APSRM
APSRM
    TRIPPLITE
    REMOTE SWITCH FOR APS INVERTER
APSRM 数据手册
Inverters & Inverter/Chargers - Remote Control Module MODEL NUMBER: APSRM Description Tripp Lite's APSRM provides remote monitoring and control of PowerVerter PLUS and PowerVerter APS Inverter systems that support the remote control module connector feature. Compact housing, mountable via 4 user supplied screws, includes 6 LEDs, a 2 position switch and detachable 50 foot remote cable with modular RJ style connectors. When used in conjunction with a PowerVerter PLUS inverter system, APSRM reports status via 3 built-in battery voltage level LEDs, 3 load level LEDs and power off/on control via built in switch. When used in conjunction with a PowerVerter APS inverter/charger/auto-transfer system, APSRM reports status via 3 built-in battery voltage level LEDs, plus 3 LED indicators for load level, inverter power and line power availability. Package ships with two user installable labels to properly identify controls when used either with a PowerVerter PLUS or PowerVerter APS system. Includes 50 foot remote cable. Features ● APSRM works in conjunction with PowerVerter PLUS and PowerVerter APS inverters that support the remote module connector feature ● Enables remote inverter power off/on control and status monitoring in applications, such as automotive or marine, where access to inverter front panel controls and indicators is not convenient or safely possible ● Built-in status LEDs indicate 7 different levels of battery charge, from low to high, plus 2 flashing programs to indicate excessive discharge or overcharge condition ● When used in conjunction with PowerVerter PLUS systems, APSRM indicates 6 levels of output load capacity, plus 1 flashing program to indicate overload condition ● When used in conjunction with PowerVerter APS systems, APSRM indicates load levels of over 90%, inverter power operation and line power operation ● Mountable with 4 user supplied screws ● Includes 50 ft cable Specifications OVERVIEW UPC Code 037332117540 Accessory Type Remote Control Module Accessory Class Power Inverter Accessories INPUT Voltage Compatibility (VDC) NA OUTPUT Pure Sine Wave Output No Nominal Output Voltage(s) Supported 100V Output Receptacles 5-15/20R 1/2 Highlights ● Intuitive "traffic light" LED readouts ● Complete remote monitoring and control Package Includes ● APSRM remote control accessory ● 50 foot control cable ● Instruction manual Continuous Output Capacity (Watts) 0 PHYSICAL Shipping Dimensions (hwd / cm) 19.68 x 20.32 x 3.81 Shipping Dimensions (hwd / in.) 7.75 x 8.00 x 1.50 Shipping Weight (kg) 0.64 Shipping Weight (lbs.) 1.40 © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
APSRM
1. 物料型号:APSRM 2. 器件简介:APSRM提供对PowerVerter PLUS和PowerVerter APS逆变器系统的远程监控和控制。它具有紧凑的外壳,可通过4个用户自供的螺丝安装,包括6个LED灯、一个2位开关和可分离的50英尺远程电缆,带有模块化RJ式连接器。 3. 引脚分配:文档中未明确提及引脚分配。 4. 参数特性: - 与支持远程模块连接器功能的PowerVerter PLUS和PowerVerter APS逆变器配合使用。 - 允许在不方便或不安全访问逆变器前面板控制和指示器的场合进行远程逆变器电源开关控制和状态监控。 - 内置状态LED显示7种不同的电池充电水平,从低到高,以及2种闪烁程序,指示过度放电或过充状态。 - 与PowerVerter PLUS系统配合使用时,APSRM显示6种输出负载容量级别,加上1种闪烁程序,指示过载状态。 - 与PowerVerter APS系统配合使用时,APSRM显示超过90%的负载水平。 5. 功能详解:APSRM可以远程控制逆变器的开关,并监控其状态,包括电池电压、负载水平、逆变器电源和市电电源的可用性。 6. 应用信息:适用于汽车或船舶等场合,这些场合不方便或不安全直接访问逆变器的前面板控制和指示器。 7. 封装信息:包括APSRM远程控制配件、50英尺控制电缆和说明书。 8. 其他规格:UPC代码037332117540,配件类型为远程控制模块,配件类别为电源逆变器配件,输入电压兼容性未明确,输出为非纯正弦波,支持的额定输出电压为100V,输出插座为5-15/20R。
APSRM 价格&库存
很抱歉,暂时无法提供与“APSRM”相匹配的价格&库存,您可以联系我们找货
