BP192V18-4U
BP192V18-4U
    TRIPPLITE
    SMART ONLINE UPS 192V RM 4U
BP192V18-4U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States External 192V 4U Rack/Tower Battery Pack for select Tripp Lite UPS Systems (BP192V18-4U) Highlights ● Extends runtime of compatible Tripp Lite UPS Systems with 192VDC external battery connection ● Provides daisy-chain capability ● Simple installation; 4U rackmount, tower or stack adaptable ● Simple maintenance chassis contains (4) 40lb. single-user replaceable battery modules MODEL NUMBER: BP192V18-4U Package Includes Description Tripp Lite's BP192V18-4U rack/tower external battery pack offers extended battery runtime when used in conjunction with compatible Tripp Lite UPS systems. Multi-use form factor supports configuration in rackmount or stacking applications using only 4 rack spaces (4U). Upright tower configuration supported with optional 2-9USTAND accessory. Includes heavy-gauge cabling with high-current DC connectors for simple installation. Additional output connector allows multiple BP192V18-4U battery packs to be daisychained to the UPS for even longer extended run operation. COMPATIBLE UPS SYSTEMS - SU12000RT4U, SU12000RT4UHW, SU16000RT4U, SU16000RT4UHW, and other Tripp Lite UPS systems that specify the use of this battery pack. Features ● Offers extended-run UPS operation when used in conjunction with compatible Tripp Lite UPS systems ● Supports stacking or rackmount installation using only 4 rack spaces (4U) ● Supports upright tower installation with optional 2-9USTAND accessory (holds 2 battery packs in tower configuration) ● Set of input/output connectors allows multiple BP192V18-4U battery packs to be daisy-chained to the UPS for even longer extended run operation ● Includes heavy-gauge cabling with high-current DC connectors for simple installation ● Simple maintenance chassis contains (4) 40lb. single-user replaceable battery modules Specifications OVERVIEW UPC Code 037332139269 INPUT Input Phase Single-Phase 1/3 ● BP192V18-4U external battery pack ● Mounting Hardware ● Instruction manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States UPS Input Cord Length (ft.) 1.333 UPS Input Cord Length (m) 0.4 OUTPUT Overload Protection 120A DC output fuse system BATTERY Expandable Runtime Yes DC System Voltage (VDC) 192 Battery Access Front-panel battery access Replacement Battery Cartridge (2x)  RBC9-192  Battery Replacement Description Simple maintenance chassis contains (4) 40lb. single-user replaceable sealed, flame retardant, non-spillable battery modules. UPS Connection Detachable cable with UPS specific DC connector (40.6 cm length, 4 gauge cable) Typical Battery Lifespan 4-6 years typical (North America) PHYSICAL Material of Construction Steel Rack Height 4U External Battery Pack Form Factor Rack/Tower Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITHD ); Tower ( 2-9USTAND ) Minimum Required Rack Depth (cm) 78.74 Minimum Required Rack Depth (inches) 31 Shipping Dimensions (hwd / in.) 13.00 x 33.00 x 23.00 Shipping Dimensions (hwd / cm) 33.02 x 83.82 x 58.42 Shipping Weight (lbs.) 284.00 Shipping Weight (kg) 128.82 Unit Dimensions (hwd / in.) 7.000 x 17.500 x 27.800 Unit Dimensions (hwd / cm) 18 x 44.5 x 70.6 Unit Weight (lbs.) 239 Unit Weight (kg) 108.41 STANDARDS & COMPLIANCE 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS; CE (Europe) WARRANTY & SUPPORT Product Warranty Period (U.S. & Canada) 2-year limited warranty Product Warranty Period (International) 1-year limited warranty Product Warranty Period (Mexico) 1-year limited warranty Product Warranty Period (Puerto Rico) 1-year limited warranty Optional Coverage 3 year, 5 year, next day, on-site warranty coverage available © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
BP192V18-4U
物料型号:BP192V18-4U 器件简介:该设备是外置192V 4U机架/塔式电池包,用于延长兼容UPS系统的运行时间。
引脚分配:包括一个可拆卸的电缆和UPS特定的DC连接器。
参数特性:输入相位为单相,UPS输入线长度为1.333英尺(0.4米),DC系统电压为192VDC,电池可扩展运行时间,典型电池寿命为4-6年。
功能详解:支持机架安装或堆叠应用,仅使用4U空间,支持塔式安装,通过可选的2-9USTAND配件支持两个电池包的塔式配置。
允许多个BP192V18-4U电池包通过菊花链连接到UPS,以实现更长的运行时间。
应用信息:与SU12000RT4U、SU12000RT4UHW、SU16000RT4U、SU16000RT4UHW等兼容UPS系统一起使用。
封装信息:钢制材料,4U机架高度,机架/塔式外部电池包形式,支持4柱19英寸机架安装。
以上信息摘自Eaton网站上的PDF文档。
BP192V18-4U 价格&库存
很抱歉,暂时无法提供与“BP192V18-4U”相匹配的价格&库存,您可以联系我们找货
