APSX6048VRNET
APSX6048VRNET
    TRIPPLITE
    INTLINVERTERCHARGER6000W48V
APSX6048VRNET 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 6000W APS X Series 48VDC 208/230V Inverter/Charger with Pure Sine-Wave Output, AVR, Hardwired MODEL NUMBER: APSX6048VRNET Highlights ● Delivers pure sine-wave AC power from AC or DC source ● 6000W continuous output power; 12000W peak power ● Auto-transfer switching option for UPS operation ● DB9 port for optional SNMPWEBSOLOHV network management ● Corrects brownouts and overvoltages without using battery power Package Includes Portable 6000W power source for power tools, computers, audio/video components and other sensitive electronics as a vehicle inverter, standalone AC power source or extended-run UPS. Optional network interface for remote monitoring operation. Description The APSX6048VRNET 6000W APS X Series 48V DC 208/230V AC Inverter/Charger is a reliable power source for a wide variety of power tools, computers, audio/video components and other sensitive electronics at mobile, emergency and remote sites. With no fumes, fuel or excess noise, it’s an excellent alternative to generator power. The DC-to-AC pure sine-wave inverter delivers clean power to sensitive electronics. Its automatic line-tobattery transfer switch and integrated charging system allow the unit to work as a vehicle inverter, standalone AC power source or extended-run UPS. It delivers 6000W of continuous power, 9000W up to one minute or 12000W of peak power up to 10 seconds during equipment startup or cycling. An automatic overload detector, cooling fan and resettable AC circuit breakers protect the unit from damage. Designed for easy installation in RVs, commercial and fleet vehicles, emergency vehicles and construction equipment, the APSX6048VRNET converts stored power from a 48V battery or automotive DC source to safe, stable, computer-grade AC power for unlimited runtime in heavy-load conditions. When hardwired to an external 208V or 230V AC source, the unit keeps the user-supplied battery charged via a three-stage 23/90A selectable charging system while simultaneously delivering conditioned, pure sine-wave AC power to connected equipment. When used as a UPS, the APSX6048VRNET responds to blackouts and brownouts with an automatic, instantaneous transfer to battery-derived, pure sine-wave AC power. The optional SNMPWEBSOLOHV accessory card enables remote monitoring of the unit via SNMP, SSH, Telnet, and Internet. Features Reliable Power for Mobile, Emergency and Remote Sites ● Generates 208/230V pure sine-wave power from 48V battery bank ● Ideal for powering variable-speed tools, computers, LEDs, fans, audio/video components and other sensitive electronics ● Designed for easy installation in RVs, fleet vehicles and emergency vehicles ● Functions as vehicle inverter, standalone AC power source or extended-run UPS ● Unlimited runtime with variety of user-supplied batteries 1/5 ● APSX6048VRNET 6000W APS X Series 48V DC 208/230V AC Inverter/Charger ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Pure Sine-Wave Power for Normal and Peak Power Demands ● 6000W of continuous power ● 9000W of reserve power up to 1 min. ● 12000W of peak power up to 10 sec. to accommodate surge power demands during equipment startup and cycling ● Automatic overload detector, cooling fan and resettable AC circuit breaker protect unit from damage ● High-current DC input terminals for simple hardwired installation Automatic Voltage Regulation ● Corrects brownouts and overvoltages without using battery power during battery charging and UPS standby modes Remote Monitoring Capability ● DB9 port for optional SNMPWEBSOLOHV, which turns the unit into a monitored network device ● Enables network monitoring via SNMP, SSH, Telnet, or the Internet Automatic Transfer Switching ● Transfer relay switches to inverter power during blackout in 10 or 20 ms ● DIP switches configure high and low voltage auto-transfer 3-Stage 23/90A Selectable Battery Charger ● Serves as battery charger when external 208V or 230V AC power is supplied and powering connected equipment ● Protects battery from overcharging and overdischarging ● Low-battery protection prevents excessive battery depletion ● DIP switches configure wet/gel charging profiles Remote Generator Starter Jack ● Connects to separate generator with user-supplied cable to automatically cycle generator when battery level is low Rugged Steel Housing ● Resists moisture, vibration, impact and high-humidity environments Specifications OVERVIEW UPC Code 037332137838 INPUT Nominal Input Voltage(s) Supported 208V AC; 230V AC Recommended Electrical Service DC INPUT: Requires 48VDC input source capable of delivering 138A for the required duration (when used at full continuous capacity - DC requirements increase during OverPower and DoubleBoost operation). For automotive applications, professional hardwire installation with 250A minimum battery system fusing is recommended. 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Input Connection Type DC INPUT: Set of DC bolt-down terminals. AC INPUT: Hardwire via built in terminal strip with cover plate Voltage Compatibility (VAC) 208; 230 Voltage Compatibility (VDC) 48 OUTPUT Frequency Compatibility 50 / 60 Hz Pure Sine Wave Output Yes Nominal Output Voltage(s) Supported 208V; 230V Output Receptacles Hardwire Continuous Output Capacity (Watts) 6000 Peak Output Capacity (Watts) 12000 Output Voltage Regulation LINE POWER (AC): Maintains 208/230V nominal sine wave output from line power source. INVERTER POWER (AC): Maintains sine wave output voltage of 208/230 VAC (+/-5%). Output Frequency Regulation 50/60 Hz (+/- 0.3 Hz) BATTERY Expandable Runtime Yes Expandable Battery Runtime Runtime is expandable with any number of user supplied wet or gel type batteries Expandable Runtime Description Runtime is expandable with any number of user supplied wet or gel type batteries DC System Voltage (VDC) 48 Battery Pack Accessory (Optional)  98-121  sealed lead acid battery (optional) Battery Charge Selectable 23 / 90A VOLTAGE REGULATION Voltage Regulation Description Includes automatic voltage regulation to correct brownouts and over-voltages back to usable levels Overvoltage Correction Input voltages above 252V are automatically reduced by 9% (230V) / Input voltages above 235/245V are automatically reduced by 10% (208V) Brownout Correction Input voltages from 208V -189V are automatically boosted by 11% (230V) / Input voltages from 188V-166V are automatically boosted 12% (208V) Severe Brownout Correction Input voltages from 188V - 171V are automatically boosted by 26% (230V only) USER INTERFACE, ALERTS & CONTROLS Front Panel LEDs Set of 6 LEDs offer continuous status information on load percentage (6 levels reported) and battery charge level (7 levels reported). See manual for sequences. Switches 3 position on/off/remote switch enables simple on/off power control plus "auto/remote" setting that enables distant on/off control of the inverter system when used in conjunction with optional  APSRM4  accessory when used in inverter mode. In AC uninterruptible power mode, "auto/remote" setting enables automatic transfer from line power to battery power - to maintain continuous AC power to connected loads. 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Material of Construction Metal Cooling Method Dual multi-speed fans Form Factors Supported Mounting slots enable permanent placement of inverter on any horizontal surface (see manual for additional mounting information) Shipping Dimensions (hwd / in.) 16.00 x 14.50 x 23.25 Shipping Dimensions (hwd / cm) 40.64 x 36.83 x 59.06 Shipping Weight (lbs.) 131.00 Shipping Weight (kg) 59.42 Unit Dimensions (hwd / in.) 10.080 x 8.960 x 19.450 Unit Dimensions (hwd / cm) 25.5 x 49.5 x 22.71 Unit Weight (lbs.) 106.50 Unit Weight (kg) 48.31 ENVIRONMENTAL Relative Humidity 0%-95% Non-Condensing COMMUNICATIONS SNMP Compatibility Optional  SNMPWEBSOLOHV  accessory card enables remote monitoring of the unit via SNMP, SSH, telnet or Internet. Communications Interface Contact closure; DB9 Serial LINE / BATTERY TRANSFER Transfer Time (Line Power to Battery Mode) Dip-switch selectable 20 millisecond (full cycle) / 10 millisecond (half-cycle) transfer times which are compatible with many computers, servers and networking equipment - verify transfer time compatibility of loads for UPS applications Low Voltage Transfer to Battery Power In 230V AC "auto" mode, inverter/charger switches to battery mode as line voltage drops to 170V AC (user adjustable to 180V). In 208V AC "auto" mode, inverter/charger switches to battery mode as line voltage drops to 165V (user adjustable to 175V)-see manual High Voltage Transfer to Battery Power In 230V AC "auto" mode, inverter/charger switches to battery mode as line voltage increases to 260V (user adjustable to 270 - see manual), In 208V AC "auto" mode, inverter/charger switches to battery mode as line voltage increases to 235V (user adjustable to 245V-see manual) FEATURES & SPECIFICATIONS Grounding Main grounding lug connects inverter/charger to earth or vehicle chassis ground Generator Start Compatibility RJ-11 port connects to a generator with user-supplied cable to automatically cycle generator when battery level is low Battery Temperature Sensor RJ-11 port connects to optional battery temperature sensor cable to regulate the charging system based on battery temperature STANDARDS & COMPLIANCE Product Certifications IEC/EN 62040 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS; CE (Europe) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
APSX6048VRNET
物料型号: - 型号:APSX6048VRNET
器件简介: - 这是一个6000W的APS X系列48V直流至208/230V交流逆变器/充电器,具有纯正弦波输出、自动电压调节(AVR)、硬连线。它适用于移动、紧急和远程场所,可为各种电动工具、计算机、音视频组件和其他敏感电子设备提供可靠的电源。与发电机相比,它没有烟雾、燃料或过多噪音,是发电机电源的极佳替代品。
引脚分配: - 输入:支持208V交流或230V交流输入,48V直流输入,具有DC螺栓式端子和AC内置端子带保护盖板。 - 输出:纯正弦波输出,支持208V或230V名义输出电压,硬连线方式。
参数特性: - 连续输出功率:6000W - 峰值输出功率:12000W,可在短时间内提供高达12000W的峰值功率,以满足设备启动和循环期间的浪涌功率需求。 - 自动过载检测器、冷却风扇和可重置的交流电路断路器保护单元免受损坏。 - 高电流直流输入端子,便于硬连线安装。 - 自动电压调节功能,在电池充电和UPS模式下,无需使用电池即可校正低电压和过电压。
功能详解: - 作为UPS使用时,APSX6048VRNET可以自动、即时地切换到由电池提供的纯正弦波交流电源,以响应停电和电压骤降。 - 可选的SNMPWEBSOLOHV附件卡,通过SNMP、SSH、Telnet和互联网实现远程监控。
应用信息: - 适用于房车、商用车和应急车辆,可作为车辆逆变器、独立交流电源或延长运行的UPS使用。 - 可与用户自备的电池一起使用,实现无限的运行时间。
封装信息: - 材料:金属 - 冷却方式:双多速风扇 - 尺寸:10.080x8.960x19.450英寸(高x宽x深),或25.5x49.5x22.71厘米。 - 重量:106.50磅(约48.31公斤)。
APSX6048VRNET 价格&库存
很抱歉,暂时无法提供与“APSX6048VRNET”相匹配的价格&库存,您可以联系我们找货
