection Detachable cable with UPS specific DC connector (90 cm length, 8 gauge) Typical Battery Lifespan 4-6 years typical (North America) PHYSICAL Material of Construction Steel Rack Height 3U External Battery Pack Form Factor Rack/Tower Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITHD ); Tower ( 2-9USTAND ) Minimum Required Rack Depth (cm) 78.74 Minimum Required Rack Depth (inches) 31 Shipping Dimensions (hwd / in.) 11.00 x 23.00 x 33.00 Shipping Dimensions (hwd / cm) 27.94 x 58.42 x 83.82 Shipping Weight (lbs.) 205.83 Shipping Weight (kg) 93.36 Unit Dimensions (hwd / in.) 5.250 x 17.500 x 28.000 Unit Dimensions (hwd / cm) 13,3 x 44,5 x 71,1 Unit Weight (lbs.) 174.00 Unit Weight (kg) 78.93 STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe) WARRANTY & SUPPORT Product Warranty Period (U.S. & Canada) 2-year limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (International) 1-year limited warranty Product Warranty Period (Mexico) 1-year limited warranty Product Warranty Period (Puerto Rico) 1-year limited warranty Optional Coverage 3 year, 5 year, next day and on-site warranty coverage available © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
BP192V12-3U 价格&库存
很抱歉,暂时无法提供与“BP192V12-3U”相匹配的价格&库存,您可以联系我们找货
